| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#211 |
Elite Padawan
That's probably Day running light. I don't think they will show low trim level at the show or in a trailer like this. Or maybe they have sport package for low trim. Who knows?
Dark
#212 |
I'm NOT the *****istrator
Drives: 1NZ-FE
Personally, i am not absolutely sure there isnt any HID on the car.
In my opinion, there seems to be a projector lamp, and only HID uses projector lamp. Halogen doesnt. The orange tint, imo, is caused by the pole lights aka position lights which are ususally orange in stock, even when paired with stock HIDs. Bear in mind, stock HID from toyota is not pure white color, it is slightly yellowish. Also cars with HID usually have an additional halogen lamp for high beam purposes. And also this video have been edited for colour contrast etc, hence the colour doesnt appear as white as it is in reality. I've circled in this picture to show where i could possibly see a projector lamp lookalike circle of much whiter light in a concentrated area, much like the light throw characteristics of HID. Halgoen doesnt throw light in a concentrated circle. And the picture also shows where i speculate the pole lights to be, causing the general orange tint. I could be wrong though as the video image have been manipulated to the nth degree
#213 | |
![]() 06-07 Imprezas had the same projector style halogen, as did the 05-09 Legacys. And thats just two for the sake of naming specific models, LOTS of cars have this kind of projector halogen headlight. Its just a nifty piece of glass in front of the halogen bulb. |
#214 | |
Car Enthusiast
Drives: tC 05 & 07, Rav4
#215 | |
Hook 'em
#216 | |
Drives: 1NZ-FE
is that so, then i must be mistaken, thanks for pointing it out |
#217 |
Drives: 1NZ-FE
so the only way to tell a HID from a Halogen is from the colour temperature and brigtness? since both can be using projector lamps
#218 | |
Drives: 2013 Subaru BRZ MT Limited
This means having two separate HID projector housings, one for highs and one for lows is not feasible, as the constant re-striking of the high beams would kill their lamp life as well as not being able to turn your high beams back on for 15 minutes after turning them off would not be a good thing. This is why on production cars with HID's the high beams are created by ether physically moving the lamp within the projector housing to change the lights focal point OR having a second high wattage Halogen housing mounted NEXT to the HID housing. You will notice in cars with the latter option, the high beams only add the Halogen's to the HID's and do not turn the HID's off due to the previously mentioned hot re-strike complication. As an entertainment technician I am very well versed in the area of lighting ![]() -Trev Entertainment Lighting Tech
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#219 |
Wrong, HID's and Halogen's can have similar color temperatures and outputs although yes, most likely the rule of thumb is halogens are low color temperature and HID's are high, however it's not a perfect rule, it all depends on how each lamp is designed, you can achieve higher or lower color temperatures in each type by lengthening or shortening lamp life. For instance I've seen 5,000k halogen's (those little display lamps you see mounted to lighting tracks in stores are usually 5000k) and I've seen 2500k HID's (usually those orange street lamps you see on the highway.) Halogens however do require more power to output at the same brightness as HID's are they are only about 2% efficient at best where HID's are closer to 10 to 15%, florescent's are something like 40% efficient and LED's are 60%. Don't quote me on those numbers as I am trying to remember from memory...I don't have supporting documents in front of me.
#220 | |
Drives: none =[[
#221 | |
Drives: 1NZ-FE
#222 |
ZC6A2B82KC7J
Drives: 2002 WRX
One thing is for sure, the glow isn't bright enough to be from the headlights, it is just the DRL. DRL never use the projector lense, they are usually a smaller incandescent bulb or sometimes CFLs like BMW or LEDs like Audi. Conclusion: you can't tell from the vid if it has HID or halogen headlights.
#223 |
Next to impossible to tell, but most likely it's the low spec Halogen model. No idea though, like you said before...the picture could be photoshopped to hell. But most likely it's Halogen, the HID model is supposed to have the LED Clearance lights in the headlamps, I do not see them therefore it's prolly the Halogen. The company is probably turning out multiple different models to use as test dummies right now, so they probably just grabbed whichever one was available for the test shots. Hence why they show a white one, a black one and a red one, they are probably 3 different models they had on hand at the time while others are going out for crash testing and other assorted tests like DOT and emissions.
#224 | |
Drives: 1NZ-FE
| Awesome feature film/video featuring AE86 and other cars in drifting competition | Hachiroku | Other Vehicles & General Automotive Discussions | 3 | 07-06-2013 11:21 AM |
| Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 541 | 11-18-2011 10:04 PM |
| New Video: Frankfurt FT-86 II Trailer! | CyberFormula | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 91 | 09-13-2011 05:19 AM |
| Gran Turismo 5 - Official Toyota FT86 Trailer [HD] | Raiden | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 08-10-2010 02:05 AM |
| Toyota FR-S : Official Name for the FT-86 Concept? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 155 | 08-05-2010 12:05 AM |
