Old 03-19-2013, 11:41 AM   #29
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Originally Posted by MotivConcepts View Post
Slight issue rubbing on the rear driver side, but I've raised the car up a tad since and have had no issues.
One more question: Did these fit with stock suspension on?
I see another member running same size wheels (diff brand) with a 38F and 42R offset that fit on his stock suspension.
Im getting ready to order wheels myself and i want to verify bc there may be a delay in getting coils.
Old 03-19-2013, 12:48 PM   #30
MotivConcepts
Drives: 2013 Subaru BRZ
Send a message via AIM to MotivConcepts
I had my coilovers on already when I got the wheels, but I don't see why it would hit on stock suspension or just springs.
MotivConcepts is offline   Reply With Quote
The Following User Says Thank You to MotivConcepts For This Useful Post:
norsamerican (03-19-2013)
Old 03-20-2013, 01:29 AM   #31
nix
nix's Avatar
Drives: AVO BRZ
My favourite wheel. I wanted to put it on my BRZ but it's heavy. Your car looks so good!!
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
MotivConcepts (03-20-2013)
Old 03-20-2013, 01:59 AM   #32
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
The new 453 tires - do you think they fit a bit wider than their sizing (like StarSpecs or SSPs?) They are on my short list but not a lot of info floating around...
Khyron686 is offline   Reply With Quote
Old 03-20-2013, 02:18 AM   #33
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Correct, i had 8.5 +38 and there is plenty of clearance on stock or drop springs. Rear has plenty of clearance so nothing to worry there either.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Old 03-20-2013, 01:21 PM   #34
MotivConcepts
They do. Their sidewall isn't flat like the FK-452, but performance is much better and less road noise.
Old 04-11-2013, 08:06 PM   #35
Sisi
Drives: TSX
Specs are:
18x8.5 +32 with 225/40/18 Falken FK-453
18x9.5 +39 with 255/35/18 Falken FK-453
Looks really good.
What coilover/spring did you use?
How many inches did you lower the car?
Did you have to adjust the camber?
Sisi is offline   Reply With Quote
Old 04-11-2013, 08:09 PM   #36
MotivConcepts
Originally Posted by Sisi View Post
Looks really good.
I'm running KW V3 coilovers on the car. I'm not sure how low it is, it's basically the setting out of the box - in those photos, I had the rear lowered a tad more, but I've raised it up since.
Didn't do any camber adjustment, just got an alignment.
Old 04-24-2013, 01:34 AM   #37
Jeremehh
Drives: Scion FR-S (Whiteout)
Hey. Sweet BRZ man. I'm lookin to do my FR-S with those size rims but i was curious on how much the Tires are going to be. Do you mind if i ask how much roughly it was for each tire? Much appreciated. Thanks. -Jeremy
Jeremehh is offline   Reply With Quote
Old 04-25-2013, 04:05 PM   #38
MotivConcepts
Tire pricing will vary depending on what size you want to get. You'll probably want to check TireRack.com - their pricing is pretty competitive. Hope that helps.
Old 04-30-2013, 03:01 AM   #39
ap1mikeo
Drives: whiteout
these look sweet. can you quote me for shipping to california?
ap1mikeo is offline   Reply With Quote
Old 04-30-2013, 01:20 PM   #40
MotivConcepts
Hey bud,
We don't actually sell Work Wheels. But if you're interested PM me and I can get you pricing.
Old 06-30-2013, 04:02 AM   #41
autobahned
autobahned's Avatar
Drives: Scion FR-S Asphalt
Originally Posted by JoeBoxer View Post
As i mentioned on facebook those offsets are perfect, those were well worth the wait!
Looks great? how's the drive and ride compare to the stock? Thanks!
autobahned is offline   Reply With Quote
Old 06-30-2013, 03:29 PM   #42
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
nice! most pics have a "hidden hardware" look to it
SLICVIC is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38 FML Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 91 06-13-2015 09:48 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +38 / 18x9.5 +38 f0rge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-16-2015 03:57 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 09:10 AM
Wheel Directory: XXR 531 18x8.5 +35 / 18x9.5 +35 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-07-2013 01:43 PM
Wheel Directory: Work Emotion 11R 18x8.5 +45 / 18x9.5 +38 DR1FT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-04-2013 02:16 PM
