Old 04-06-2013, 10:56 PM   #603
xcelir8brz
Drives: 2013 BRZ Limited
An E85 Flex kit (note, either E85 or 93) takes time to develop. It's not just an E85 tune. It's a flex kit to switch back/forth.
xcelir8brz is offline   Reply With Quote
Old 04-07-2013, 01:58 AM   #604
ScionFrsFan
But still there will be a simple e85 tune...that might be done? Who knows how long they been working on this?
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 04-07-2013, 03:42 PM   #605
xcelir8brz
Chill Out on the E85.
Old 04-07-2013, 04:22 PM   #606
ScionFrsFan
I'm just asking questions.
ScionFrsFan
Old 04-07-2013, 04:51 PM   #607
bakerr6
Drives: 2013 raven black fr-s
Well justa little update...
I have not contacted TiC yet, but I'm almost certain they do not normally tune with unichip. I will need to contact Jack later this week because I cannot log in to access the maps anymore (was able to the first week or so) and would like to take a look at the additional maps and compare them to what I currently have.
I will also be contacting him to see about possibly getting set up for launch control and also purchasing the nitrous controller to run nitrous for now, and possibly switch it over to meth injection if I end up using it when I go with a turbo later this year.
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
ScionFrsFan (04-07-2013)
Old 04-07-2013, 06:47 PM   #608
mrk1
Drives: Sterling BRZ Ltd
Can a Unichip be purchased preloaded with a selected tune? I'm a Mac user, and don't plan on fiddling with it to much.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-07-2013, 08:04 PM   #609
Mike86
Drives: Scion frs
yup! you select the map you want when puchasing the unichip
Mike86 is offline   Reply With Quote
Old 04-07-2013, 09:05 PM   #610
ScionFrsFan
Like he said, you can....but its pretty cool to tweak with diff tunes yourself.
ScionFrsFan
Old 04-07-2013, 09:12 PM   #611
mrk1
Got my fill of that with my last sti, just looking to drive this car.
The Build Thread
Old 04-08-2013, 08:33 AM   #612
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I thought I'd contribute to this thread by posting our dyno results today
Here's my run.
Blue line is my baseline run, Milltek full exhaust including overpipe and cat-delete front pipe, stock ecu, stock intake with the snorkel delete (I didn't want to remove the bumper to reinstall the snorkel just for this). Pulled 152.05whp and 127.76tq, best run out of three.
Red line is with the Afe Takeda dry intake, Milltek full exhaust, Unichip EMS running 92 octane Fuel Standard, Timing Standard, Takeda, AllCatB map. Runs conducted on the same day. Best pull was 161.93whp and 134.78tq.
Here's the AFR with the Unichip and Takeda intake, this wasn't the best pull
Compared to stock ecu and stock intake AFR
These runs were on a Dynojet, on a very hot summer day, about 36-37C ambient temp, with the hood up. I would assume this was an advantage for the stock intake because without the snorkel, it was taking in fresh air from the fan. The Takeda's velocity stack leaves no gap, so it's not able to suck in any air from the fan.
And here's the run of my friend's car. His car is also MT like mine, same 100RON octane fuel, around 5,000km on the odo with an oil change recently (my odo is 3,100km and oil was changed at 1,300km) has the same Milltek full exhaust, but with Injen intake and Ecutek tuning. Best pull was 157.31whp and 134.29tq. Again, this was with the hood up, with the Injen taking in fresh air from the fan
HRTROB is offline   Reply With Quote
The Following 6 Users Say Thank You to HRTROB For This Useful Post:
Anthonytpt (04-08-2013), l0aded (04-08-2013), Mike86 (04-12-2013), ScionFrsFan (04-08-2013), swift996 (04-08-2013), Wigmasterflex (04-08-2013)
Old 04-08-2013, 01:13 PM   #613
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Jack,
Any comments/input on the dyno sheets I posted above? Looks like the car is running rich with the Unichip and intake. This was with the 92 octane fel standard, timing standard, takeda, allcatB map. Should I try fuel out, timing standard or fuel out, timing in?
Old 04-08-2013, 01:45 PM   #614
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by HRTROB View Post
^Nice bunch of cars there! Any more pics/info on that 65/66 Fastback?
Unichip Jack - I couldn't get the vehicle filter to work on your site, but do you guys make a chip for the fox-body Mustangs? Like the 89-93 5.0L, or maybe an Explorer with the same engine. I'm considering using one of these in my '67 and looking into what types of engine control are available since I'm mostly familiar with Subie stuff.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 04-08-2013, 06:39 PM   #615
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Here's my run.
Thanks for doing this, one of the only dynos of the Unichip to date and useful even without a stock comparison. Interesting data extrapolated from this although most numbers are close enough to maybe considered negligable. 100RON = 100 octane in (R+M)/2 method correct? With high ambient temperatures and fan cooling the Injen probably performs worse because of its design but the data gives me confidence in the Unichip tuning route.
Jack,
edit: read wrong lol
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 04-08-2013, 06:50 PM   #616
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
2point0… I’ll pm you since it’s a bit off topic… short answer is yes.
HRTROD… nice post. I second 2point0, nice group of cars. I’m always a bit reluctant to comment on dyno stuff I wasn’t present for because there are so many variables. That said…
I wouldn’t sweat the AFR much because of the high ambient temperature... especially if you don't have repeatable runs. Typical “target” AFR numbers are for conditions close to SAE/JAE/DIN standard day conditions which are significantly lower. As the IAT rises, the ECU adds fuel to cool the combustion chamber… (richer = cooler, leaner = hotter). As the mixture gets richer, you’ll lose a little power BUT THAT'S GOOD. Heat = power = reduced component life… it’s one of the major reasons race engines don’t last.
A better test would be on the road with a mobile wide band early in the day when the temperatures are better. If you still see those sort of numbers, I’d try a fuel out map… but I think you see them a little leaner when it’s cooler.
With 100 RON, I'd certainly try Timing + to see what the car thinks. Pretty simple test, if the car is slower or gets a flashing CEL for a misfire, go back to the Timing ~ map. If the car is quicker and feels good, stick with the Timing + map. If you don’t feel/see any difference, I’d run the (more conservative) Timing ~ map.
Cheers
Unichip Jack is offline   Reply With Quote
The Following 2 Users Say Thank You to Unichip Jack For This Useful Post:
2point0 (04-08-2013), HRTROB (04-09-2013)
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
