Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 03-08-2013, 03:49 AM   #71
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
Originally Posted by sav View Post
Those are very nice but I still want the OEM DRL to work properly. I know how to wire them, I just need to figure the pins on the headlights out.
our hopes rest with you @sav
Vladror is offline   Reply With Quote
Old 03-08-2013, 04:21 AM   #72
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Haha I'm just scraping up the courage to do this.
The plan is to rewire them with a relay. IGN on, DRL in high/bright mode. Headlights on, DRL in low/dim mode. Got that part figured out, I just don't know what the pins are on the headlights so I'd have to sit with a multimeter and test.
I'm also trying to source a "jumper cable" that fits between the headlight and harness so I wouldn't need to cut any wires. Zero luck to date.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-08-2013, 04:33 AM   #73
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
What if we ask Communica to make one?
GeeTee86 is offline   Reply With Quote
Old 03-08-2013, 04:35 AM   #74
sav
sav's Avatar
I'm not sure if they manufacture though? We need very specific male/female connectors.
95RON SAV Tuned
Old 03-08-2013, 04:38 AM   #75
GeeTee86
86 Nut
GeeTee86's Avatar
they do make up wiring kits, just not sure if they would have those connectors
Old 03-08-2013, 04:39 AM   #76
sav
sav's Avatar
Here is the connector:
95RON SAV Tuned
Old 03-08-2013, 04:43 AM   #77
sav
sav's Avatar
That's the problem. I've been through almost the whole of Alibaba.com without any luck.
I'll contact the headlight manufacturer and ask if they could provide something.
95RON SAV Tuned
Old 03-08-2013, 05:19 AM   #78
Mike Hoxbig
Mike Hoxbig's Avatar
I don't understand something - if the guys overseas can go in to a dealer to have it disabled, why can't we go in to have it enabled? Is it a case of "you're South African, so you have to take it up the nought by default"?
Mike Hoxbig is offline   Reply With Quote
Old 03-08-2013, 05:36 AM   #79
sav
sav's Avatar
Not sure, but we've had a look and there is no dealer function anywhere to switch them on.
Overseas they were on by default and then there was a recall with an ECU replacement to enable the dealers to switch them off.
95RON SAV Tuned
Old 03-08-2013, 05:45 AM   #80
sav
sav's Avatar
Originally Posted by HRTROB View Post
I have managed to enable the LED DRL strip to come on at full brightness whenever the engine is on and the parking brake released
Open the fuse box on the right hand side of the engine bay and plug in a relay on the emptly slot for the DRL. You can test it out by unplugging the horn relay and plugging it into the DRL slot. Start thr car, release the handbrake and the DRL should activate. This was done to my Philippine spec car, I hope it works for you SA guys. Enjoy!
@HRTROB I can't remember if I've asked before - before adding the relay, did your LED lights work with the headlights switched on?
95RON SAV Tuned
Old 03-08-2013, 05:53 AM   #81
GeeTee86
86 Nut
GeeTee86's Avatar
Mike as I understand the SA versions dont have the body control unit to make this work.
Old 03-08-2013, 08:08 AM   #82
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yup they worked before adding the relay. They would light up in parking lights mode and when you switch on the headlights.
Have you guys tried hooking up techstream to your cars? There might be an option there to activate it.
HRTROB is offline   Reply With Quote
Old 03-08-2013, 08:16 AM   #83
GeeTee86
86 Nut
GeeTee86's Avatar
we did, no such option
Old 03-08-2013, 08:31 AM   #84
sav
sav's Avatar
Yep, really annoying.
95RON SAV Tuned
Cool feature of the daytime running lights! eriktherod Scion FR-S / Toyota 86 GT86 General Forum 26 08-31-2014 11:28 PM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
