Old 04-21-2013, 11:44 PM   #1
firestormriot
Drives: 2013 FRS
Zeta Performance Exhaust Install and Review (Pics)
First off, I want to give major props and thanks to @F1point4 for providing his expertise in how to actually go about doing the exhaust install in the comfort of my garage space. @F1point4 was gracious enough to assist, provide instructions and walk me through the parts list to make sure I had everything I needed to make the install as painless as possible.
The exact exhaust I purchased is the @ZetaPerformance Catback Exhaust - Stainless with Titanium Tips. My car is an automatic.
First Impressions
- The exhaust is very nicely made and has a nice stainless shine to it. I have the titanium tips and the coloring is even on both exhaust tips and the blue is perfect and was something that I was looking for in an exhaust. I think Zeta did a good job on the titanium tips. They are welded on the exhaust for those who are curious. I think their Carbon Fiber ones go over the regular stainless steel tips.
- The tubing diameter is 2.37" per Zeta and the exhaust tips have a 4.5" diameter.
- The welding overall on the exhaust looks pretty good to my amateur eyes and @F1point4 agreed as well. This was a plus for an exhaust that sells for just a hair over $600.
- The weight of the exhaust is around 35 lbs so it weights around 3.5 lbs less than the stock exhaust
- They did provide three gaskets and 6 nuts and bolts in order to install the exhaust. You have to use the two spring bolts and nuts and the 5 hangers that are on the stock exhaust to install.
Day of Install Steps (Quick Listing)
- Used a low profile 2.5 ton floor jack on the front then the rear to get the car on 4, 3 ton capacity each jack stands.
- Used PB Blaster on the bolts and nuts of the stock exhaust so loosen the bolts
- Loosened all the bolts and nuts and put them to the side. At this point, the front pipe comes off as it is not held on my hangers.
- For the hangers we used to a soap and water mixture and sprayed it on the hangers to take them off. It was much easier to take the hanger off the car on all 5 of the hangers that I took off.
- At this point, the stock exhaust is off the car
- The old hangers were taken off the stock exhaust and put on the Zeta exhaust pieces. @F1point4 then helped me in getting the Zeta muffler hooked on by the 4 hangers on the muffler piece. This was much easier than it was to take them off but the soapy water did help tremendously.
- The Y pipe was now hooked onto car via the hanger and the bolts were tightened with the gaskets between the connectors.
- The front pipe was then connected to the Y pipe and we adjusted slightly to connect up the front of the front pipe to the stock donut gasket.
- Tighten up all the bolts one last time
- Turn the car on and check for any leaks
- Done!
This process for someone who knows what they are doing like @F1point4 would take 45 minutes without the time to get the car on the jacks. I believe the install time was a tad over 2 hours and 15 minutes for us because of the fact that I am a noob when it comes to this install. Even then, a very good experience and definitely not a difficult install.
Driving Impressions
- @F1point4 and I were able to take the car for a short drive (15 miles) right after the exhaust was installed to pick up my Zeta Performance Carbon Fiber Spoiler from the UPS warehouse (more details/info to follow).
- The exhaust sounds great at start up, has nice deep exhaust tone as @F1point4 pointed out.
- When you start cruising it does quite up a bit but not too much. As soon as you do step on the accelerator, it does wake up with a nice exhaust note.
- I did have a 500 mile drive that weekend ahead of me so I knew Id get to hear the exhaust for a longer period of time and here is what I noted.
- The exhaust on the lower RPM's is easier to notice while in the car and definitely can be heard by people around you.
- On the higher RPM's it does quiet down a bit but from cars driving near me, it is noticeable. Not extremely loud but enough to where there is no constant drone from the exhaust.
- For a period of time, I was going around 90mph and the exhaust did get a bit louder but nothing that would give me a headache.
- Overall, two thumbs up for someone who, like me, is looking for an exhaust that won't break the bank but that would be put together well, have a nice deeper exhaust note but also something that wouldn't wake up the neighbors every morning or give you a headache while driving on the highway.
Thanks again to @F1point4 for the pictures, the assistance and all the help in getting this done.
firestormriot is offline   Reply With Quote
Old 04-21-2013, 11:45 PM   #2
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Zeta Performance Catback Exhaust Quick look
20130419-NabilZetaCatbackExhaust-045 by VictorN07, on Flickr
Back with another quick look at more parts for the EightSix. Recently I walked @firestormriot through his first major car mod...catback exhaust. I advised him to get a catback exhaust because it is one of the best feel good mods you can do to this car. He researched and let me know he got the new Zeta Performance Catback Exhaust.
