Drives: Scion FR-S (mt)
Steering Wheel Off-Centered
I may be thinking about it too much, but it bugs me. My steering wheel is slightly left when driving straight. Anyone else notice this or know if I can straighten the wheel? (The car does not pull and tire pressures are even)
Thanks in advance |
#2 |
Drives: 13 GTI
Take it to the dealer to see if they can get it re-aligned for you.
#3 |
Drives: Supercharged Golf Cart
You just now noticed this or you hit a curb or pothole since purchase? It should be straight as a laser beam, which is in stark contrast to the common line of horseshit you are fed after attempting to get an alignment...surely you've heard it before:
"all cars are designed from the factory to pull slightly to the right in case you fall asleep" To which I reply: "funny, every new car I've ever purchased was not set up correctly then, because they drove perfectly straight from day 1"...<deer in headlights look appears on face of moron technician>. |
| The Following User Says Thank You to fistpoint For This Useful Post: | idreamofdrifting (03-21-2013) |
#4 |
Lol, i thought i was the only one. Mine is a little to the left as well. Just gonna have it fixed when i go in for my first oil change.
#5 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
its an alignment issue. get one and itll be fixed. like second poster said if you hit a curb or pothole it could have caused it
#6 | |
Drives: 2013 BRZ Ltd. MT
Now, if the steering is set up to be perfectly centered traveling along a truly flat piece of pavement, then when traveling along a road with a slight rightward slant, the driver needs to compensate slightly with a tiny bit of left-turn steering to keep from drifting off the right side of the road. Other factors may play a role as well, such as driver weight, a heavy passenger, crosswinds, etc. The car can be set up to have the steering wheel dead centered when on the average crowned road. It’s up to you how you want yours set up. If the steering wheel is not dead-center level, spokes parallel to the horizon on any given road, it does not necessarily indicate a problem. However, if you notice a sudden change from what it had been, then that probably calls for a visit to an alignment shop. Hope this has been useful and helpful.
| The Following 2 Users Say Thank You to Porsche For This Useful Post: | strat61caster (03-20-2013), suaveflooder (03-20-2013) |
#7 | |
Drives: 10 VW GTI
P.S. ford or someone has a new electronic power steering that can compensate road crown or lateral wind blow. |
#8 |
Drives: Vs Commodore (86 GTS on order)
All vechicles are built 4-5mm shorter on one side, depending on which country you live in, to automatically accommodate for camber, every car for the last 10+ years has been built this way.
Any dealer telling you it automatically accommodates for camber via steering calibration is either trying really hard to spin stuff to sell it, or has no idea what hes on about. |
#9 |
Drives: FR-S MT
| The Following User Says Thank You to FRiSson For This Useful Post: | strat61caster (03-20-2013) |
#10 |
Drives: 2013 Scion FR-S (Hot Lava)
get an alignment, it is free and covered by warranty if done within the first 10,000 miles. I had to get one a few thousand ago and all is well now.
#11 |
Drives: DS FRS
It's super easy to adjust yourself - takes 5 minutes. Read up on adjusting the front tie rods. You don't even have to jack the car up
#12 |
#13 |
Yet the car still drives perfectly straight, yes? Because mine sure as hell does and all before it. That was the very first thing I smiled about when I got 100 feet out of the dealership parking lot...no more pulling right like my old car with multiple problems in the tie-rod and boot areas.
#14 |
wheel gap
Drives: whiteout frs, 04 xrs
can get an alignment under warranty for sure
| WTB: Stock steering wheel (wheel not airbag) | mobybrz | Interior Parts (Incl. Lighting) | 2 | 09-11-2014 02:23 PM |
| Different Steering Wheel?- NOT? | BRZfan | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-07-2013 09:01 PM |
| Steering wheel stiffness? | j4m35ly | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-20-2012 02:51 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) — General Topics | 8 | 12-08-2011 11:16 AM |
| That steering wheel | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-04-2011 12:16 AM |
