Old 04-05-2013, 06:27 PM   #1
dompower
dompower's Avatar
Drives: BRZ sportech
How to: Brembo STi 08+ (black) on a BRZ 2013
Donnor car: STI 2010
Receiver car: BRZ 2013
Needed pieces:
-Front Caliper STi 2010 X2
-Rear Caliper STi 2010 X2
-Front Backplate STi 2010 x2
-SS braided brake hose (Can used the rubber one, from the BRZ or STI)
-Rotor and pads STi 2010
-Caliper bolt STi 2010
-Spacer 3/4" for the front X2
First of all, rotor have been redrill to 5x100
It's a straight bolt on mods! It took me 4h to do it, taking my time, drinking a beer.. no rush
BRZ OEM front brake
BRZ OEM rear Brake
We got to modify the front back plate. drill a new hole for the center bolt and re-work the outside shape of the 2010 STI
BRZ front backplate
STi Backplate
Front Rotor size difference:
Rear Rotor: E-brake is EXACTLY the same!! I don't even had to adjust it!!
We got to trim the BRZ backplate around the caliper bolt and the outside part
that interfer with the bigger rotor.
Rear Rotor size difference
WE got to install it with the caliper's specific bolt. Bleed it, with both bleeder. they have to be on the TOP of your caliper, not pointing down. I had to add 3/4" spacer to clear my wheels
The braking feeling is smooth on the pedal, but If I need to, it's completely insane! It feels and look like if it was like this from the factory. I love it!
Dom
dompower is offline   Reply With Quote
The Following 4 Users Say Thank You to dompower For This Useful Post:
AbsolutKev86 (04-07-2013), Choco (01-21-2015), slava (10-08-2014), whataboutbob (04-10-2013)
Old 04-08-2013, 10:18 PM   #2
charged86
charged86's Avatar
Needed pieces:
-Front Galiper STi 2010 X2
-Rear Galiper STi 2010 X2
-Galiper bolt STi 2010
BRZ OEM front brake
BRZ OEM rear Brake
BRZ front backplate
STi Backplate
We got to trim the BRZ backplate around the galiper bolt and the outside part
WE got to install it with the galiper's specific bolt. Bleed it, with both bleeder. they have to be on the TOP of your galiper, not pointing down. I had to add 3/4" spacer to clear my wheels
Dom
What do you mean center bolt? Do you mean the hub bearing hole?
Old 04-09-2013, 10:34 AM   #3
dompower
dompower's Avatar
you see the smaller hole, over my thumb, at rigth? near the hub
we have to drill a hole there.
The Following User Says Thank You to dompower For This Useful Post:
charged86 (04-09-2013)
Old 04-09-2013, 11:24 AM   #4
infinite012
Drives: 13 DGM BRZ Ltd
What
Did you really have to quote all the pictures?
Anyways, cool thread, but I thought we already had one of these? And it's spelled caliper, not galiper.
infinite012 is offline   Reply With Quote
Old 04-09-2013, 01:26 PM   #5
dompower
dompower's Avatar
lolllll thanks! in french it's galiper .. I think..
Old 04-09-2013, 02:00 PM   #6
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Needed pieces:
BRZ OEM front brake
Dom
havent noticed, did you switch the front calipers left to right or not (also switching the bleeder position) ?
the braking pistons size are different top to botom...
if not - they aren't working as engineered
MSTiFK8R is offline   Reply With Quote
The Following User Says Thank You to MSTiFK8R For This Useful Post:
dompower (04-10-2013)
Old 04-09-2013, 04:11 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I was going to ask the same thing. Did you swap the plugs and bleeders on your front calipers? Interesting idea reusing the front STI backing plate as well. I guess I am not the only BRZ running this full set of calipers now.
Old 04-10-2013, 06:00 PM   #8
dompower
dompower's Avatar
mmm... interesting.... I didn't change the bleeder position... that's maybe why they are very noisy.....
I tought It was the same thing.. I've buy it unmounted....
Old 04-11-2013, 10:21 AM   #9
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
if the bleeders are still at the top - then the pistons are mixed up top to bottom
you will face VERY uneven pad wear and low efficiency braking
swap the fronts left to right so the bleeders are on bottom, then change the upper plugs to bleeders
voila !
now the enginnering is as planned
see the bore piston difference? because racecar and because STI have the calipers in the wheelbase, while brz have them in front of the wheel
dompower (04-11-2013)
Old 04-11-2013, 01:10 PM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
What
You fail at quoting
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
dompower (04-11-2013), Mr.Jay (04-11-2013)
Old 12-23-2013, 10:28 AM   #11
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I am interested in the Backplate installation. So the rear we do not have to change right? For the front, drill and install? Thank you.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-23-2013, 12:17 PM   #12
OrbitalEllipses
Drives: Attitude
Okay...it's not a backplate. That's not the correct terminology I don't believe - the item you and the OP are talking about is a rotor dust shield. It is commonly removed during big brake swaps and never put back on. I ran my WRX without a dust shield for the better part of 5 years and had NO issues. Don't worry about the dust shield bro, it's not necessary.
voila !
Keep the front calipers on the same side they came on originally. This ensures the pistons are in the proper positions (direction of rotation hasn't changed, so the leading piston is still leading). This WILL require swapping the bleeder plugs from one side of the caliper to the other.
Obviously an old post, but still worth giving the right information.
Old 12-23-2013, 01:50 PM   #13
Figo
Figo's Avatar
Thank you man. I know it is not necessary; however, will there be a lot of brake dust on you rim when you run a BBK without dust shield? That will be hard to clean and a shield might make life easier.
Old 12-23-2013, 02:15 PM   #14
OrbitalEllipses
Drives: Attitude
Cleaning wheels > wasting time fitting a dust shield, IMO.
My wheel barrels get caked in dust anyway just due to the aggressive compounds, so it doesn't do anything for me.
Brembo Big Brake Kits - Black Friday Specials!! vividracing Brakes, Suspension, Chassis 16 01-03-2013 07:26 PM
2013 BRZ Limited (black) Epictetus Cars for Sale/Trade 2 11-14-2012 11:38 AM
Latest pic of the 2013 Black BRZ I did a few days ago ReflectiveAuto Northwest 7 10-22-2012 02:03 PM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 08:03 PM
