#15 |
Drives: '13 frs
#16 | |
Drives: Scion FR-S
I've read somewhere 20mm drop is ideal for this car from a handling prospective. The ohlin coilovers suggest a 15mm drop and they are one of if not the best suspension company around. Sent from my Nexus 7 using Tapatalk HD |
#17 |
Boost addict
Drives: Soarer, Efini, Silvia - all turbo
I've modded plenty of cars as well as worked with customer on theirs. So hope my 2 cent helps and worth the weight. No guessing or Googled opinion on my part.
Lowering springs + struts is the cost effective way to lower the car, but you can't adjust the ride height. That's only achieved by going with different brands, so Eibach may drop your front 1.4", while H&R might drop 1" in the front only. Another point is that once you find the right drop, the spring might not offer the rate you want, so it will either ride too stiff or soft. It is also a bad idea to change out only the springs and not the shocks, as you put more stress on the OEM shocks, therefore, cutting their lifespan. I'm not saying the OEM shocks suck, but just don't be surprised when they are blown. One last note on the springs, once installed, some brand WILL have a settling period where they'll drop just a bit more. Coilovers - Usually cost more, unless you go with those unbranded Ebay specials. This is the best way to go if planning for the 'slammed' look, or might be looking to change wheel size in the future. Besides adjustable ride height to preference, most premium brands also offer "dampening" adjustment. Meaning it allows you to adjust how hard/soft the car rebounds. I saw a comment above that coils are more 'bouncy'? Em... no. Some coils-overs even allow you to change out the springs for further customization on rates. Another perk is that the spring seats on the coil-over are smaller(so far on the brands I've sold or used), so you could go with wider tires and not worry about rubbing when turning. While lowering struts tend to have a bigger spring seat (the part of strut that flares out, where the spring sits on). Worst thing you can do is cut OEM springs. >_<
PM me for Password JDM product discounts!!
97 Accord-boosted and stolen | 97 240SX-boosted and sold | 95 SC300-boosted and crashed | 93 RX-7-boosted and sold | 97 SC300-boosted and current daily ![]() |
#18 |
RCE Yellows. Not too expensive, good reviews, stock-like ride quality, and a good drop (0.75")
Ultramarine 2013 Scion FR-S 6MT
#19 | |
Drives: 2013 Scion FR-S MT "Panda"
#20 |
Drives: 2015 Tacoma
i've had a lot of setups on previous cars from h&r coils, eibach pro-street coils, to a spring/shock combo with bilsteins. Best suspension came from a set of springs matched with bilstein shocks. I never once touched my coils after the initial ride height was set so it was a total waste.
That being said, i'm looking into the eibach pro-kit or H-Sport springs for now...then later koni yellows, or bilsteins if they get made... |
| The Following User Says Thank You to euroshowoff For This Useful Post: | shawnperolis (04-25-2013) |
#21 | |
| The Following 2 Users Say Thank You to shawnperolis For This Useful Post: | ftc~brz (04-25-2013), Sportsguy83 (04-25-2013) |
#22 |
Done
Drives: WRB BRZ
I bought my wheels off of a shop car and the pro kit was thrown into the deal since he had it set up for those wheels and it was just easier to do it all together. (I heart sweet deals)
I can say that the ride with these springs and stock shocks is less jarring than the oem set up. Even the one person I stuff in the back said she could notice the difference in the ride and she likes it better now. It's still tight and responsive and didn't change the handling as far as I can tell and I dd it. I did hate the lifted jeep look of the stock tires and well gap. ![]() I will probably switch to coilovers in the future but for now the price was right, I achieved the look I wanted sooner than I had planned, and I can save for other mods iso just coilovers. |
#23 |
Drives: 2013 Scion FR-S AT Asphalt
After seeing how you improperly installed your coilovers I don't think you are qualified to be making this statement.
http://www.ft86club.com/forums/showp...98&postcount=7 Scott
| The Following 2 Users Say Thank You to naikaidriver For This Useful Post: | 636 (04-25-2013), shawnperolis (04-25-2013) |
#24 | |
I keep a pretty good tab on the suspension section and follow very closely many of the conversations regarding this. Between other's experience here and my own experience with my own cars, I wouldn't recommend using springs only for the amount of drop you are looking for. The stock struts just weren't designed to work in that ride height range. If you were bent on using springs I would recommend the RCE's with a set of Koni struts. I don't think you will get all of the drop you are looking for but you won't be compromising your car's safety, ride quality, or longevity of your suspension components. Honestly though, if 1.4 inches is what you TRULY want, you're just going to have to bite the bullet for the coilovers. DO NOT CUT YOUR SPRINGS!! If you only do an occasional autocross and are not a serious track racer, I would recommend the Buddy Club Racing Spec coilovers. They can be found for around $1300 all around the web. Scott
#25 | |
Drives: '23 CWP BRZ
They be baller as fuck nao, so it aint no thang i got money idgaf ye. Oh yeah, how are your coilovers doing? |
#26 | |
![]() At least you posted your mistake like a BOSS where most would have hidden it! Bravo! Scott
#27 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
| The Following 2 Users Say Thank You to raul For This Useful Post: | naikaidriver (04-25-2013), shawnperolis (04-25-2013) |
#28 |
Drives: Asphalt FR-S
Why not Swift springs? I believe they're lower than RCE but not too low.
+1 for RCE though since I just installed mine. |
| Annoying Mustangs | Mburolla | FR-S / BRZ vs.... | 174 | 05-18-2013 11:42 PM |
| Slamming my FRS / Spring Rate Question. | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 01-28-2013 06:24 PM |
| To coilover or spring? That is the question... | Knightmare | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 01-13-2013 10:34 PM |
| Tapatalk app notification extremely annoying | Zgrinch | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 07-19-2012 11:20 AM |
| This whole withholding price thing is really annoying me | Hanzo | BRZ First-Gen (2012+) — General Topics | 13 | 03-19-2012 11:32 PM |
