Old 03-14-2013, 10:04 PM   #519
ML
ML's Avatar
Drives: 13 White MT FR-S
thats what was on the stock map
Old 03-14-2013, 10:09 PM   #520
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by ML View Post
So my car has been bogging down (throttle response) pretty bad since I put on the Injen Intake, and the car feels pretty unresponsive below 4500 rpm. I finally got my cable, and was wondering on thoughts about which fuel/timing map I should use. I was thinking Fuel in, and timing standard. Thanks
Sounds like the Injen intake itself, which is poorly designed in my opinion. The open faced design sucks in hot air that rises up off the headers and gets trapped under the hood when idling and driving at low speeds. There is no protection against filter heat soak on the front side and the other sides are poorly sealed. Do a search and you'll find lots of posts from people with bogging and sluggish response from the Injen intake even without a tune. I'd get a either a true CAI or a SRI that completely shields the air filter from radiant engine bay heat like the AFE Takeda.
You may not have noticed it that much in the winter months but as the ambient temps get warmer, the heat soak effect will likely be more pronounced.
Old 03-14-2013, 10:10 PM   #521
ScionFrsFan
He's right ^
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
The Following User Says Thank You to ScionFrsFan For This Useful Post:
ATL BRZ (03-14-2013)
Old 03-14-2013, 10:13 PM   #522
ML
ML's Avatar
Originally Posted by ATL BRZ View Post
Sounds like the Injen intake itself, which is poorly designed in my opinion, IMO. The open faced design sucks in hot air that rises up off the headers and gets trapped under the hood when idling and driving at low speeds. There is no protection against filter heat soak on the front side and the other sides are poorly sealed. Do a search and you'll find lots of posts from people with bogging and sluggish response from the Injen intake even without a tune. I'd get a either a true CAI or a SRI that completely shields the air filter from radiant engine bay heat like the AFE Takeda.
I know I know...I just want it to go away! atleast I can change something about the chip to try and make it better.
Old 03-14-2013, 10:15 PM   #523
ScionFrsFan
I'm not sure the chip can fix that. Sorry man If you do change your intake and still have stock box go get the Zeta drop in stage 2...Its great!
ScionFrsFan
Old 03-14-2013, 10:24 PM   #524
ATL BRZ
ATL BRZ's Avatar
Sell it on eBay like I did with my Airaid intake and then get a true CAI, or just plug the resonators and noise gen hole in the stock intake and get a nice drop-in. Think of it this way, if you can fetch at least $200 for the Injen you're only out $70 for a true CAI (Vigilant @ $270) or you could spend around $50 for a drop-in + plugs for the stock intake. Either way you'll be happy you ditched the Injen.
Old 03-14-2013, 10:27 PM   #525
ML
ML's Avatar
ive already plugged the stock reso holes and put a k&n on, and i got a good deal on the injen, but still, i wish i could fix this.
Old 03-14-2013, 10:34 PM   #526
ATL BRZ
ATL BRZ's Avatar
I really think you should at least try swapping back to stock and see if you notice a difference in throttle response and top end power, especially after idling and creeping around in traffic. I almost didn't want to believe it, but when I swapped back to stock after running the Airaid for a while, the low end throttle response felt better in those instances where I was taking off from a long stop light when it was hot out and the engine bay was hot too. Top end power felt about the same with a bit less noise in high rpms.
Anyways, sorry for the off topic chat, Jack! Back on topic!
Old 03-14-2013, 11:53 PM   #527
ScionFrsFan
haha . Back on topic...e85
ScionFrsFan
ML (03-15-2013)
Old 03-16-2013, 04:49 AM   #528
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Injen seems to be a hit or miss. Make sure everything is installed correctly. A lot of people seem to have bogging issues but mine was fine. I remember someone reviewed it and had the same problem and his vendor sent him a new one and it fixed everything.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
Minovsky (05-28-2013)
Old 03-16-2013, 08:51 AM   #529
ML
ML's Avatar
I had re-installed it twice. I took ATL BRZ's advice and put stock back on. Car is peppy again. I'll probably sit on it and then sell it.
The Following User Says Thank You to ML For This Useful Post:
ATL BRZ (03-16-2013)
Old 03-16-2013, 11:48 AM   #530
blkwrxwag
Drives: DS FRS
My Injen seems to be ok - none of those issues.
I seem to have settled on the 92 octane, Fuel + Timing - for my car running on CA 91 octane.
I'm racing the car at an autocross tomorrow to see how the map feels there.
blkwrxwag is offline   Reply With Quote
Old 03-17-2013, 06:33 PM   #531
ScionFrsFan
Jack,
You been quiet...what's in the works ?
ScionFrsFan
Old 03-18-2013, 01:16 AM   #532
subiestar
Drives: CBS Limited BRZ
So I was just doing a hex compare, using Beyond Compare software, on some of the maps and I found that a lot of maps in the same category are the same data wise.
for example in the 92 octane Fuel Standard Timing Out folder; the Stock, All Drop-in Filters, and All CatB maps are the same.
Jack - could you give some light on what's different between the stock maps and the All Drop-in / All CatB maps?
subiestar is offline   Reply With Quote
The Following User Says Thank You to subiestar For This Useful Post:
Visconti (03-19-2013)
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
