Old 03-25-2013, 08:23 AM   #1
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Exclamation normal mode/vsc sport/trc off
Explain with your own words what do you feel when you drive the 3 different modes for the gt86. When and where do you prefer to drive like that? Which is your favorite mode? Any nice experience to tell?
Toyota GT 86 is offline   Reply With Quote
Old 03-25-2013, 12:33 PM   #2
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
All three are just tolerance levels before the traction system kicks for what ever you are doing. Even when traction is off it is still affected by the traction system. If I want to turn it off I do the pedal dance.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-25-2013, 12:49 PM   #3
boead
boead's Avatar
pedal dance?
boead is offline   Reply With Quote
Old 03-25-2013, 12:54 PM   #4
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Originally Posted by boead View Post
pedal dance?
There's a thread that talks about a complicated sequence of pushing pedals and engaging and disengaging the parking brake that will actually properly defeat the electronic aids. Can't remember the specifics but when I'm at home and have more time I'll try and find it and link to it if someone doesn't beat me to it.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 03-25-2013, 01:06 PM   #5
WolfsFang
Scrape Master
WolfsFang's Avatar
pedal dance?
Sorry was away from home
http://www.ft86club.com/forums/showthread.php?t=25494
Old 03-25-2013, 01:07 PM   #6
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
This is a thread about the "pedal dance". I've read a couple different ways of how to actually do it though.
Edit: haha a minute too late
campy is offline   Reply With Quote
Old 03-25-2013, 01:19 PM   #7
boead
boead's Avatar
What about holding the \traction "off" button for 5 seconds. When I do that the car is untamed = more fun.
Old 03-25-2013, 01:26 PM   #8
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
well, ill be the one to toss this out there:
dont be stupid and turn off everything on the street. the pedal dance should only be performed and utilized on a closed course.
supramkivtt2jz is offline   Reply With Quote
The Following 8 Users Say Thank You to supramkivtt2jz For This Useful Post:
BanzaiZee (03-25-2013), Ingen (04-09-2013), jonnyozero3 (03-25-2013), racecaresuaceb (03-25-2013), raul (04-05-2013), russv (03-25-2013), Scenic Driver (03-26-2013), strat61caster (03-25-2013)
Old 03-25-2013, 01:58 PM   #9
robo_robb
robo_robb's Avatar
Drives: Whiteout FR-S
Thumbs up
I do this every time I drive the car. TCS/VSC is an impediment for the competent driver. Save for when you're experiencing severely inclement weather.
robo_robb is offline   Reply With Quote
The Following User Says Thank You to robo_robb For This Useful Post:
Rayme (03-25-2013)
Old 03-25-2013, 02:39 PM   #10
boead
boead's Avatar
SO how does it differ from the pedal dance?
And YES, I almost got stuck in some snow this weekend. No, I WAS stuck in snow and was like 20 miles up a dirt road!
I realized the car was in this mode; I tend to do exactly what you do and turn it all off most of the time.
With the TC on and with a light foot on the clutch I was able to back the car out of the "too deep" snow back onto some dry ground.
It saved my ass.
I also found in the rain the car becomes too tail happy at inopportune times. With the TC fully engaged its a definite advantage. I can easily feel the car braking. It also feels as though the car is altering the steering somewhat.
Old 03-25-2013, 03:00 PM   #11
Dezoris
Dezoris's Avatar
Pedal dance is not an option. As it affects ABS performance in tighter and hard braking situations because it cancels brake force distribution. Long story short it's not really a "mode" to select, it's a diagnostic setting that can have un-predictable results.
The Following User Says Thank You to Dezoris For This Useful Post:
supramkivtt2jz (03-25-2013)
Old 03-25-2013, 03:09 PM   #12
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Correct. Another FR-S guy at the last autoX event mentioned he hated the characteristics of the car after the pedal dance. It confuses the ABS computer and renders the car more unpredictable. He and I prefer to drive with the VSC+TCS off by holding for 3 seconds.
Old 03-25-2013, 03:15 PM   #13
iaclimber4
iaclimber4's Avatar
Drives: 2013 Whiteout FR-S MT
2 buttons, multiple outputs. Varying degrees of slip angle
1. All nannies on when you start the car; use this in bad weather, otherwise usually drive with #2 on normal days.
2. VSC sport - won't let you spin the tires (4-5K launch), but will let you drift around a corner - fairly limited, but did save my butt once in the rain
3. VSC Sport/Trac off - lets you do a spirited start but turns off (Trac) after 31mph. Won't really let you get sideways too much due to the VSC
4. All nannies off - press the left button for 5 seconds....at ANY speed. Go have fun doing donuts, hand brake u-turns, drifting! ABS still active. In this mode, feel free to wrap yourself around a tree, nothing will stop you (except the tree)....usually use this on country roads and when little traffic around the city.
iaclimber4 is offline   Reply With Quote
The Following User Says Thank You to iaclimber4 For This Useful Post:
Toyota GT 86 (04-06-2013)
Old 03-25-2013, 03:17 PM   #14
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Even "competent" drivers screw up. Ask any NASCAR driver.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following User Says Thank You to russv For This Useful Post:
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 10:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 03:40 AM
VSC Sport, Trac Off, Both Off - Which do you use for normal driving? pinoyplaya BRZ First-Gen (2012+) — General Topics 100 08-28-2012 03:24 AM
Delivery day. To sport mode or not? Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 5 06-21-2012 07:50 AM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
