Old 04-02-2013, 10:10 AM   #71
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by tom@kartboy View Post
In the works right now. signing off in injection mold tooling shortly.
any news pls?
I was about to purchase the kit, but adding these would be awesome
MSTiFK8R is offline   Reply With Quote
Old 04-02-2013, 12:39 PM   #72
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
Originally Posted by MSTiFK8R View Post
any news pls?
Order the kit now. it will be a few weeks minimum. I'll take care of you.
Tom
tom@kartboy is offline   Reply With Quote
Old 04-03-2013, 11:47 AM   #73
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Anyone install the insert? curious as to how much work it takes to just get to that part and what difference it may have made
abutterman is offline   Reply With Quote
Old 04-03-2013, 11:49 AM   #74
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I hate tooting my own horn, but this should give you an idea:
http://www.ft86club.com/forums/showt...ghlight=perrin
You can do this on jackstands. It isn't a hard install. We mentioned you can see the rear shifter insert from inside the car when you have everything apart.
F1point4 is offline   Reply With Quote
Old 04-03-2013, 12:30 PM   #75
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Just installed mine the other day. The install went extremely well - I also attempted to pull the rubber off the linkage from the transmission end rather than the small hole at the top where the actual shifter goes - woops. After going at it the right way it came right down and was easy to pull out of the way.
Does anyone know what the allen head screw is from on the top of the shifter (where you put the knob on)?
rmjjensen is offline   Reply With Quote
Old 04-03-2013, 07:33 PM   #76
edward
edward's Avatar
Drives: 2013 BRZ - Sterling Silver Metallic
Wow. Excellent DIY guide. Thank you.
edward is offline   Reply With Quote
Old 04-03-2013, 11:49 PM   #77
Alabang 86
Alabang 86's Avatar
Drives: GT86
nice ! ! ! ! mine shipped last week looking forward to this install !
...my turn...
Alabang 86 is offline   Reply With Quote
Old 04-03-2013, 11:52 PM   #78
tom@kartboy
Its a set screw to hold the internal spring in compression. Its all part of our patent on the shifter.
Tom
Old 04-04-2013, 03:03 AM   #79
Alabang 86
Alabang 86's Avatar
Drives: GT86
Originally Posted by chenshuo View Post
OP, you have some serious photographing skills!
+1
what's ur camera setup?
...my turn...
Old 04-04-2013, 11:27 AM   #80
F1point4
Photo Specialist
F1point4's Avatar
Originally Posted by Alabang 86 View Post
+1
For cars I mostly use
Olympus OM-D
Olympus 12mm F/2.0
I also have a
Panasonic DG Summilux 25mm 1.4
Olympus 75mm F/1.8
Olympus FL-500R flash
Old 04-04-2013, 05:51 PM   #81
zooki
Drives: waiting on a 2021...
Thanks for the write up. I managed to get my shifter installed with a minimum of problems. I did manage to tear the dust boot that covers the linkage, but I think it'll be OK.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-07-2013, 12:28 PM   #82
SilentMike
Drives: 2013 FR-S 6MT Asphalt
I installed my short shifter two weeks ago tomorrow. The install went fine and the shifter has functioned and felt great, with no audible vibrations.
I got around to installing the rear bushing yesterday. I did it with a set of Rhino ramps and wheel chocks. It took me an hour or so. I suspect it would have gone easier and faster had I access to a lift or a jack that could raise the car higher for support on jack stands. The limited amount of room under the car combined with the cramped quarters around the bushing (due to the close proximity to the exhaust and drive shaft) made it a challenge to get the bolts holding the OEM bushing out and the replacement bolts for the KB bushing back in and torqued. The bushing helped crisp up the shift feel.
All in all, I'm extremely pleased with the KartBoy short shifter and rear bushing for the twins.
SilentMike
SilentMike is offline   Reply With Quote
Old 04-13-2013, 06:51 PM   #83
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Installed mine today. This DIY is spot on. Went in flawlessly. Thanks to the OP.
Just took it for a spin around the block. Shifts are much more precise and I think it helped with second gear. Always has been a bit notchy.
Little more drive time. Has helped with the 1-2 shift. Little more effort required to change the gears. Overall I love it.
Edit #2 : After a couple weeks with the shifter now.... getting a audible rattle/buzz higher rpm in 2nd.
FRSFirestorm is offline   Reply With Quote
Old 04-14-2013, 06:42 PM   #84
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Tom
Ordered via RSD ) wohoo!
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 09:19 PM
Kartboy Short Throw Shifter!! RallySport Direct Transmission and Driveline 16 04-18-2013 02:18 PM
Kartboy Short Throw Shifter!! RallySport Direct Announcements, Contests, Giveaways 34 03-18-2013 03:18 PM
