Old 11-17-2011, 02:06 PM   #155
madfast
Drives: 2010 Evo X MR-T
Originally Posted by arghx7 View Post
ding ding ding
direct injection is a lot more sensitive to the shape of the piston crown because mixture formation is very different than on a port injected engine.
only for stratified charge, no? for regular DI on the intake stroke, wouldnt the shape of the ports would be more important than the piston?
madfast is offline   Reply With Quote
Old 11-17-2011, 02:08 PM   #156
serialk11r
Drives: '06 AM V8V Coupe
That's true, but I don't think the information on D4-S is consistent enough to say what actually happens. I've read all the "official" articles on it several times and I am still confused as to how the direct/port injectors are operated.
Old 11-17-2011, 02:41 PM   #157
Allch Chcar
Drives: N/A
ding ding ding
I got nothing. What you said it true.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-17-2011, 09:58 PM   #158
arghx7
Drives: car
"Developed spray" is that pattern used in the 2GR-FSE of the IS350, which utilizes the D-4S (GDI + PFI) system like on the new FA engine.
Old 11-28-2011, 04:03 PM   #159
dcaff
Drives: Toyota Tacoma X-Runner
Lol. I just hope that TRD will make a Turbo or Supercharger kit for this car. 12.5 is sky high. But TRD makes the Supercharger for the 1GR-FE in my truck and compression is a decent 10.1. Its a 60hp gain (crank) from stock. 239 to 304hp.
Imagine how much money Toyota would make if they offered a S/C kit that brings power from 200 to 260 or 280hp! Did i mention when installed at a dealer the S/C , motor and everything else are covered under warranty!
dcaff is offline   Reply With Quote
Old 11-29-2011, 03:12 AM   #160
serialk11r
Imagine how the world would be if everyone read the news and knew, for example, how Toyota said there would be no forced induction for this car, ever. What a thought.
lol sorry didn't meant to be a ****, but too many people make annoying posts like that.
Old 11-29-2011, 06:39 AM   #161
Levi
Drives: Toyota
There should not be any problem for supercharging this engine. The BMW M3 E9X runs over 600 PS with supercharger (G-Power, ESS-Tuning, Active Autowerke,...) and has a compression ratio 12.0:1.
Levi is offline   Reply With Quote
Old 11-29-2011, 11:48 AM   #162
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
That's not a terribly relevant "if...then" comparison. We have no idea how fragile or strong the FA20 is. We can run some calculator numbers and make educated guesses what the typical safe boost level limit is, however that makes no regard for actual individual component strength, which is very much decided on a per-engine design basis. Saying "just cuz BMW can do it" has no bearing on if this particular engine can. Only time and experimentation [or very advanced simulation] will tell.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-29-2011, 01:05 PM   #163
Allch Chcar
Drives: N/A
Originally Posted by Driftster View Post
I giggle at these threads, no more than 5 maybe 6 months ago I was in here saying this cars boost potential will be all but non existent, the direct injection and it's application will be the limiting factor, because with direct injection comes higher compression for fuel economy........ And what were the responses I got?
"you don't know what you're talking about"
"Toyota would never produce a car that was this focused on the tuner market that couldn't be boosted"
"You're an idiot"
"get out of here troll"
"Direct injection has nothing to do with how the engine works"
...Hah....Good job...
It still remains to be seen.
Because the common belief is that you can never have enough power?
It's usually not just the structural strength nearly as much as the propensity for detonation. From my understanding that is, detonation is far more dangerous and damaging than incrementally higher cylinder pressures. Eg. If you take a high compression engine and run race grade fuel you can usually run more boost safer unless there is a significant weak point.
I'm not trying to come across like I know what I am talking about so please excuse my inexperience.
-Allch Chcar
Old 11-29-2011, 04:25 PM   #164
serialk11r
Nah the point is there are too many people talking about factory supercharging options when it's been said over and over that it wouldn't happen.
Old 11-29-2011, 04:34 PM   #165
Ryephile
Hot Dog
Ryephile's Avatar
Yes, of course. I was oversimplifying. Total quench (mechanical + chemical) fuel type, component strength, knock sensor, and ECU strategy all play their part in detonation prevention and resistance.
Old 11-29-2011, 06:22 PM   #166
madfast
they said no turbo. nothing about superchargers. personally i doubt it would happen, but you never know...
Old 11-30-2011, 01:25 AM   #167
Allch Chcar
Drives: N/A
I was just elaborating.
I never tire of posting my turborat w/ wings.
-Allch Chcar
Old 11-30-2011, 02:26 AM   #168
jdhariwal
Toyota CEO
Drives: 1996 240sx
During the opening speech at Fuji Speedway, they said that the engineers had traveled all over the country attending grassroot drift and track events, to see what the enthusiasts and purists wanted. I'm sure that a turbo kit will be available within months of its release. People are already taking about building a drift car out of it, so theirs no way Toyota and Subaru would limit us to a motor like this, seeing as pro drift cars are 400+hp.
jdhariwal is offline   Reply With Quote
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 09:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 10:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 05:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 10:46 PM
