| Northwest AK, ID, OR, WA |
#15 |
Vtec Jesus
Economy is a huge factor with the tuner. I get great gas mileage with my Honda that runs 100 percent E85. E85 is also a full dollar or more cheaper than 93 in Chicago. Not quite sure where the expensive thought is coming from.
#16 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
If you want a peak HP car that will drive and handle differently than stock, you don't plan on doing anything but showing off your dyno sheets and popping your hood for high school girls; I say go turbo.
If you want a smooth, factory feeling powerband with no intrusion to you oil system. A smooth and instant power delivery, wicked manufacturer support and support from the big name brands that have a reputation to lose. Then go vortech. Also, with the vortech, you get to throw on the UEL headers and get a beast sounding car. Not just another turbo 4 banger. Jeff Perrin is capable of making 300whp on the stock fuel system, I've seen his car in person and its gorgeous. I have seen the AVO kit in person, the numbers are there on the dyno but to be totally honest, I wouldn't be too stoked to pop my hood and show it off. Here is the thing with this car that I don't think most people on this forum are realizing, sure it's cool to say "I've got 400+whp", but we have a 2700lb car in its heaviest form. 220-270whp puts you at the magical 10lbs:hp ratio that super car manufacturers strive to meet. It really isn't going to matter how you achieve that HP, be it S/c or turbo. The turbo power comes in a bit faster which will change the factory balanced, fun, predictable feel. After a lot of research, personally, I am leaning towards the vortech with a super aggressive tune from Perrin until open source for the car picks up a little better. Bob, still love you and drift office is amazing. Just my preference on this one.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following User Says Thank You to Wonderbar For This Useful Post: | Silver86 (05-15-2013) |
#17 |
Drives: FRS :D
Same boat I've been checking out too many turbo kit threads and sc threads. I want one soo badly its bad news. Only thi g about the Vortech sc is I haven't seen a single one put out anything near 300whp other than Perrins. Everyone else seems to be around 250ish.
I would be very happy with 275hp Nd that's roughly my goal but the ability to break 300 is just soo alluring
Out of the FRS game
#18 |
Drives: 2013 Asphalt FRS
I'll wait patiently for a year waiting for the ino supercharger to be released before I make any deciding factors on the build for my car.
Super charger -Boost comes with RPM range (higher the RPM the more boost) It's a ladder of boost. -Reliability factor is that a supercharger will not require as much service as a Turbo set up and isn't as "picky" in different weather conditions like a turbo kit is. (once you start getting into more boost you will need different tunes for different temps) On a supercharger this isn't exactly an issue since the Boost is made by the actual inefficiency of the supercharger/pulley. Different pulleys will give you more or less boost. -MPG it honestly depends on your foot. Turbo Depends on the turbo.... (usually boost comes all at once) -Smaller turbo, more lower end power faster spool boost will drop off at peak RPM More torque and faster torque due to spool More for time attack or autoX Better MPG -Bigger turbo, more high end power more lag more boost less low end torque usually (depends on supporting mods) re bigger injectors and fuel pump will require more maintenance on higher boost applications overboost will need to be watched in temp changes MPG will go down and car will run "weirder then stock in low RPMS" Will make bra's fall off.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#19 |
Boosted Member
Drives: 2013 SWP BRZ Limited
thanks for the valuable input guys. So far I get turbo = high school girls and bra's coming off. SC kit = way to go to keep balance of the car, but may have the lowest potential for HP compared to turbo kits.
So far Vortech is winning me over by a small margin..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#20 | |
Boost comes in suddenly generally is a "feature" of bigger turbo's, a small turbo setup like ours comes in much like a OEM turbo setup. Smaller is a relative thing, it will do 350whp at higher boost levels. |
#21 | |
Drives: FRS :D
Out of the FRS game
#22 | |
P.s I do like your kits though and have run AVO turbos before and have no complaints!
2013 Sion FRS
#23 | |
Drives: 2013 subaru limited wrb brz
#24 | |
| The Following User Says Thank You to AVOturboworld For This Useful Post: | NickFRS (04-19-2013) |
#25 |
It's easy to be in the low 30's. ESP if you drive in higher elevations around Oregon. He doesn't want a garage queen so the car still needs to be realisticly street-able.
2013 Sion FRS
#26 | |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
Presently average prices in Washington are: 92: $3.83 e85: $3.13 So armed with those figures lets take a metaphorical trip. Lets go 1000 miles. FRS' gas tank is 13.2 gallons max. We'll assume for the sake of argument that we are able to achieve no more than max highway MPG as stated above. 396 miles a tank on 92 octane 277.2 miles a tank on e85. In order for you to complete the 1000 miles you would need to fill up (assuming you're running nearly dry and then filling up): 3 times on 92 (1188 potential on 3 tanks) 4 times on e85 (1108.8 potential on 4 tanks - ~80 miles LESS) So to make that trip you're going to spend: $151.67 for 92 octane $165.26 for e85 e85 stations in my area, and circled where I actually drive. Closest station to my house is 50 miles. Sounds like a really attractive way to tune
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
| The Following 2 Users Say Thank You to deucethemoose For This Useful Post: | Drift-Office (05-15-2013), NickFRS (04-19-2013) |
#27 | |
When my 2002 WRX loved your turbos. Also I was mainly refering to larger turbos like 30r or 35r turbos.-Personally if I boosted this car I would use something like a JDM twin scroll vf42 or something. :happy0180:
2013 Sion FRS
#28 | |
Vtec Jesus
| Torn on Antenna Options. | 2pt5RS | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 02-18-2014 06:16 PM |
| Vortech supercharger. | skatery1989 | Engine, Exhaust, Bolt-Ons | 2 | 02-23-2013 07:19 AM |
| Torn between a BRZ and a 335 Coupe (with M package) | Iixii | FR-S / BRZ vs.... | 70 | 12-04-2012 07:13 AM |
| Still torn between WRB or silver. | whitejdm | BRZ First-Gen (2012+) — General Topics | 34 | 05-21-2012 05:50 PM |
