Old 04-03-2013, 01:46 PM   #29
mrk1
Drives: Sterling BRZ Ltd
Warranty replacement set on its way. My first set matched the pictures on the first page of this thread. With a black bearing in the center. When my new set comes in I will confirm if they also match the pictures here.
mrk1 is offline   Reply With Quote
Old 04-03-2013, 06:24 PM   #30
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I just got mine in today. I have the new dust covers and bearing. Also I noticed on the side of the box there is a date on it. mine was 3-5-2013 I assume these came off the line at that date. Still wondering if these will work with the koni yellows adjustable knobs.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-03-2013, 07:25 PM   #31
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
OK, I was putting my setup back together, and I noticed something concerning, and it could explain the clunking, at least for those of us running KWs with these top hats. When you put the spring perch and the conical washer onto the strut shaft, there is very little of it protruding into the actual bearing of the top hat (I measured only 1/8"). I think we need a nut or a sleeve that will fill the gap between the threaded portion of the strut and the bearing. Otherwise, all that slop is just going to cause problems, and it could be a contributing factor in why these things failed so quickly.
Compare the KW perch and washer with how much thread shows with the stock perch. I measure 3/8" from the top of the perch to the threaded section with the stock perch.
neurokinetik is offline   Reply With Quote
Old 04-04-2013, 06:19 AM   #32
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by SWPBRZ415 View Post
Nope no noises, running RCE yellows. -1.5 camber all around on 18x8.5.
Hello, @SWPBRZ415
Have you used a conical washer over a spring perch?
makinen is offline   Reply With Quote
Old 04-06-2013, 10:14 PM   #33
neurokinetik
Well, for the first time ever since installing the COM-C mounts and KWs, I am noise free!
Not sure whether it is the improved, "2nd generation" COM-C mounts, the presence of the correct conical washer, the spacers that I added to fill in the gap between the threaded section of the strut and the bearing, or the new swaybar endlinks, but all of the odd clunks and metal-on-metal sounds I had last year are completely gone this year. Now all I hear are the loud-ass Hankooks and the exhaust. As it should be!
EDIT: Clunks and bangs are back when I turn the wheel, but I'm not assigning the blame to the mounts yet. I may try the KWs without the helper springs and see if that helps.
Old 04-09-2013, 07:00 PM   #34
mrk1
Got my replacement "second gen" mounts today. Mine match the picture on the first page. Second generation have silver KOYO brand bearings and spiffy dust covers.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
Old 04-10-2013, 07:23 PM   #35
Spencer
Can someone give a short review ??
Spencer is offline   Reply With Quote
Old 04-10-2013, 08:00 PM   #36
Calum
That Guy
Drives: 2013 asphalt FRS MT
Try here for a short review.
http://autoblopnik.com/category/scion/
Edit: damn, nobody thought that was funny. Tough room.
Old 04-15-2013, 12:25 PM   #37
mrk1
Bad clunking part on the left with the black bearing, New replacement on the right with the silver KOYO branded bearing, also the new dust cover.
The Build Thread
Old 04-15-2013, 10:53 PM   #38
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Been running my new revised warranty replacement Com-C's for a week now. They are quiet, and they are performing great with no conical washer. No rubber deformation, no noises over bumps. OEM struts, RCE Yellows.
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
bpracer (04-16-2013), Calum (04-16-2013), console_cowboy (08-02-2013), wparsons (04-16-2013)
Old 04-16-2013, 11:42 PM   #39
bpracer
Drives: Asphalt FR-S
Keep us updated, I need a bit more camber than the crash bolts provide.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
The Following User Says Thank You to bpracer For This Useful Post:
brn12345 (09-29-2013)
Old 04-16-2013, 11:54 PM   #40
bpracer
HA!
edit - Well, that site lead to another link, that lead to another link, to this T-shirt. Yeah, you have to follow F1 to get it: http://www.shotdeadinthehead.com/kim...hirt-mens.html
Nice!
Asphalt FR-S
Ducati 848
Calum (04-17-2013)
Old 04-17-2013, 09:22 PM   #41
mrk1
I am waiting on back ordered Koni inserts to come in then I will install everything again.
The Build Thread
Old 04-21-2013, 11:18 PM   #42
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I just had my konis, rce springs, and WL com-c's installed professionally and there's definitely some clunking and noise that wasn't there before. I have to check some things (sway bar endlinks etc.) but I'll report back here when I figure out what's up.
enjoyminutemaid is offline   Reply With Quote
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
