| DIY (Do-It-Yourself) Guides For all DIYs. |
Mad Sciontist
Drives: gt86
Fuel pump upgrade install (Visconti 290lph)
So today I installed a new 290lph fuel pump that I got from Visconti and realised that there wasn't too much information on the subject so I decided to make a small turorial on it.
First of all it's not the most fun modification to do with all the black sticky sealant, tight cramped areas and the effort required not to get fuel all over your seats but all in all it probably took me about an hour. (Also run the car until the fuel light comes on, it will save you getting fuel everywhere) 1. Firstly you will need to release the pressure out of the fuel system by removing the fuel cap and then remove the 10mm bolt holding the left hand side rear seat and fold the seat up out of the way. ![]() 2. Under the seat you will see a cable entering a steel lid that is stuck down with some soft setting sealant, this just pops off with a flat blade screwdriver and a little bit of force. 3. Unplug the connector that supplies power to the pump and the fuel gauge floater and move aside. 4. Next the fun part, remove the fuel line connected to the top of the white plastic fuel pump carrier and watch out you don't get fuel everywhere, wrap a rag around the hose to absorb the fuel. You will also see a big collar holding the carrier in the tank, this collar needs to be unscrewed to remove the carrier, this is nearly impossible to do by hand so I just used a soft hammer and a length of aluminium to tap the collar loose. ![]() 5. Once that is removed you can pull out the carrier watching out for the float switch as well as anothe fuel line that needs to be disconnected. 6. Once it's been removed follow this link for the fuel pump install in the carrier. http://img259.imageshack.us/img259/4...stallinstr.pdf 7. It's a tight squeeze to assemble the carrier back together as the carrier actually holds the fuel pump against its seal (2 o-rings). 8. The wires in the carrier need to be cut and soldered then heat shrink applied. Red to blue and black to black. 9. Do everything back in reverse and your done. 10. Enjoy smelling fuel in the car for the next few days
#2 |
Drives: a few
Nice write up. I would add to anyone who has never done this, to have a low fuel level and to release the fuel pressure. Fuel system is something you should take extra precautions with.
#3 |
Drives: Scion FR-s
what would the point of upgrading the fuel pump??? are we thinking higher flow pump get gas to engine faster?
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake |
#4 |
Drives: Attitude
Higher quantity of gas faster. Pumps are rater liter per hour. This pump flows more fuel than the stock pump, required for when requesting more fuel via the ECU when going forced induction.
#5 |
First 86
Drives: Scion FRS Argento Automatic
The pump may pump faster but isn't it limited by the quantity the fuel injectors pump? Just asking.
Life is short...NO BORING CARS |
#6 |
Mad Sciontist
Drives: gt86
Oh yea I forgot to add that. Il wack it in now.
#7 |
Drives: Attitude
Yes. Injectors have a flow rating as well. Once you get to high enough fuel requirements, you will need to replace the injectors so you have more headroom (IDC, injector duty cycle). You'll more than likely run out of pump before injectors, though. Usually both are replaced, but it's much easier to replace the pump. Ran a 240lph pump in WRX before I even considered switching injectors.
#8 |
Drives: WRB BRZ
does a bigger pump decrease MPG?
#9 |
Drives: Attitude
#10 | |
Drives: BRZ WRB
could you pls share detail on the pump itself? manufacturer, p/n? |
#11 |
Drives: Argento 6spd FR-S
why not just take the seat all the way out tho instead of fighting with working with it held up?
#12 | |
Drives: Whiteout
It's good to have a sticky on the process to do this. |
#13 |
Mad Sciontist
Drives: gt86
It's not really fighting it, it's just foam, the amount of time you are holding it up for is much shorter than removing it completely.
#14 |
Mad Sciontist
Drives: gt86
You will need a pump when you start to run a bit of boost. I also run 500cc injectors with this pump and together their good for 20psi+ on e85
| Fuel pump and speed sensor | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 28 | 04-20-2017 01:54 PM |
| Fuel pump issue. | sevi21 | Issues | Warranty | Recalls / TSB | 13 | 02-01-2013 09:57 AM |
| New tail lights and fuel pump inc | MindtheGap | Mid-Atlantic | 14 | 12-19-2012 07:42 PM |
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 10:06 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
