Old 03-05-2013, 01:07 AM   #29
OrbitalEllipses
Drives: Attitude
Whomever said they wanted STI arms: Japanparts.com just posted these http://www.japanparts.com/db/partsli...EY=484-013-008
20valvewynn83 (03-05-2013)
Old 03-05-2013, 01:33 AM   #30
Hanakuso
What's the difference between these? Totally different part or just another STI option?
http://www.japanparts.com/db/parts_d...=&SEARCH_page=
Hanakuso is offline   Reply With Quote
Old 03-05-2013, 01:50 AM   #31
OrbitalEllipses
Drives: Attitude
RaceComp has those so they're better equipped to answer... but the one you linked is 4 arms not just the 2 lower control arms.
$250 isn't a bad price. You'll have to remember they're not adjustable though (IIRC); just a pillowball.
Old 03-05-2013, 02:22 AM   #32
Hanakuso
But it replaces the same part?
Old 03-05-2013, 11:26 AM   #33
OrbitalEllipses
Drives: Attitude
The big arms are both LCA replacements. The $500 one also includes what they're calling lateral links, from what I'm deciphering of the description.
Old 03-05-2013, 03:13 PM   #34
robispec
Drives: Black frs project
for clarity the rear suspension has 4 links the "genaric" nomenclature for thes arms is as follows:
the arm everyone is talking about here is the CAMBER arm just because the oems provides no adjustment doesn't change the name lol
The arm parallel to the camber arm is the TOE arm
The only arm going forward is the TRACTION arm
the arm with the highest conection (really a combination of two arms) is the UPPER arm...
please continue discusion.. there ARE NO LATTERAL LINKS in this multilink rear suspension..(they are usually reserved for a strut rear suspension design only).
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
WillRacer1jz (03-09-2013)
Old 03-05-2013, 06:12 PM   #35
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
corrected the title Robispec, thanks
aside from adjustable CAMBER ARMS, what else do I need to run, modify to get grip back there?
Huehuecoyotl is offline   Reply With Quote
Old 03-05-2013, 07:56 PM   #36
OrbitalEllipses
Drives: Attitude
Yeah, I thought it was funky that they were calling them lateral links as this isn't a strut type suspension. As I said, it was their description, but thanks much for the clarification Robi.
Old 03-07-2013, 12:25 AM   #37
uncivilised
Drives: 86 GT
dumb question (sorry)
do those angled camber arms like the stance ones that are sold used as a roll centre adjuster for the rear?
uncivilised is offline   Reply With Quote
Old 03-07-2013, 12:49 AM   #38
robispec
no the
'drop" damper allows a longer damper to be run important in monotubes with limited damper length like the frs/brz/gt86
uncivilised (03-07-2013)
Old 03-07-2013, 01:00 AM   #39
jamal
jamal's Avatar
Drives: Legacy GT
The only way to alter the roll center or other geometry of the rear would be to change where the pivot points are. Not really easy to do on the rear suspension of these things. You could do it with offset camber bushings in the upper arm, or by drilling a new mount in the subframe, or with a custom billet upright (MSI makes them and can do that for you, but it's $$$$). This would also change the camber curve and anti-geometry.
The angled arms are nice, especially on a lowered car, because they give you extra bump travel.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
Old 03-07-2013, 01:50 AM   #40
uncivilised
Drives: 86 GT
awesome thanks guys. i figured that but thought i would ask
Old 03-08-2013, 10:20 AM   #41
Paragon
Guest
Posts: n/a
I have the cusco ones and they are really hard to adjust without taking the spherical bearing end off?
■■ Stance Lower Control Arms & Stance Coilovers ■■ FREE SHIPPING - Photos and Video. FT-86 SpeedFactory Brakes, Suspension, Chassis 338 09-30-2016 04:46 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 02:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 06:28 PM
Enjuku Racing - NRG/DME Rear Lower and Toe Arms ** New Product ** Enjuku Racing Brakes, Suspension, Chassis 0 10-17-2012 12:55 PM
