Old 03-20-2013, 12:25 AM   #1
dco107
Drives: Scion FR-S (mt)
Steering Wheel Off-Centered
I may be thinking about it too much, but it bugs me. My steering wheel is slightly left when driving straight. Anyone else notice this or know if I can straighten the wheel? (The car does not pull and tire pressures are even)
Thanks in advance
dco107 is offline   Reply With Quote
Old 03-20-2013, 12:32 AM   #2
mact
Drives: 13 GTI
Take it to the dealer to see if they can get it re-aligned for you.
mact is offline   Reply With Quote
Old 03-20-2013, 12:42 AM   #3
fistpoint
Drives: Supercharged Golf Cart
You just now noticed this or you hit a curb or pothole since purchase? It should be straight as a laser beam, which is in stark contrast to the common line of horseshit you are fed after attempting to get an alignment...surely you've heard it before:
"all cars are designed from the factory to pull slightly to the right in case you fall asleep"
To which I reply: "funny, every new car I've ever purchased was not set up correctly then, because they drove perfectly straight from day 1"...<deer in headlights look appears on face of moron technician>.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
idreamofdrifting (03-21-2013)
Old 03-20-2013, 12:44 AM   #4
suaveflooder
Thanks in advance
Lol, i thought i was the only one. Mine is a little to the left as well. Just gonna have it fixed when i go in for my first oil change.
suaveflooder is offline   Reply With Quote
Old 03-20-2013, 01:19 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
its an alignment issue. get one and itll be fixed. like second poster said if you hit a curb or pothole it could have caused it
Old 03-20-2013, 01:42 AM   #6
Porsche
Drives: 2013 BRZ Ltd. MT
Thanks in advance
Most road surfaces are cambered (slanted) slightly to the right on each side of the center “crown” of the road. This is necessary for water drainage in rain; we would not want our roads to be “cupped” and pooling all the water in the road center, creating a lake.
Now, if the steering is set up to be perfectly centered traveling along a truly flat piece of pavement, then when traveling along a road with a slight rightward slant, the driver needs to compensate slightly with a tiny bit of left-turn steering to keep from drifting off the right side of the road.
Other factors may play a role as well, such as driver weight, a heavy passenger, crosswinds, etc.
The car can be set up to have the steering wheel dead centered when on the average crowned road. It’s up to you how you want yours set up.
If the steering wheel is not dead-center level, spokes parallel to the horizon on any given road, it does not necessarily indicate a problem. However, if you notice a sudden change from what it had been, then that probably calls for a visit to an alignment shop.
Hope this has been useful and helpful.
Porsche is offline   Reply With Quote
The Following 2 Users Say Thank You to Porsche For This Useful Post:
strat61caster (03-20-2013), suaveflooder (03-20-2013)
Old 03-20-2013, 02:56 AM   #7
motofan
Drives: 10 VW GTI
This is also what I'm going to say. Find a very flat road and test it.
P.S. ford or someone has a new electronic power steering that can compensate road crown or lateral wind blow.
motofan is offline   Reply With Quote
Old 03-20-2013, 05:14 AM   #8
Nick26
Nick26's Avatar
Drives: Vs Commodore (86 GTS on order)
All vechicles are built 4-5mm shorter on one side, depending on which country you live in, to automatically accommodate for camber, every car for the last 10+ years has been built this way.
Any dealer telling you it automatically accommodates for camber via steering calibration is either trying really hard to spin stuff to sell it, or has no idea what hes on about.
Nick26 is offline   Reply With Quote
Old 03-20-2013, 11:17 AM   #9
FRiSson
Drives: FR-S MT
Interesting. Can you verify this?
FRiSson is offline   Reply With Quote
The Following User Says Thank You to FRiSson For This Useful Post:
Old 03-20-2013, 11:22 AM   #10
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
get an alignment, it is free and covered by warranty if done within the first 10,000 miles. I had to get one a few thousand ago and all is well now.
SkitterSkotter is offline   Reply With Quote
Old 03-20-2013, 12:07 PM   #11
blkwrxwag
Drives: DS FRS
It's super easy to adjust yourself - takes 5 minutes. Read up on adjusting the front tie rods. You don't even have to jack the car up
blkwrxwag is offline   Reply With Quote
Old 03-21-2013, 07:43 AM   #12
Nick26
Nick26's Avatar
By trade I am a vehicle body repairer. You can see yourself by doing a simple rope test wheel alightment, one side will be shorter by a a small number measuring center to center after aligning your wheels.
Old 03-21-2013, 06:46 PM   #13
fistpoint
Yet the car still drives perfectly straight, yes? Because mine sure as hell does and all before it. That was the very first thing I smiled about when I got 100 feet out of the dealership parking lot...no more pulling right like my old car with multiple problems in the tie-rod and boot areas.
Old 03-22-2013, 12:43 AM   #14
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
can get an alignment under warranty for sure
Jesse is offline   Reply With Quote
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 03:23 PM
Different Steering Wheel?- NOT? BRZfan Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2013 10:01 PM
Steering wheel stiffness? j4m35ly Scion FR-S / Toyota 86 GT86 General Forum 6 06-20-2012 03:51 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 12:16 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
