| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#29 |
Drives: FRS :D
LED is gonna be the new standard I think soon considering higher end brands are already messing around with laser headlights and stuff (BMW) and they are going into production cars already (i8 will have laser headlights)
Out of the FRS game
#30 |
Softparker
Drives: 2002 Mazda Miata
Cost prohibitive for mainstream cars. If there is a "fad" for LED headlights, it'd be with the retrofit guys, and most of them are paying way too much to do it wrong anyway. If the car was designed to make use of it, great. Otherwise, it seems like a waste and a hassle just to look cooler?
BMW's already 1up-ing the LEDs anyway. http://wot.motortrend.com/bmw-shows-...rk-126103.html |
#31 | |
2 wheel member
Drives: JZA80, 997.1, Taco
LED headlights are brighter than xenon and are more efficient. They may look cooler b/c they are indeed running cooler!
#32 | |
Adventure Enthusiast
"The Jetsons" must have been their crystal ball.
"I say why do you care what other people think about you when driving your car, why can't you just enjoy it for what it is and have fun with that?" - Carlos Lago, Motor Trend |
#33 |
Praise Helix!
The Prius has LED headlights as an option. If I remember correctly, it's a dual projector setup. One projector for front throw and a second diffused projector for fill lighting.
I like HID, and after having a car with a proper HID (as in OEM, not this "shove this kit into a halogen projector/reflector") setup I'd rather have it than halogen. But if LED were an option it'd be nice. Probably never have to change the bulbs and low power consumption. I imagine that the biggest issues to overcome are heat management and costs. Same reason that LED home-use bulbs are expensive and bulky. |
#34 |
Drives: '06 AM V8V Coupe
I call bullshit on the BMW laser thing, 2 times the efficiency despite having to excite a phosphor, bullshit. If they are using solid state lasers, there is no way a good white LED that is 3 colors mixed together would be less efficient than a solid state blue laser that loses part of its energy through the phosphor. If it's a gas pumped laser, efficiency is possible but those have questionable durability and are bulky.
#35 |
Drives: FRS :D
real facts or marketing trend/hype
either way laser headlights is going into production cars
Out of the FRS game
#36 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
For parts of the world where it snows part of the year, LED head-units wouldn't create enough heat to melt the snow build up in front of the lights.
This was the case when they installed LED traffic lights in some parts of the US. The build up of snow in the openings made telling what colour the light was nearly impossible. ![]() Although this is an issue that can be easily fixed if addressed properly - but can lead to a lot of recall's and accidents if not noticed beforehand. - just my 2 cents |
#37 | |
Drives: RX-8
. Those old 'unintended consequences' rearing their ugly head again lol! At least there shouldn't be ice forming on the LEDs, just snow that can blow away.
#38 | |
Hook 'em
#39 |
Drives: 2013 Subaru BRZ MT Limited
As someone who works in the technical side of entertainment industry, LED are a big part of what I do.
The current problems with LED's that need to be overcome before they become completely mainstream (they are VERY VERY close) are mainly heat and being able to be focused as well as cost. You wouldn't think Heat would be a problem with LED's, however it's a HUGE problem, LED's have such a narrow operating range for tempurature, the high powered LED's you see in headlights and some lighting fixtures require large heatsinks which take up space, making them difficult to integrate into a small headlight enclosure. That being said, major strides have been achieved within only the last 2 or 3 years, especially in the entertainment industry where are are starting to see more and more LED based high powered fixtures. For instance the Vari-Lite VLX which contains seven 170 watt LED's, in order to keep the LED's cool enough the fixture has a built in water cooling system. In cars the problem comes from fitting a heatsink into a small headlight enclosure and also trying to keep LED's cool in a hot engine bay. However I don't see these being major issues for very much longer, in fact I wouldn't be surprised if the 2nd Gen FT-86 or even the TRD/STI version had LED Headlights. Focusing LED's is the other problem, LED's flood light everywhere in all directions making it difficult to build a reflector to focus the light only where you want it to go. Unlike normal filament based light sources where most of the light irradiates out of the sides of the lamp. This would kill any DOT approval that could be given to LED's. Again however major strides have been made in this front using micro reflectors built into the LED's themselves, they are now more easily focused so I don't really see this being a problem for much more than 1 or 2 more years.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#40 |
Hook 'em
Why can't they just use multiple LEDs with narrow viewing angles to focus light into a lense? I'm not very up to date with the high wattage LEDs, most of the work I've done with them involve the small low powered ones and surface mount stuff.
#41 |
That is basically whats being done, but LED's naturally are wide output light sources. They output in all directions, so like I said the newer ones are using micro-reflectors built into the LED's themselves to create narrow angle output, which they can then use to focus the light.
#42 | |
Drives: RX-8
Like these, some focused for low beam, some for high.
![]() Quote:
| What's up with Japanese cars and headlights? | CyberFormula | Other Vehicles & General Automotive Discussions | 22 | 04-14-2011 12:20 AM |
| What did you think about this year's automotive super bowl commercials? | iff2mastamatt | Other Vehicles & General Automotive Discussions | 5 | 02-08-2011 01:02 PM |
| Subaru's FT-86 Version still alive and coming confirms Automotive News | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 10-19-2010 06:19 AM |
| A question regarding xenon headlights | Go Mango | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-14-2010 09:14 PM |
| Top Automotive Fails of 2009 | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 8 | 01-28-2010 07:13 PM |