While we were working I took some photos to share with everyone. I'll let him give the main feedback. Here we go
Before: Stock exhuast with DC Sports tips
20130419-NabilZetaCatbackExhaust-008 by VictorN07, on Flickr
First time to have his car in the air.
20130419-NabilZetaCatbackExhaust-009-Edit by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-018-Edit by VictorN07, on Flickr
The OEM catback exhaust compared to the Zeta Performance catback exhaust. The Zeta exhaust splits into two parts via the Y-pipe and feeds into a "dual" can style muffler.
20130419-NabilZetaCatbackExhaust-021 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-023 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-024 by VictorN07, on Flickr
The muffler. The entire exhaust is stainless steel. There are some big ol tips on this bad boy. I think @firestormriot said they were 4.5 inches.
20130419-NabilZetaCatbackExhaust-028 by VictorN07, on Flickr
He mentioned this exhaust was inexpensive. His selection made sense given his goals for his car are less aggressive than my direction. The welds actually were neat
20130419-NabilZetaCatbackExhaust-033 by VictorN07, on Flickr
More welds
20130419-NabilZetaCatbackExhaust-034 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-036 by VictorN07, on Flickr
Everything you need to install the system was included. Six nuts and bolts and three gaskets. You reuse the donut gasket on the front pipe
20130419-NabilZetaCatbackExhaust-039 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-044 by VictorN07, on Flickr
The Y Pipe
20130419-NabilZetaCatbackExhaust-048 by VictorN07, on Flickr
More neat welding
20130419-NabilZetaCatbackExhaust-052 by VictorN07, on Flickr
The flanges were not thick on this exhaust. It shouldn't be a big deal, but I enjoyed the thick flanges on the Perrin headerback components and the Borla Header
20130419-NabilZetaCatbackExhaust-058 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-060 by VictorN07, on Flickr
The welding was only on the outside of the pipes. The inside was not welded
20130419-NabilZetaCatbackExhaust-059 by VictorN07, on Flickr
The Y-Pipe had a plate stamped with the date of manufacture
20130419-NabilZetaCatbackExhaust-067 by VictorN07, on Flickr
Example of the gasket that is included
20130419-NabilZetaCatbackExhaust-068 by VictorN07, on Flickr
Welds around the resonated pipe. @firestormriot in the background
20130419-NabilZetaCatbackExhaust-070 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-071 by VictorN07, on Flickr
This is the flange that bolts up to the OEM front pipe. As you can see they mimic the OEM design quite a bit. Very thin flange designed to use a donut gasket and use the two OEM spring bolts
20130419-NabilZetaCatbackExhaust-073 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-076 by VictorN07, on Flickr
Inside of the resonator.
20130419-NabilZetaCatbackExhaust-079 by VictorN07, on Flickr
Zeta Burnt tips
20130419-NabilZetaCatbackExhaust-080 by VictorN07, on Flickr
Nice touch on the muffler
20130419-NabilZetaCatbackExhaust-083 by VictorN07, on Flickr
Final fitment on the car. Given that the entire exhaust has so many connection points, the fitment is bang on. We didn't have to fidget at all to get the alignment right. @firestormriot said Zeta test fits each exhaust to make sure it all fits together.
20130419-NabilZetaCatbackExhaust-088 by VictorN07, on Flickr
Long shot under the car. I like this one
20130419-NabilZetaCatbackExhaust-093 by VictorN07, on Flickr
SHot of installed Y-Pipe
20130419-NabilZetaCatbackExhaust-094 by VictorN07, on Flickr
Dem pipes
20130419-NabilZetaCatbackExhaust-096 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-098 by VictorN07, on Flickr
20130419-NabilZetaCatbackExhaust-099 by VictorN07, on Flickr
Quick Thoughts
+ The exhaust was very easy to install. Did not have to continually mess about to get good alignment
+ They fill in the bumper cutout nicely. They also fill the hole made by the bumper and diffuser together
+ Wasn't a big fan of the thin flanges
+ Welds were pleasing aesthetically
+ @firestormriot told me there is a 3lbs weight savings. Not super impressive
+ Fits an automatic gearbox so that is great.
+ The exhaust note was very smooth and there was no drone or rasp. Just like my Perrin headerback it gets out of the way when you want to cruise or go forth gentle. Apply throttle and it wakes up
+ It does have a deep tone.
+ I think it does its job well.
