#533 |
Drives: Your Car
#534 |
Drives: 2013 Asphalt Scion FR-S
Those headlights are badass
Why can't the U.S. ever get nice parts. They always gotta cheap it out It's the little things that make up a nice car.
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
#535 |
Drives: 2013 BRZ Limited - WRB, MT
#536 | |
Drives: Firestorm
So much brighter! Since I had the actual OE version fogs they were plastic so I wasn't able to throw HID's in them due to temperature. Now with the full LED face along with glass housing I think the output is 5x brighter. I think it's even brighter than my headlights, haha!
Firestorm FRS
Airrex - Varis - GReddy - Arqray - Edirb - Whiteline |
#538 | |
Drives: scion fr-s argento
#539 |
That' perfect. i was worried about not having enough cable to pull the ballast up somewhere but that'll work great
#540 |
P i N O Y P R i D E
Drives: 86 C7P MT
I just recently installed the fogs on @Rollan's FRS with the new harness and new smaller switch from nigels. just a tip, if u guys want to use the switch. u need a extra extension wires that goes thru the firewall, because the wire that suppose to go thru the firewall to the switch from the outside is very short.
| The Following User Says Thank You to 86 FRS For This Useful Post: | nigel-jdmparts (03-14-2013) |
#541 | |
Drives: 86
I will talk to the factory and try to see if I can get them longer for you guys in the next shipment. let me know if 50CM extension enough for you guys, I might able to get it for you all. Last edited by nigel-jdmparts; 03-14-2013 at 05:33 AM. |
#542 |
I Void Warranties
Drives: Asphalt 86
Let someone else chime in who has installed it as well, but I think 50CM would reach to the left panel below the steering wheel.
| The Following User Says Thank You to tbwoodlee For This Useful Post: | nigel-jdmparts (03-15-2013) |
#543 |
#1362
Drives: 2014 Ice Silver WRX
@nigel-jdmparts longer the better!
| The Following User Says Thank You to mezdup For This Useful Post: | nigel-jdmparts (03-15-2013) |
#544 |
First 86 Driver Baby!
Drives: FR-S, Flex
@nigel-jdmparts if you can make it longer I'll take one!
| The Following User Says Thank You to kmbkk For This Useful Post: | nigel-jdmparts (03-15-2013) |
#545 | |
#546 | |
P i N O Y P R i D E
Drives: 86 C7P MT
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
| FINALLY - Got my FR-S | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 08-03-2012 05:16 PM |
| FINALLY GOT IT! | Ayaz2589 | NY / NJ / CT / PA | 8 | 07-28-2012 02:52 AM |
| Finally got it!! | percyng | CANADA | 21 | 06-17-2012 01:50 AM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 07:29 PM |
