Old 04-04-2013, 05:17 PM   #1
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Pandora Music
Can I listen to Pandora through my cars speakers?
If so how?
Thanks.
Carlitoz3 is offline   Reply With Quote
Old 04-04-2013, 05:22 PM   #2
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
http://www.ft86club.com/forums/showthread.php?p=666146
Old 04-04-2013, 05:28 PM   #3
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Yep, I just put the stock radio in bluetooth audio mode and fire up Pandora on my Nexus 4.
Narcoden is offline   Reply With Quote
Old 04-04-2013, 06:45 PM   #4
Carlitoz3
Carlitoz3's Avatar
I have to try this. I was trying to connect via USB cord this whole time. But as I noticed from the link, that only works with iPhones.
Old 04-04-2013, 06:48 PM   #5
norsamerican
Drives: WRB BRZ
i wish i had unlimited data to stream pandora
Old 04-04-2013, 07:05 PM   #6
Carlitoz3
Carlitoz3's Avatar
I have unlimited :p
The only problem though is I have TMobile and for some reason, my internet starts to slow down half way through the month!
Old 04-05-2013, 12:16 PM   #7
Hix
Hix's Avatar
Drives: 2017 WRB PP
Originally Posted by Carlitoz3 View Post
I have unlimited :p
You need to get your phone lock code and remove the proxy they put on your phone. If anything I would recommend getting DSP Manager or maybe rooting your phone to Android 4.2.2 with something like CyanogenMod
Hix is offline   Reply With Quote
The Following User Says Thank You to Hix For This Useful Post:
Carlitoz3 (04-11-2013)
Old 04-05-2013, 01:09 PM   #8
blackraven1425
Drives: raven at
I have unlimited :p
That's because it's not unlimited. TMobile offers unlimited plans, but there's a stipulation in the contract that if you go over a certain amount (I believe 5GB), they throttle you down to EDGE speeds instead of 3G.
blackraven1425 is offline   Reply With Quote
The Following 2 Users Say Thank You to blackraven1425 For This Useful Post:
Carlitoz3 (04-11-2013), tripjammer (04-12-2013)
Old 04-11-2013, 05:53 PM   #9
Carlitoz3
Carlitoz3's Avatar
Do you have a link on how I can do this?
Old 04-11-2013, 05:57 PM   #10
Carlitoz3
Carlitoz3's Avatar
Still having trouble hearing my cell through the radios Bluetooth. I can talk but still can't listen to Pandora or navigation through Bluetooth. Does anyone know under what setting on the radio I need to change to fix this? Thanks.
Old 04-11-2013, 06:51 PM   #11
Narcoden
Narcoden's Avatar
Android phone? Check the Bluetooth settings... Find the BT connection for your radio on your phone and go into its settings. Then make sure the "media audio" box is checked. Then try again.
Sent from my Nexus 4
Old 04-12-2013, 03:05 PM   #12
Hix
Hix's Avatar
Drives: 2017 WRB PP
Android? Use xda-dev site and poke around. For the lock code (again droid) I would call your provider and tell them you are adding a new sd card because you are out of internal memory and it is asking you for the code.
Old 04-12-2013, 04:40 PM   #13
alderaan34
alderaan34's Avatar
I have their truly unlimited plan, no slow downs here, although tmo in general is slow. My max use has been 10 gigs in a billing cycle, other guys on xda have used about 30 I think.
alderaan34 is offline   Reply With Quote
Old 04-12-2013, 11:43 PM   #14
Carlitoz3
Carlitoz3's Avatar
The box is checked, still no luck
Music gusbarragan Scion FR-S / Toyota 86 GT86 General Forum 2 03-02-2013 01:21 AM
Pandora RMStringer Electronics | Audio | NAV | Infotainment 12 01-15-2013 08:53 AM
z1r jackel pandora helmet karma003 Tracking / Autocross / HPDE / Drifting 2 09-14-2012 06:08 AM
Spotify or Pandora Jordan6908 Electronics | Audio | NAV | Infotainment 2 06-29-2012 02:47 PM
scion teaming up with pandora? julioisaroller Scion FR-S / Toyota 86 GT86 General Forum 18 07-28-2011 11:28 PM
