#71 | |
Drives: Toyota 86 M High - Dark Grey
#72 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Haha I'm just scraping up the courage to do this.
The plan is to rewire them with a relay. IGN on, DRL in high/bright mode. Headlights on, DRL in low/dim mode. Got that part figured out, I just don't know what the pins are on the headlights so I'd have to sit with a multimeter and test. I'm also trying to source a "jumper cable" that fits between the headlight and harness so I wouldn't need to cut any wires. Zero luck to date.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#73 |
86 Nut
Drives: 86 Satin 6MT High
What if we ask Communica to make one?
#74 |
I'm not sure if they manufacture though? We need very specific male/female connectors.
95RON SAV Tuned |
#75 |
86 Nut
they do make up wiring kits, just not sure if they would have those connectors
#76 |
Here is the connector:
95RON SAV Tuned |
#77 | |
I'll contact the headlight manufacturer and ask if they could provide something.
95RON SAV Tuned |
#78 |
I don't understand something - if the guys overseas can go in to a dealer to have it disabled, why can't we go in to have it enabled? Is it a case of "you're South African, so you have to take it up the nought by default"?
#79 |
Not sure, but we've had a look and there is no dealer function anywhere to switch them on.
Overseas they were on by default and then there was a recall with an ECU replacement to enable the dealers to switch them off.
95RON SAV Tuned |
#80 | |
95RON SAV Tuned |
#81 |
86 Nut
Mike as I understand the SA versions dont have the body control unit to make this work.
#82 | |
Drives: Toyota 86
Have you guys tried hooking up techstream to your cars? There might be an option there to activate it. |
#83 |
86 Nut
we did, no such option
#84 |
Yep, really annoying.
95RON SAV Tuned |
| Cool feature of the daytime running lights! | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-31-2014 11:28 PM |
| ***FR-S/BR-Z LED Daytime Running Lights 6K White*** | Vicious LED | Exterior Parts - The Rest | 7 | 10-14-2012 04:38 PM |
| daytime running lights | JDMrolla | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-06-2012 11:09 PM |
