#57 | |
![]() Does not matter if you replace it with a high-flow cat. It must be broken/ and or out of warranty to be legal to replace. I am guessing you would not fail an emissions test unless they knew what to look for. I mean headers are headers. |
#58 | |
Drives: 2013 Asphalt FRS
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#59 | |
| The Following User Says Thank You to reeves For This Useful Post: | NickFRS (03-26-2013) |
#60 |
What if you could somehow fabricate something that looked like the stock heat shields to cover up your hi-flo cat? I noticed both of them are covered up that way. Not sure how closely they examine your cats, but just an idea.
#61 |
Drives: Scion FR-S
Is the main advantage for the header the removal of the torque dip? Aren't there cars with e85 tunes and header back exhausts making very similar power pre and post torque dip.?
Sent from my Galaxy Nexus using Tapatalk 2 |
#62 |
I would think that's the case.. I've seen those cars/dynos that you're talking about.. seems the one thing they all were missing was headers. But I shouldn't speculate because I'm no expert.. any combination of mods could affect the torque curve differently.. I'm just glad it worked out for me on my first attempt.
#63 | |
Drives: Scion FR-S
#64 |
Drives: Scion FR-S
Does the factory aluminum skid plate fit with the header installed?
#65 |
Is a tune required with this header? I have Visconti stage 1, im very interested in these long tube headers. It seems like everyone is jumping on this after Nameless posted their results. I know FA20 club tuned a set of P&L long tube headers, are these the same(they sure look the same)?
#66 | |
Mid-range was what I was targeting as well.. I don't redline my car too often, but I drive in the 3-5K rpm quite a bit, as I'm sure alot of other people do.. I don't see how you can go wrong with these headers for the mid-range pull. ![]() I'm still curious how a better flowing cat-back will affect the torque curve, if it does at all.. but I'm not going to be the one to find that out.. I'm satisfied with the power (and sound) I get from my stock exhaust with these mods. |
| The Following User Says Thank You to reeves For This Useful Post: | vtmike (03-26-2013) |
#67 | |
#68 |
Drives: 2013 White Out FR-S
The header gives an all around completely different power band. while you can almost flatline the tq dip without the header; it seems the header creates more along the lines as a significant bump in tq throughout the same range. the car breaks loose now anytime you stomp the pedal even while cruise down the road in 2nd & 3rd gear from the bump in midrange tq.
| The Following User Says Thank You to FA20Club.com For This Useful Post: | tripjammer (03-27-2013) |
#69 | |
#70 | |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
| Tags |
| header, turbo manifold |
| Visconti vs FA20Club vs Stock Tune Dyno Results | mechaghost | Engine, Exhaust, Transmission | 153 | 07-08-2013 11:35 AM |
| FA20CLUB V2 Turbo Kit Progress | FA20Club.com | Forced Induction | 40 | 05-17-2013 01:26 PM |
| FA20CLUB Power Pack #1 Tested | FA20Club.com | Engine, Exhaust, Transmission | 31 | 01-16-2013 03:32 PM |
| Borla cat-back w/ UEL header tested at the track | BeltedBiscuit | Engine, Exhaust, Transmission | 17 | 12-30-2012 02:57 AM |
| Turbo FR-S Tested For Drift Reportedly Spotted | DanPO | Scion FR-S / Toyota 86 GT86 General Forum | 123 | 01-24-2012 01:25 AM |
