Old 03-20-2013, 07:39 PM   #1
xwd
April SCCA Fastrack
http://scca.cdn.racersites.com/prod/...april-solo.pdf
Included in this a proposal to eliminate the "Stock" classes starting in 2014 as they are currently defined. "Stock" would change its name to "Street" and run on street tires (140 TW next year and 200 TW in 2015).
It also eliminates shocks with remote reservoirs, allows replacing both front and rear swaybars, and allows the addition of camber plates and camber bolts for strut type suspensions. On our cars that means you could use them in the front but not the rear.
Old 03-20-2013, 07:51 PM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I like the idea. but I also like the idea of a newbie with a bone stock car being at least a little competitive so they will be excited to mod the car and return for more events. If you open up to much modding in stock class it will really hurt the people that don't have the money for camber plates and sway bars and they well probably loss interest with the sport. Just my 2 cents.
Sent from my SGH-T989 using Tapatalk 2
Old 03-20-2013, 08:03 PM   #3
xwd
The camber thing is really so people aren't spending tons of money on tires with certain cars, such as the WRX, Mini, Audi TT, most VWs, etc. Those cars with the current ruleset eat through expensive tires in no time since they have very little camber in the front.
Old 03-20-2013, 08:08 PM   #4
Accurate Race Shop
Drives: Scion FR-S
I would really be in for it as long as we don't over do it and scare away the new people making them think they have to drop $5k into the car just to be competitive. I think stock class is really to broad in some areas and to narrow in others I would like to see it refined a little bit sounds like they are in the right path.
Old 03-20-2013, 08:09 PM   #5
des
des's Avatar
I would guess that the current delta between two identically prepped cars, one on R-compounds and the other on 200TW, is bigger than the difference than a bone-stock car and a fully prepped one under the new rules.
des is offline   Reply With Quote
The Following 2 Users Say Thank You to des For This Useful Post:
BlaineWasHere (03-20-2013), Rampage (03-20-2013)
Old 03-20-2013, 08:15 PM   #6
Mitch
form follows function
Drives: RIP '13 BRZ
Camber plates and sway bars are a hell of a lot cheaper than Motons and R-compounds. This is a significant improvement over the current situation.
Mitch is offline   Reply With Quote
The Following 3 Users Say Thank You to Mitch For This Useful Post:
BlaineWasHere (03-20-2013), mkiisupra (03-21-2013), Rampage (03-20-2013)
Old 03-20-2013, 08:19 PM   #7
xwd
There are a number of expensive shocks out there which do not have remote reservoirs. So it doesn't stop someone from still spending $5K on shocks if they really want to. Not that having those is a key to winning anyways, many championships have been run on cheaper shocks like Koni Sports.
I am favor of the rules for the most part but would like to see the camber allowance opened up for all suspension types.
Old 03-20-2013, 08:27 PM   #8
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
I kindof saw this happening with creation of the RTR sub class within stock. Most people I know would only run in the RTR class and not CS due to having to run R comps to be competative in CS. I also like the ban on $3000.remote res. shocks that most could not afford. This keeps the "stock" class a bit more down to earth and if someone wants to go nuts on the mods then we already have STX.
Gearhd79 is offline   Reply With Quote
Old 03-20-2013, 08:28 PM   #9
brz7400
brz7400's Avatar
Drives: Subaru BRZ
How does this affect RTR CS? Since 200 treadwear tires, both become the new Street class?
Sucks they allow for +/-1" wheel diameter, but not width
brz7400 is offline   Reply With Quote
Old 03-20-2013, 08:30 PM   #10
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Presumably, there will be no more RT* classes if the "Street Class" becomes a thing. I can't think of any differences in the rules once Stock gets off the R-comp crack.
Unless you just like PAX-indexed scoring.
Old 03-20-2013, 08:39 PM   #11
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I am ecstatic at this. but @Sam Strano wont be quite add happy. Waiting to hear his thoughts.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 03-20-2013, 09:14 PM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
Agreed. Even +/- 0.5" would make a good majority of most aftermarket wheels out there usable.
simpleisbest is offline   Reply With Quote
Old 03-20-2013, 10:13 PM   #13
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I agree with simpleisbest COMPLETELY on the half inch wheel allowance.
As Sam did on facebook, I highly encourage everyone to PLEASE write a letter to the SEB with your thoughts on this, that huge thread about stock class on this forum is filled with ideas and opinions now is the time to push the issue to make this "entry" ruleset into what WE as members want out of such a class. whether you are on favor or opposed, make your opinions known to those who have a say.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-20-2013, 10:32 PM   #14
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
I like almost all the changes, but don't understand the two swaybar allowance. Won't we end up with massive, 'unstreetable' bars front and rear as the 'hot' setup (real or perceived)?
Also fyi, there is a posting at solomatters.com that provides some additional background info and reasoning on the changes.
jdrxb9 is offline   Reply With Quote
Feb Fastrack posted, E85 no longer legal for ST xwd Tracking / Autocross / HPDE / Drifting 23 01-24-2013 04:29 PM
November Fastrack xwd Tracking / Autocross / HPDE / Drifting 2 10-23-2012 07:26 PM
And the Winner is:...........BRZ to STX ..Oct fastrack Scooby South Tracking / Autocross / HPDE / Drifting 79 09-28-2012 04:40 AM
SCCA! Who's going? Hayashi Hawaii 18 08-21-2012 01:40 PM
BRZ in April GQ ionshards BRZ First-Gen (2012+) — General Topics 29 03-22-2012 08:21 PM
