Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 04-06-2013, 12:39 AM   #169
F-T
F-T's Avatar
Drives: FRS
bumooop
F-T is offline
Old 04-10-2013, 09:42 PM   #170
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Alright so I just got mine today. But I don't know how I want to install them. Either always bright, or dim with the headlights. Suggestions?
husker741 is offline
Old 04-10-2013, 10:00 PM   #171
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I'll take one. PM'ing you now!
Chewie4299 is offline
Old 04-10-2013, 10:50 PM   #172
yotaracer6
yotaracer6's Avatar
Drives: 2013 scion fr-s
can you pm me? id like to purchase a set.
yotaracer6 is offline
Old 04-15-2013, 08:48 PM   #173
F-T
F-T's Avatar
Drives: FRS
do bright with daytime running lights.. and dim at night with head lights... I think the bright is a little too bright for night time driving... IMO
F-T is offline
Old 04-15-2013, 09:07 PM   #174
husker741
Ok sounds good!
Old 04-15-2013, 09:33 PM   #175
serial gixxer
Ok sounds good!
I have it set to full bright at all times (on w ign) and haven't had any issues.
serial gixxer is offline
Old 04-19-2013, 12:11 AM   #176
charger
Drives: frs
I'm no good at wiring and this is the step I'm not getting..can anyone clarify a little? I'm not getting how the fuse wire is used and how to tap into the white power wire.
charger is offline
Old 04-19-2013, 03:49 AM   #177
F-T
F-T's Avatar
Drives: FRS
White and blue wires go conected to headlights while the red power wire goes connected to anythig that has ignition power.
F-T is offline
Old 04-20-2013, 06:47 PM   #178
charger
Drives: frs
Finally had time to finish this..
I don't suggest wiring to the cigarette lighter behind the glove, it is way too much of a hassle just because it's hard to tap into the power wire with barely any room to see and move. I can confirm that the power wire to the radio works exactly the same way as the cigarette power lighter in that when the key is turned, the LED's will always be on (which sucks IMO). I still wired to the cigarette lighter just because it was annoying me. When I finally got it, it was when I was looking inside at about a 45 degree angle from the floor rather than keeping my head directly underneath and staring up. Much easier to reach in that way and still be able to see well enough to position your hands and clamp the wire tap with pliers.
charger is offline
The Following User Says Thank You to charger For This Useful Post:
F-T (04-22-2013)
Old 04-22-2013, 03:41 AM   #179
F-T
F-T's Avatar
Drives: FRS
I love running them at night too but I run them on low setting
Sent from my SPH-L710 using Tapatalk 2
F-T is offline
Old 04-24-2013, 06:34 PM   #180
F-T
F-T's Avatar
Drives: FRS
Bump
F-T is offline
Old 04-26-2013, 09:07 PM   #181
Chewie4299
Spaceman
Chewie4299's Avatar
Just received mine today and installed them. I LOVE THEM.
Used the blue wire so they dim when I turn on my headlights. On full-time otherwise.
Old 04-29-2013, 10:27 AM   #182
jwbrocloud
Drives: Raven MT
Finally got mine installed as well. On full bright all the time. Also installed with nigel's OEM foglight harness and button next to trunk button so I can turn them off in case I want to creep up on people. Quality product. Easily one of the most enjoyable mods I have put on my car. Thanks F-T
jwbrocloud is offline
The Following User Says Thank You to jwbrocloud For This Useful Post:
F-T (04-30-2013)
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 02:15 PM
LED daytime running lights sav AFRICA 168 03-22-2016 05:26 AM
Front LED Daytime Running Lights myjobis2pimp NY / NJ / CT / PA 0 04-18-2013 06:47 AM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
