Old 03-12-2013, 06:25 AM   #1
normanb21
Drives: black frs
Brz turbo?
If the new forester xt comes with our engine with turbo, does this mean we will get this turbo in a upcoming model? It makes 250hp and 258tq at 2000rpm which is great. If i already have a brz,can i just slap this turbo on to my car with the same tune as the xt, and if i can what happens with warranty?
Heres a small review I found on the. Internet.
"In general, we liked everything about the turbo/CVT setup except the way it launched from a standing start. Surprisingly sluggish is how we'd describe its launch—and seriously not any faster by the seat of the pants than the 2.5i model—yet by 10 mph the turbo boost builds and it feels legitimately quick, and you get all 258 pound-feet of torque at 2,000 rpm. We think the rather tall starting ratio of the CVT has something to do with it—although this crossover does still weigh 3,600 pounds."
normanb21 is offline   Reply With Quote
Old 03-12-2013, 06:47 AM   #2
polancd
Drives: a few
That motor will have differnet internals and i dont think it has direct injection (off the top of my head ). While it may be possible that a Brz will one day come with a turbo, I dont think you will see one in the next MY.With an educated guess it will not be as simple as getting XT turbo parts and slapping it on to the FA20. Might be as simple as getting some sort of conversion kit though. But one thing I do know is the stock XT tune will not work and adding a turbo will void your warranty (unless it is some sort of Delar installed option). If you want to turbocharge your car, get a turbo kit.
polancd is offline   Reply With Quote
Old 03-13-2013, 07:25 PM   #3
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Pretty sure I've read a bunch of times there an agreement for no FI until 2015 or something.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 03-14-2013, 05:45 AM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
same internals, no port injection
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 03-14-2013, 05:59 AM   #5
ft_sjo
Drives: GT86
How can it be same internals if the compression ratio is 10.x:1? Magic!
The Following User Says Thank You to ft_sjo For This Useful Post:
dori. (03-14-2013)
Old 03-14-2013, 06:38 AM   #6
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Really thick head gaskets? I seriously doubt the internals are similar in anyway.
industrial is offline   Reply With Quote
Old 03-14-2013, 10:52 AM   #7
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
The FXT will be running a full Subaru direct injection unlike our Toyota D4-S. Also, the motor in the FXT will sit in a much different location (and a much different engine compartment) than the motor in your FR-S and the turbo/exhaust manifold won't fit.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 03-14-2013, 10:58 AM   #8
ft_sjo
Drives: GT86
As you seem to be 'in the know', could you please clarify for us what parts of the turbo/manifold will foul the BRZ?
Old 03-14-2013, 11:15 AM   #9
jimbobrand
jimbobrand's Avatar
The engine in the FXT will be mounted much higher in the chassis than the engine in the BRZ/FR-S and the FXT will be running a turbo mounted below and in front of the engine like the newer Legacy GT. The BRZ/FR-S has the engine mounted as low as possible in it's chassis to keep the center of gravity as low as possible and doesn't have the space for the OEM turbo manifold. If you look at the stock FA20 exhaust manifold it was designed to be as low profile as possible.
For the money, I'd just go with the AVO turbo kit because even if the OEM stuff fit it would still cost almost as much (or more) as the aftermarket kit.
Jim Brand
TXIC San Antonio
Old 03-14-2013, 11:21 AM   #10
ft_sjo
Drives: GT86
You just contradicted yourself. You said it won't fit, then you said if it fits. If you don't know don't make statements, instead offer an opinion that it may not fit.
Unless you've tried bolting the turbo FA20 into a BRZ you won't actually know.
Old 03-14-2013, 11:32 AM   #11
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
I really don't think that it's going to be as hard as everyone says.
Here is the '12 Legacy GT turbo set-up:
It doesn't look that much different from our exhaust mani.
Here is the '14 Foz engine and turbo set-up:
If they are to turbo the BRZ, seems like an easy enough install to me. The only "real" hard part I see is the piping to the rear of the car.
Beyer Subaru is offline   Reply With Quote
Old 03-14-2013, 11:33 AM   #12
jimbobrand
jimbobrand's Avatar
Where do I say that it fits? I said "even if (key words have been bolded) the OEM stuff fit it would still cost almost as much (or more) as the aftermarket kit". The aftermarket makes turbo kits for the BRZ/FR-S fitment but that is different than the stock FXT parts the OP was talking about using, OEM and aftermarket options are not the same. I've seen a new 2014 FXT and the turbo hangs too low in the chassis to fit the brz.
Jim Brand
TXIC San Antonio
Old 03-14-2013, 11:41 AM   #13
ft_sjo
Drives: GT86
So for the same money you could have an aftermarket conversion bolted to a n/a engine or a proper OEM-designed solution, with the right compression ratio and amazing torque response which will do 100k miles without issue.
Not a hard decision for me. Thanks for your input
Old 03-14-2013, 11:53 AM   #14
jimbobrand
jimbobrand's Avatar
Not sure if troll or just doesn't pay attention?
Jim Brand
TXIC San Antonio
The Following User Says Thank You to jimbobrand For This Useful Post:
Turbowned (03-15-2013)
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 06:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 07:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 02:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 02:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