Overall it was nice to be able to show someone new to cars how to mod it. I basically told him what tools he needed and told him what to do. I think he is very pleased with the way things came out. He'll update the first post with this detailed thoughts.
Video
With each review I strive to get better and better.
OEM Exhaust
[ame="http://www.youtube.com/watch?v=wjpEK2HlsgM"]Toyota 86 OEM exhaust - Zeta Performance Catback Exhaust Comparison - YouTube[/ame]
Zeta Catback
[ame="http://www.youtube.com/watch?v=476b-bdG3e8"]Zeta Performance Catback Exhaust Comparison - YouTube[/ame]
Driving Review Part 1 of 2
This my first attempt at recording in car driving video. Let me know how I did.
[ame="http://www.youtube.com/watch?v=Iaz0pS0S6kk"]Zeta Performance Catback Review - YouTube[/ame]
Driving Review Part 2 of 2
[ame="http://www.youtube.com/watch?v=PZn_Du2yw0U"]Zeta Performance Catback Exhaust Review Part 2 - YouTube[/ame]
Near Miss.
Dammit Other drivers
[ame="http://www.youtube.com/watch?v=RKkt3TnD-6o"]Zeta Performance Catback Goof - YouTube[/ame]
F1point4 is offline   Reply With Quote
Old 04-22-2013, 01:52 AM   #3
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
@firestormriot @F1point4 are you able to post some vid of the exhaust while driving???...want to hear how it sounds.
Old 04-22-2013, 01:55 AM   #4
F1point4
Photo Specialist
F1point4's Avatar
i did record some clips. will post tomorrow
Old 04-22-2013, 02:04 AM   #5
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Love your work, @F1point4. Always so easy to see what you are working on.
husker741 is offline   Reply With Quote
Old 04-22-2013, 11:43 AM   #6
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Nice and clean.. Looking for exhaust for mine.. I want something that's not loud when driving normal and something that growls when I open it up ..
Old 04-22-2013, 12:35 PM   #7
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
that is what I am looking at too..
Old 04-22-2013, 01:42 PM   #8
marky
marky's Avatar
Looks like we in the same boat :happy0180:
Yeah I'm not a fan of something that's loud when driving at normal rpm.. I'm sure it will annoy me if its loud... Its like them civic fart cans.. Loud AF but going slow..
Can't wait for the video upload..
Old 04-22-2013, 01:49 PM   #9
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I've always thought that Zeta exhaust was VERY good-looking! Nice write up and thanks for taking the time to share!
Honestly I'm surprised that it still came out slightly lighter than stock. I would have thought it would have been heavier.
Scott
naikaidriver is offline   Reply With Quote
Old 04-22-2013, 01:59 PM   #10
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Yea man..on other hand, I was looking into the Nameless Axleback exhaust too. Heard lots good things about Nameless over the forum.
Old 04-22-2013, 02:43 PM   #11
Timmy_Jones
Spun
Drives: 23' Supra
Hmm, great pics and install, but that exhaust just doesn't do it for me. So many unnecessary bends and twists. Exhaust seems like a great spot to cut weight out on the car and this is not the ticket for that. Also, the exhaust tips are blue, not sure what happened there? Is the single tube diameter 2.37"? That seems like the stock size, am I correct?
Timmy_Jones is offline   Reply With Quote
Old 04-22-2013, 02:56 PM   #12
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
interested in the sound clip as well.
And to the OP which setup for perrin headerback did you have? (i.e. nonres/cat)
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 04-22-2013, 05:08 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
nice and deep review
Old 04-22-2013, 06:08 PM   #14
firestormriot
Drives: 2013 FRS
The exhaust tips are blue because this exhaust has the titanium tips on there.
The 2.37 diameter is for the front pipe. Not exactly sure what the stock size is.
f1point4, zeta performance exhaust
Zeta Performance - Full Stainless Steel Cat-Back Exhaust System ZetaPerformance Engine, Exhaust, Transmission 142 05-06-2015 12:38 AM
Zeta Performance Intake Review/Install fmsida Engine, Exhaust, Transmission 20 08-15-2013 12:11 PM
ZETA Performance Cat-back Exhaust System - Stainless Steel, Titanium & Carbon Fiber ZetaPerformance Engine, Exhaust, Bolt-Ons 30 07-18-2013 12:53 AM
FS: Zeta Performance Radiator Kit New Asphalt~86 Engine, Exhaust, Bolt-Ons 0 04-15-2013 10:49 PM
