Old 04-17-2013, 01:40 PM   #2423
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by buditjoenawan View Post
It doesn't matter if it's phantom knock or real knock, since the ECU is applying self preservation tactics anyway. As a result, the car will feel like it's stuttering, hesitating, bucking. Regardless of real or not, the ECU "hears" more things happening and takes preemptive measures to mitigate the possibility.
I can tell you that you definitely won't be feeling a 1 degree of timing knock correction, and that was over a very short RPM window before the ECU said, "Nope, I was probably wrong about that call" and put the timing back in.
Old 04-17-2013, 01:46 PM   #2424
buditjoenawan
Drives: Very very slowly
I'll leave it to Paul to comment on whether or not you can feel the corrections in the car. My experiences are not with this car and perhaps this particular motor/ECU combo is far smoother than other cars I've experienced.
buditjoenawan is offline   Reply With Quote
Old 04-17-2013, 01:54 PM   #2425
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
It doesn't matter if it's phantom knock or real knock, since the ECU is applying self preservation tactics anyway. As a result, the car will feel like it's stuttering, hesitating, bucking. Regardless of real or not, the ECU "hears" more things happening and takes preemptive measures to mitigate the possibility. The lower octane fuel, and who knows if there are any weird blends or oxygenation that is in the gas, will inherently be less stable at higher chamber pressures. At this point, I am assuming that the motor is octane limited; smart tuners please refute me.
Paul, does the ignition advance multiplier go beyond 1.0? If I was tuned for 91 octane, then moved to an area with 93 octane, will the ECU adapt to the higher octane?
budi
This may be true but a second set of ears per se will confirm weather it is real or not and this can be tuned out during tuning. Since I am not an EcuTek Master tuner I don't have access to what all it can do but if it is anything like any other tuning software you can adjust knock sensitivity and the total amount of knock retard when detected. You can even adjust in most cases the speed in which it pulls timing. There are a bunch of different ways you can change how the ECU reacts to knock detection but you must first determine whether it is real or not before making these adjustments. It is very frustrating to me that I cannot dig into the ECU myself without paying an arm and a leg for the Master EcuTek license but at the same time I like it because it keeps people from ripping off your hard work in tunes. Once you start really modifying you vehicle the stock knock sensors can start picking up all kinds of false readings so this is a great way to account for that.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 04-17-2013, 01:58 PM   #2426
AVOturboworld
budi
1.0 is the best case scenario. The stock ECU setup starts at 0.7, and ramps up from there (on good gas) or down from there (on bad gas). On a bad tank of gas or extreme conditions, it's normal to see it down in the .6 range. Toyota and/or Subaru knew the engine was going to see bad gas, which is always going to be an issue at 12.5:1 compression, so the ECU is designed to deal with it as best possible.
It may seem like we are being overly finicky about keeping it at 1.0, but we just want to make sure we deliver as safe a tune and setup as possible.
Old 04-17-2013, 02:29 PM   #2427
sw20kosh
Drives: 2013 Black FR-S
Looks like a high quality and reliable water/meth injection system is now on my list of support add ons for FI.
Old 04-18-2013, 10:13 AM   #2428
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Is there any possibility pf having the option for the AVO logo on the fmic?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-18-2013, 11:07 AM   #2429
2forme
Paul, sent you a PM, get back when you get a minute.
Old 04-18-2013, 11:40 AM   #2430
Brody602
Drift King
Brody602's Avatar
So did I, I second this post. Lol
Old 04-18-2013, 12:04 PM   #2431
AVOturboworld
I can probably arrange for that, yes.
Old 04-18-2013, 12:05 PM   #2432
Brody602
Drift King
Brody602's Avatar
Would it be free seeing as how it'd be free advertising?
Old 04-18-2013, 12:06 PM   #2433
Brody602
Drift King
Brody602's Avatar
The option that is, not the fmic itself, lol.
Old 04-18-2013, 12:15 PM   #2434
AVOturboworld
Ahhh, I wouldn't charge for that. Just need to make up another template to size. If I can, I'll see if I can arrange for it to be done factory side, so it doesn't need to be completely unpacked to be painted.
Old 04-18-2013, 12:17 PM   #2435
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I would like that too, but guess I'll have to DIY it! A paper/carton template would help (cough, cough)
Old 04-18-2013, 12:19 PM   #2436
Brody602
Drift King
Brody602's Avatar
It'd be nice to have as an option, in white on the black fmic would look nice, the logo with turbo in it would like awesome IMO, but obviously makeit an option for those who really want to retain the oem look.
Cheers!
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
