Old 04-11-2013, 11:33 AM   #1
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
E85: A word to the wise
Over the last 3 months or so, I've been "playing" with E85 tunes from two different Ecutek tuners. This has been a good thing, regardless of the power gains, since it has taught me quite a bit about corn juice. I've traditionally been a pump gas guy just like many of you.
One of the problems that I have discovered is how incredibly inconsistent e85 stations are with their Ethanol content. Not only have the stations not known what the actual content is, E70 or E85 (70 to 85% ethanol), but in some cases I have been told that it is E70 only to find out I pumped E85 or something close to it. This can be bad for many reasons. I've been told that you can and should measure Ethanol content before loading the appropriate tune, but the cheap way of doing this using a glass cylinder, some distilled water, an E?? sample and a stopper is not practical at all since you will pretty much need to do this every time you fill up. That is if you wish to run E85 full time such as myself. You can't trust the E85 schedules (class 1 (79) , 2 (74) , 3 (70)) that are posted on various Internet websites for each state. I repeat, these are not accurate. Some stations have blender pumps that show a minimum 70% 105 octane rating, but they can't actually tell you the TRUE state of the content. It could even be close to E90!
A recent trip to the dyno on an E70 tune led to a power loss because of a lean condition (~13.5 AFR at WOT). I ended dyno testing after the 3rd run. Apparently I had E85 in the tank. Thank god alky is forgiving. I've found that it has cooling properties and lower EGT's better than pump and resists detonation.
Moral of the story: make your life easier and protect your motor. Get an Ethanol Content Analyzer (ECA) from Zeitronix or whomever. This will hook up to your fuel system and comes with a digital display that you run to your cabin. It will show you the Ethanol content in your tank.
I'm not suggesting that people not use E85. Just be careful and take appropriate steps before going WOT.
tech4pdx is offline   Reply With Quote
Old 04-11-2013, 12:00 PM   #2
arghx7
Drives: car
aaaaaand that's why actual flex fuel cars have an ethanol sensor or a software model to determine ethanol content
Old 04-11-2013, 12:03 PM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
This is why if I go with E85 it will be a true flex fuel setup.
Old 04-11-2013, 12:03 PM   #4
xxscaxx
Drives: 2013 SWP BRZ
are you filling up at the same station every time?
xxscaxx is offline   Reply With Quote
Old 04-11-2013, 12:09 PM   #5
SkullWorks
Drives: SSM LT MT BRZ
A good tuner with a standalone can allow for this in the tune, you will err on the safe side with timing but still reap 90% of the gains of E85.
The best case scenario is running a ECA with a feedback loop to the ECU (standalone or otherwise) that accounts for the Ethanol Content and blends the maps accordingly. you should essentially have a 91 map and an E92 map and it will be a predictable slope between the two as far as timing and fueling go so that they can be interpolated between, there are only a couple options for this currently, but most companies are working on or just now releasing firmware that will handily...handle...this task. I believe even ECUTek is developing a "flex fuel" version of software for our vehicles.
Old 04-11-2013, 12:10 PM   #6
tech4pdx
Make love
tech4pdx's Avatar
Yes and no. I use whatever station is available when I need to refuel. All of the stations here post the same info on the E85 pumps and say the same thing verbally about E85. They don't really know and I will never again trust what comes out of their mouths. An ECA will tell the truth.
Old 04-11-2013, 12:14 PM   #7
tech4pdx
Make love
tech4pdx's Avatar
Supposedly, Ecutek flex fuel is already available. The flex fuel maps exist. I have yet to see any real penetration of this technology in this market.
Regardless, I'm at the point where I am taking my tuning needs locally using whatever tuning solution the local tuner prefers. It's safer and more convenient that way. Just my opinion! Not a knock on anybody!
Old 04-11-2013, 12:19 PM   #8
CBR600RR
Drives: Raven Black
@Visconti I'd like to hear John's 2 cents on this
Old 04-11-2013, 12:33 PM   #9
xxscaxx
I was only asking because I just purchased an e85 tune, and I only have one station near me that has e85. So I will be filling up at that same station every time.
Did you do any data testing in regards to going to the same station and seeing if the content is consistent?
Old 04-11-2013, 12:36 PM   #10
tech4pdx
Make love
tech4pdx's Avatar
@CBR600RR .. John is aware of my situation and he has my logs. He kindly let me know that I should be testing my ethanol content. I agree with him. That's why I'm buying an ECA.
John has done nothing wrong. He is a good tuner. The responsibility is on me to verify the quality and the content of my fuel.
Old 04-11-2013, 12:44 PM   #11
CBR600RR
Drives: Raven Black
if you ran the e85 tune with e70 fuel what would the result be? running rich?
Old 04-11-2013, 12:46 PM   #12
2forme
Yup. The higher the ethanol content, the more fuel required to maintain AFR.
Old 04-11-2013, 12:49 PM   #13
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Sometimes I'm glad there's no E85 in CT. Takes the choice away from me......
Chewie4299 is offline   Reply With Quote
Old 04-11-2013, 12:50 PM   #14
tech4pdx
Make love
tech4pdx's Avatar
I do not have this data. In addition to what I've learned, I've also been told by different tuner shops/mechanics that blindly pumping "E85" without testing is asking for trouble. E85 pumps don't exist for tuners. They exist for FFVs. They are under no real obligation to guarantee the precise ethanol content because they know FFVs can deal with it. A pump gas car on a fixed tune geared towards performance will not be so forgiving. There are numerous other forums out there that have been discussing this for years.
Keep a word...Drop a word tuckdaddy Off-Topic Lounge [WARNING: NO POLITICS] 18889 03-25-2023 09:13 AM
Young and Dumb VS. Old and Wise Still Tripped Scion FR-S / Toyota 86 GT86 General Forum 105 05-07-2013 07:17 PM
Performance Wise - Almost Identical: FR-S vs. SLK 250 SkitterSkotter FR-S / BRZ vs.... 36 01-17-2013 05:14 PM
Word of wise.. connor_lol FR-S / BRZ vs.... 25 08-13-2012 04:53 PM
Is it wise to buy an all-new model car when it first comes out? Raiden Scion FR-S / Toyota 86 GT86 General Forum 39 01-29-2011 10:57 AM
