#43 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
I would say its more rifle bolt action like than stock yes. It doesn't take muscle to shift. When you do shift its very satisfying. makes you want to say stuff like "Engage second gear!" then shift.
| The Following User Says Thank You to F1point4 For This Useful Post: | burnt toast (03-20-2013) |
#44 | |
Drives: Attitude
#46 |
Drives: 2013 SWP BRZ
Just did this install today. F1 is correct, the dust boot is a bit of a pain in the ass to get off. Other than that, pretty simple install. Be careful with the boot, I put a slight tear in it because I pulled too hard.
Oh, the grease kartboy supplies is sticky and annoying and it webs when you try to stop the flow of grease.I had a "white" ring around the top of my reverse lockout - if you have this issue just hit it with some swirl remover. If that doesn't take it off westand with 2000 grit and then polish (what I did). Haven't driven the car but I'm very happy with the throw and placement of the shifter. I have the Carsmo armrest, and now the shifter sits PERFECT when your arm is resting on it for shifts. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | F1point4 (03-20-2013) |
#47 | |
Photo Specialist
Too busy to try to remove it right now. Borla header incoming.
#48 | |
![]() Can't wait for your writeup and review on the Borla header. One of the many I have my eyes on... can't make my mind up haha. All I know is I want a UEL header. Just worried about making it too loud. |
#49 |
Drives: BRZ WRB
you lit a fire, ordering mine )
| The Following User Says Thank You to MSTiFK8R For This Useful Post: | F1point4 (03-26-2013) |
#50 |
Drives: whiteout
Yes, because of this thread I ordered this shifter.
Shifter installed, feels good. Install was slightly time consuming and the boot was a slight pain, but not near as bad as other things ive done to cars in the past. Took like five attempts to get the boot off, no tears. I used a flat piece of metal with a crowbar-type bend at the end of it to help get the boot off. Getting it back on took one attempt. Easy peasy. There was a rattle from my stock shift knob near redline- easily remedied with teflon tape on shifter threads where the shift knob screws on. Now to figure out where ill be able to find a lift for the bushing.... |
| The Following User Says Thank You to burnt toast For This Useful Post: | F1point4 (03-26-2013) |
#51 |
Drives: FR-S :)
Thanks to F1point4 i was able to install this without an issues. The only thing left shifter bushing and trans mount insert...
but so far shifting feels great! also got myself a flossy shift knob to go along with the kart boy short shifter, for even a better feel
| The Following User Says Thank You to p00mba For This Useful Post: | F1point4 (03-26-2013) |
#52 |
I had a hard time getting the shift boot off because even though I was referencing this thread, I looked too quick at the photo of the boot removal and ended up pulling it back from the front, not that top hole
I don't even know how I attempted to stretch it that far. Just figured i'd note that, make sure you stretch the boot down from the top opening where the shifter passes through, not the linkage!
| The Following 3 Users Say Thank You to xxscaxx For This Useful Post: |
#53 |
Drives: Attitude
EASILY doable on the ground, follow F1point4's guide to doing the Perrin bushing. I found it easier to drop the front pipe (I was doing a front pipe install at the same time anyway) because that gave me room to get a socket w/ extension in there easily.
#54 |
Drives: Asphalt FRS <3
Very detailed might pick one up!
#55 | |
Photo Specialist
Sorry I didn't think to share this before.
| The Following User Says Thank You to F1point4 For This Useful Post: | JPxM0Dz (03-26-2013) |
#56 |
Drives: Attitude
It IS possible from inside of the car, but you're going to want flex sockets, etc. to make it easier.
| STI Short Shifter Kit | Hanakuso | Engine, Exhaust, Transmission | 37 | 01-18-2016 09:19 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Transmission and Driveline | 16 | 04-18-2013 02:18 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Announcements, Contests, Giveaways | 34 | 03-18-2013 03:18 PM |
