Old 03-14-2013, 01:06 AM   #2325
sw20kosh
Drives: 2013 Black FR-S
Turbo doesn't act like a resonator.
It quiets an exhaust down the same way this does:
see the similarity?
The principles are the same. Sound waves cannot just exit out freely from the exhaust ports. They hit something in the exhaust path. Whether it be a butterfly valve or a turbo turbine blade wheel.. same principle. The material absorbs the some of the sound energy and bounces it back even.
The Following User Says Thank You to sw20kosh For This Useful Post:
vubaru (03-14-2013)
Old 03-14-2013, 02:49 AM   #2326
troek
troek's Avatar
Drives: 2012 Toyota 86
that sounds pretty darn mean to me
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
vubaru (03-14-2013)
Old 03-14-2013, 12:09 PM   #2327
AVOturboworld
[ame="https://www.youtube.com/watch?v=4feKV_xeGeg"]AVO BRZ Test Honjo Circuit - YouTube[/ame]
The Following 10 Users Say Thank You to AVOturboworld For This Useful Post:
BRZranger (03-15-2013), Calum (03-14-2013), cmss2000 (03-14-2013), Draco_PR23 (03-14-2013), Jeff86 (03-24-2013), Mr.Jay (03-16-2013), Sonolin (03-14-2013), Sportsguy83 (03-14-2013), troek (03-14-2013), vubaru (03-14-2013)
Old 03-14-2013, 11:30 PM   #2328
JD86
Drives: 2013 Toyota 86 GT
Sounds hot, looks like a lot of fun... But what's with the purple interior? :-p
JD86 is offline   Reply With Quote
Old 03-15-2013, 12:46 AM   #2329
sw20kosh
Love the purple seats. What number is the avo car? 1? 2? 3?
Old 03-16-2013, 02:17 PM   #2330
AVOturboworld
I believe they were the no.3 car with the 43 second time. Will check on that. The seats are black - that interior camera does weird things with color. Exposed to too many exotic fumes I guess..
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (03-16-2013)
Old 03-16-2013, 08:00 PM   #2331
Calum
That Guy
Drives: 2013 asphalt FRS MT
So that camera makes the seats purple, your other camera makes your FRS a very strange color orange.... I think you guys are messing with things.
Old 03-16-2013, 08:14 PM   #2332
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I don't think I can trust all the dyno graphs that have been posted since I can't even trust their videography skills.
STOP LYING TO US AVO!!
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-18-2013, 01:18 PM   #2333
AVOturboworld
In this next week or two.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
BRZranger (03-18-2013), vubaru (03-18-2013)
Old 03-19-2013, 01:36 AM   #2334
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Can I add my name to the pre-order list :"D
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-20-2013, 12:37 PM   #2335
AVOturboworld
Track testing update:
Ross at AVO Turboworld Japan just completed a full day of track testing at Tsukuba Circuit. And when we say full day, it was a full day, 20 minute sessions on the hour, every hour from morning till evening. All in all, the AVO BRZ did around 80 laps over the course of the day.
With Ross driving, times were very consistent, around the 1m05sec mark for the entire day. This is about a 3.5 second improvement from the BRZ back when it was N/A, but with the suspension and tires. Ambient temperatures were at the 25° C mark, with the actual track surface temperatures at 35° C mark.
The car was logged the entire time so we could track water and oil temps, along with a lot of other data we were keeping an eye on. Over the course of the day, the max water temperature we hit was 106° C, which dropped to 98°C when the heater turned on. Oil temperatures hit 140°C at max, which dropped to 135°C when the heater went on. In direct comparison, another BRZ being driven at the same time that was N/A and running a large oil cooler was hitting 117° C oil temperatures.
Needless to say, it was a fairly comprehensive thrashing of the car at the track. Yet at no time did the car overheat. One reason for that is that the oem radiator cap is 1.1-bar unit.
Ross’s advice towards anybody considering these levels of track duty may certainly want to invest in an oil cooler, it would help. Things to look at is maximizing air flow through the car, and possibly invest in a more efficient radiator.
They also did a fairly comprehensive test of the track breather system, and it worked brilliantly. Part of that setup was a new PCV valve designed for turbocharged application. A problem with the standard PCV is that it was never designed for positive intake manifold pressure, and will leak under boost. We will be posting some videos of testing of the PCV soon.
A couple of pics from the previous track day a week earlier at Honjou Circuit
The Following 12 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (03-20-2013), bestwheelbase (03-24-2013), Bonburner (03-20-2013), BRZranger (03-20-2013), buditjoenawan (03-20-2013), Fly Guy (03-23-2013), Jeff86 (03-20-2013), NorCalRider (03-20-2013), Sportsguy83 (03-20-2013), sw20kosh (03-20-2013), swift996 (03-20-2013), vubaru (03-20-2013)
Old 03-20-2013, 02:18 PM   #2336
dabocx
dabocx's Avatar
Drives: Scion FRS
Some on needs to put a full turboback/injectors/pump and see what this thing can do on 93 and e85.
Still the most oem looking kit and that sound >_>
dabocx is offline   Reply With Quote
Old 03-20-2013, 04:02 PM   #2337
AVOturboworld
I am planning on doing that here as soon as possible, and have it run on the Drift Office dyno again so we have clear back to back data.
dabocx (03-21-2013), Sportsguy83 (03-20-2013)
Old 03-21-2013, 04:47 AM   #2338
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by vubaru View Post
... Walbro high volume fuel pump...
I'm looking for the optimal fuel pump to support my ~10-12psi AVO build
Has anyone experienced putting Walbro 255lph in the BRZ\FRS bucket?
Will it fit ?
As spoken with Paul from @AVOturboworld , Ross is testing some fuel pump options at the moment, so I' ll be very grateful if AVO could add the appropriate and relable pump in the package, which is about to leave my way...(hopefully)
I've chosen Deatschwerks 700cc inhectors, but heard many weird things reg their DW65 pump, which seems to have a mind of its own ... so I'm seeking options
MSTiFK8R is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
