#57 |
Drives: 2013 Black FR-S
HP is calculated from Torque and rpm.
An engine that has a high hp number will have a high redline. Why? Because torque generated at high RPM = high HP # relative to torque #. An engine that has a high torque number relative to HP will have a low redline (like 4,000-5,000). Study a few dyno graphs that have both torque and HP on them. Simply saying "I want torque" means nothing. You have to specify where you want it. On a car that revs to 7500 rpm you will generally always have a higher HP # unless you are choking the engine in the upper rpm range. Look at the s2000's engine. It has low torque, but this torque is carried out all the way to redline. This creates a huge HP number of 240HP. F1 cars rev at least twice as high and generate even more HP compared to their torque. If what you desire is more torque in the lower rpm range, then a positive displacement supercharger is your best bet. If sized properly you wont be suffocating the engine or generating too much heat in the upper rpm range and you will have lots of torque down low. |
#58 | |
Pro Subie Engine Nerd
Drives: empty spot for an FR-S/BRZ
Also, more air and more fuel (at the added few CC's) doesn't not mean more power. There is a lot more to an engine than that when you are talking volume changes that are this small. With the added volume, that can also mean more residual gas too, so you how have a lower % of your volume being fresh air and fuel. With that being said, you also said that you would have lower temps with a lower compression ratio. With all things being equal, I would agree. However, as stated, not all things are equal. You may have a nice 'chunk' of your now being hot exhaust (residual gas). ...just telling the rest of the story
#59 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#60 |
Drives: GTS86
It's really a problem only in summer heat
#61 |
Drives: BRZ WRB
Could anyone recall maximum psi proven which could be run without detonation on 93 \ stock motor \ upgraded fuel injectors&pump ?
What's the record by now? @Visconti , John, what's your experience? Last edited by MSTiFK8R; 03-12-2013 at 08:20 AM. |
| The Following User Says Thank You to MSTiFK8R For This Useful Post: | congiiee (04-06-2014) |
#62 | |
Drives: WRB Subaru BRZ
#63 |
Thanks
Necro master
#64 |
Drives: Asphalt FRS
Too many variables really, but I am running 11-12 on 93 with mine. The car seemed to like this the best with my small turbo. 15 an up, we did see two counts of knock. One below 4500rpm, and one about 6k. So we turned it back down. However, there is a member on here running 20psi on pump safely according to his tuner.
#65 |
Boosted Member
Drives: 2013 Subaru BRZ
I am running ~22psi on stock internals on 93 octane, and there is still headroom there before it was showing knock. Been running it like this for a couple months now. Before that I was running 17psi. FWIW, I am running straight 93. Not the "This gas may contain up to 10% ethanol" crap. How much of a difference that makes - ![]() Now, I don't know how long it would hold up in a track setting. This is why I am building the motor though - I will probably stay about the same power (maybe a bit more), just with a bigger margin for error and better durability. I have plans for getting into going to the track by fall or maybe next spring at the latest. To be honest, my biggest concern is cooling.. the engine seems to be doing fine (for the street) at these power levels. But again, 15 seconds of running thru the gears at 22psi and I am doing like 150mph, and thru the twisty back roads it doesn't see full boost for long at all so can't exactly say what it will do in a track environment where it is at the limits for a long period of time which creates a lot of heat.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#66 |
Junior
Drives: a car
#67 | |
Drives: 2014 FRS
Do you have any ecutek logs from round the town stops or dyno power runs to share? Id like to compare with what I see in mine. Thanks. |
#68 | |
#69 |
Drives: 2014 FRS
http://www.ft86club.com/forums/showt...ght=woode+dyno
He also has a dyno sheet if you look for it. I want tuning logs..
| The Following User Says Thank You to onzippy For This Useful Post: | congiiee (04-06-2014) |
#70 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
In your example, the calculation would be 1.68 X 10.5 = 17.64! 1 bar boost (approx. 14.7 psi) doubles effective CR. Obviously, if you double the density of the intake charge, you will double the effective CR. "Effective Compression = ((Boost PSI / 14.7) + 1) * Current Static Compression Ratio" Here is a simple calculator for determining effective CR: http://www.gtsparkplugs.com/Effectiv...ssionCalc.html |
| Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? | HitTheGas | BRZ First-Gen (2012+) — General Topics | 12 | 02-21-2012 01:24 PM |
| Turbo FR-S | Mino | Engine, Exhaust, Transmission | 24 | 12-16-2011 08:42 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| turbo yes | BMWDAD | BRZ First-Gen (2012+) — General Topics | 79 | 12-06-2011 12:58 AM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
