alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 04-03-2013, 11:41 AM   #141
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I broke one the passenger side clear side marker metal pin. (I knew it was bound to happen). I drilled a hole through the pin area and held it with a tie-wrap. It pokes out a little bit but at least I know its not going anywhere.
Oh, and I did something stupid (and minor) during the install, I removed the ambien temperature sensor for the digital dash display. I'm trying to figure out how to re-insert it without removing the bumper.
I didn't brake any of the metal pins, but I did have to reinstall the metal pins in the side marker and mess with them a couple times. They definitely don't like coming out very many times, and I am not sure they could have come up with a worse way to mount those things.
Where is that sensor located? I have noticed since my turbo kit install that it seems to read quite a bit higher until I get some good airflow going. It definitely doesn't seem to be as accurate as the one in my Toyota Tundra which I'm sure uses the same part number.
Old 04-03-2013, 11:46 AM   #142
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yeah, I honestly think its the worst designed part of the car. They are just bound to break if you remove them a couple of times. On the driver's side, the clip came out and I was able to re-insert it. On the passenger side, it doesn't want to hold in anymore.
The sensor is located right in front of the AC condenser in the passenger side. It will now sit between the condenser and the IC, that is why you now get higher readings.
Old 04-03-2013, 10:13 PM   #143
Sportsguy83
Drives: Limited BRZ
Took it out for a spin around the block today. There is some oil being burned by the exhuast area. I quadruple checked if it was the turbo oil pump, but it is clean. I am guessing its some old oil spilled while installing the pump.
Couldn't step too much in it since I still don't have the appropriate map for it. It does felt nice at around 4-5K RPM's at 5 psi. Didn't go any farther than that and did it only twice.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (04-03-2013)
Old 04-03-2013, 10:15 PM   #144
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Wuts ur max psi?
lbroskee is offline   Reply With Quote
Old 04-03-2013, 10:16 PM   #145
Sportsguy83
Drives: Limited BRZ
Originally Posted by lbroskee View Post
Wuts ur max psi?
Right now 7, theoretically 14.
Old 04-03-2013, 10:21 PM   #146
lbroskee
lbroskee's Avatar
Y theoretical? And u got reg or 4bar sensor?
Old 04-03-2013, 10:21 PM   #147
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Awesome, cant wait for your driving impressions once you get the tune file
Right now I'm too tempted to buy the kit!! XD
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Sportsguy83 (04-03-2013)
Old 04-03-2013, 10:22 PM   #148
Sportsguy83
Drives: Limited BRZ
theoretical because I have the fuel and adjustable boost controller to go up to 14 psi. 3 bar sensor.
Old 04-04-2013, 08:58 AM   #149
Cheddar
Saving them pennies...
I see some joy rides being giving at the next meet for $5 a pop.
Cheddar is offline   Reply With Quote
Old 04-04-2013, 09:53 AM   #150
Sportsguy83
Drives: Limited BRZ
Too low!!
Old 04-04-2013, 09:57 AM   #151
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Too low!!
Trade ya?
Huehuecoyotl is offline   Reply With Quote
Old 04-04-2013, 09:57 AM   #152
Sportsguy83
Drives: Limited BRZ
Originally Posted by Huehuecoyotl View Post
Trade ya?
Any day!! I honestly would love to drive a SC 86.
Old 04-04-2013, 03:35 PM   #153
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Congrats, the BRZ sounds awesome! Any plans for a dyno field trip?
TRD_07 is offline   Reply With Quote
Old 04-04-2013, 03:44 PM   #154
ftc~brz
Done
Drives: WRB BRZ
Car is finally on the floor again!!
did that stork in the back ground deliver your brz?
ftc~brz is offline   Reply With Quote
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
