Old 03-18-2013, 11:36 AM   #15
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by cmspooner View Post
I love that shift knob! Is it a flossy? Do you still have the pattern?
Yes and Yes!
F1point4 is offline   Reply With Quote
Old 03-18-2013, 12:59 PM   #16
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
Awesome install
Thanks
Tom
tom@kartboy is offline   Reply With Quote
The Following 2 Users Say Thank You to tom@kartboy For This Useful Post:
F1point4 (03-18-2013), Jrdad (08-31-2013)
Old 03-18-2013, 01:39 PM   #17
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Thanks for the great write up. Looking forward to when mine arrives.
rmjjensen is offline   Reply With Quote
The Following User Says Thank You to rmjjensen For This Useful Post:
Old 03-18-2013, 01:43 PM   #18
Racecomp Engineering
Awesome review as usual!
- andrew
Old 03-18-2013, 01:45 PM   #19
xxscaxx
Drives: 2013 SWP BRZ
Just in time as I will be installing mine today or tomorrow. Thanks as always for the great write ups, and most importantly awesome photography!
You should be the DIY moderator, lol.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 03-18-2013, 04:26 PM   #20
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Originally Posted by F1point4 View Post
Yes and Yes!
Can you send the image my way? I would love to get that on the red grip-tape knob; that is if you don't mind.
cmspooner is offline   Reply With Quote
Old 03-18-2013, 04:40 PM   #21
raphy
raphy's Avatar
Drives: whiteout FRS
amazing write up!
raphy is offline   Reply With Quote
Old 03-18-2013, 05:03 PM   #22
p00mba
p00mba's Avatar
Drives: FR-S :)
this is awsome! just ordered mine and will be using this for the install. Thanks for posting this!
p00mba is offline   Reply With Quote
The Following User Says Thank You to p00mba For This Useful Post:
Old 03-18-2013, 08:50 PM   #23
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
has shift leverage changed?
can you still feel the 'gates'?
do you like it enough to recommend it for DD?
for track?
have you had it up to speed?
any more or less play than OE?
any more vibration, NVH or other feedback?
thanks, great write up
Huehuecoyotl is offline   Reply With Quote
Old 03-18-2013, 09:09 PM   #24
F1point4
Photo Specialist
F1point4's Avatar
for track?
Gem,
Haven't had tons of miles on it to break it in or taken it past 65mph so I'll have limited feedback.
Right now it takes some more strength to work the shifter vs OEM but you can still two fingertip shift. Force wise it could be quantifies as the same (more force across a short distance vs less force over a longer distance :p )
Its still comfortable to use for DD. it'll be natural just like the OEM once I adjust my muscle memory
It has the same amount of lateral wiggle while in gear as OEM
It reduced vibration for me both visibly and physically. Could be a combination of mods there but no more shakes. As for NVH, I didnt hear anything over the Vortech
When I'm less busy I'll take it for some hooning. Perhaps it'll be better the more I drive it.
Old 03-18-2013, 09:52 PM   #25
White64Goat
From watching the two overhead videos it appears that the shifts from Neutral to R, 1, 3 & 5 are shorter than the stock stick, but the shifts from Neutral to 2, 4 & 6 appear to be the same distance as stock as evidenced by where the edge of the shift knob appears from above when shifting to 2, 4 or 6. If that is the case, why aren't the shifts to 2, 4 & 6 shorter in distance (from neutral) like 1, 3 & 5. I assume the camera wasn't moved between shooting the videos?
Old 03-18-2013, 10:04 PM   #26
OrbitalEllipses
Drives: Attitude
From a profile view it appears the camera is a slight angle (i.e. ____/ ) and not directly over-top (i.e. ____| ) which could cause the phenomenon you're describing.
Slightly helpful Youtube mashup, not synchronized at all available here: http://www.youtubemultiplier.com/514...em-shifter.php
Old 03-18-2013, 10:19 PM   #27
F1point4
Photo Specialist
F1point4's Avatar
I am whipping up some science for you guys in response to this latest question
The Following User Says Thank You to F1point4 For This Useful Post:
yuicebox (07-15-2013)
Old 03-18-2013, 10:21 PM   #28
OrbitalEllipses
Drives: Attitude
Protractors and rulers?!
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 09:19 PM
Kartboy Short Throw Shifter!! RallySport Direct Transmission and Driveline 16 04-18-2013 02:18 PM
Kartboy Short Throw Shifter!! RallySport Direct Announcements, Contests, Giveaways 34 03-18-2013 03:18 PM
