#43 | |
Make love
Drives: H8R.. Not really
#44 |
Drives: Many types of cars in R&D.
Engineers for multi-billion dollar car firm as to pursue a perfect car, though that there is no such thing. And traditionally pleasing everyone must contain sacrifices.
However, let's just say that in case of the FT86, the engineers and the president of the firm both were 'passionate' and that resulted in a car that didn't please everyone, but a select few percent that really appreciate this sort of car. It's a rare occurrence in a company like Subaru and more so for Toyota... I just feel lucky to be even be allowed such regular communication channels where we as fans here, can collectively voice things and actually get a response on a personal level as I can to Tada-san, with your opinions and thoughts intact, and even suggest that I should report back to all of you like this. Let's keep this channel open, with constructive thoughts and courtesy, yes?
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. |
| The Following 15 Users Say Thank You to Moto-P For This Useful Post: | chanomatik (02-10-2015), danthedirt (03-25-2013), demonpoofball (02-05-2015), Fly Guy (04-24-2013), ichitaka05 (03-25-2013), i_giado (03-25-2013), JoeC (08-08-2014), Nardi330 (03-27-2013), Purdue FR-S (04-03-2013), racecaresuaceb (03-25-2013), stock (04-05-2014), tech4pdx (03-25-2013), Theognosis (03-29-2013), twag4 (03-28-2014), Walldodger (03-27-2013) |
#45 | |
Make love
#46 | |
Drives: car
My shifter requires more throw force than I'd like, going 1st to 2nd to 3rd is too notchy, where it used to feel sweet and smooth; seamless; it's notchy, clicks into place. I'm at 5000 miles. However, my friend at 18,000 miles in his FR-S has the smoothest action on his stick shifter. He hasn't changed the trans fluid. Most 86's I've seen have a clicky, notchy feel; But a few I've seen have smooth buttery action. What might the case be for causing the difference in feel?. Is there some maintenance that I could perform to fix this, perhaps the linkage or fluids? I'm bringing the issue to my dealership, and I'd like any researched opinions from the engineers on how to make the shift feel better, like it was new. Last edited by radroach; 03-25-2013 at 07:22 PM. |
#47 | |
And many are being resolved. Select "Limited" grade appointment list of toys, were approved for certain very limited run for Scion to be released this year in the USA. And rattling dash, like the foggy tail-lamps are being drilled for causes at production line and at the suppliers manufacturing tolerances and materials. Torsen is as far as Toyota corporate wants to take, since any stiffer will make more noises and increased tire wear more than Toyota would like as a commonly available street car (so we can just resort to 4 pinion mechanical LSD if we want more from myriads of LSD makers). Now your thing about the Traction Control and VSC lamps, there's actually 4 different combinations of VSC/TRC modes and combination of lamps indicate which mode it is on, so that really shouldn't be erased I think....LOL! AS for the TPS monitor lamp, that's a DOT thing that US government pressed upon all car makers, so my answer was to put a dash cluster overlay, and just stuck a black decal between it so I can't see the thing blinking. Maybe you can take the same approach. ![]() ![]() Like this. Not to plug our own Club4AG gear line but for mere answer to any dash lamps that annoy you.
Moto Miwa
#48 |
I've also asked them (the Team86) about making a new cluster maybe, that deletes the needle dial speedometer (which is redundant for cars with digital speedometer) and using that space for oil temp/presure dials, and releasing it as TRD option replacement. They LOVE the idea, but at the same time, the tricky part is that such replacement of entire cluster in the USA, will put a 'red flag' in the vehicle registration tag since odometer would have to be replaced in the process.
But I'd do it for one!!! (OK going off in to a tangent off the original topic. So I'll stop)
Moto Miwa
| The Following 7 Users Say Thank You to Moto-P For This Useful Post: | Bristecom (03-25-2013), civicdrivr (03-26-2013), Fish (04-06-2013), Fly Guy (04-24-2013), ichitaka05 (03-25-2013), Ingen (03-25-2013), tech4pdx (03-25-2013) |
#49 | |
Site Moderator
Drives: ichi 86 Project
#50 | |
Drives: 2017 Subaru BRZ PP
Toyota + Subaru =
#51 | |
Site Moderator
Moto-san told me about this to persuade me to buy FR-S ![]() Anyways, back on topic, Thank you for the information Moto-san. |
#52 |
Drives: 2013 Subaru BRZ LTD
Thanks for sharing the feedback Moto-P.
Honestly, the second gear is not too big an issue for me because it goes away after just 5 minutes. I actually like driving this car in the cold because the shifts are chunkier and go ka-chunk ka-chunk between the gates probably because the transmission fluid is still thick. |
#53 |
I appreciate the fact that there is a line of communication open about issues with the car.
It would be nice if they offered a solution "AKA different trans fluid" for the cold climate users. Because lets face it whatever the excuse in regards to the trans, I don't like grinding gears, having difficulty engaging gears and skipping gears while I wait 10 minutes for the trans to heat up. It's a street car. I was one of those who first swapped fluids and it helped, but does not fix the issues. Basically I don't like having to find a remedy for something the engineers should have accounted for in cold weather testing. It's unfair to expect your customers to be ok with it. That's really the point.
| The Following User Says Thank You to Dezoris For This Useful Post: | radroach (03-26-2013) |
#54 |
Drives: Raven FR-S
Yes, I think my only complaint of ergonomics & interior is the useless analog speedo and lack of auxiliary gauges! Shifting a fine for me but it doesn't get cold here.
#55 |
Road Warrior
Drives: AE86 Levin
Both my ae86's have this too. Second gear is a bitch to shift in, it's fine when the car is warmed up.
Because racecar
#56 | |
Drives: 2018 Golf R
Re: Second Gear - It doesnt bother me. I don't drive the car hard until its up to temp, and by the time I get to the main road, its already warm enough for the shift to be smoother. Every single one of my cars have had this issue when cold, and those were far from track inspired street cars.
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | Bristecom (03-27-2013) |
| New manual driver - SPEED BUMPS! | eifer | Engine, Exhaust, Transmission | 47 | 06-16-2015 01:27 PM |
| FS: Toyota 86 GT! 6 Speed Manual ! Black ! [VIC] | os86 | Australia Classifieds | 0 | 12-19-2012 05:01 AM |
| Whiteout 6 speed manual (Raleigh, NC) | low trq | Southeast | 3 | 10-29-2012 03:57 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 02:22 PM |
| Another reason to buy a manual transmission car... | xantonin | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 08-10-2011 11:30 AM |
