Old 03-03-2013, 02:45 PM   #1
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
My DEAD FRS Had to be Taken to the Dealership Yesterday
Yeah, yesterday was just one of those days I should have just stayed on the couch and watched Top Gear on XBL. But, I couldn't resist my local SCCA Solo Test and Tune day even though it was 35 degrees outside and sleeting on and off.
The morning started off ok and the car was running flawlessly. I was even able to post a few times on the "timed track area" that were impressive enough to make a few others in the STX class dread the day I get new tires! A couple trips around the skid pad and around the faster slalom courses and I thought that I would take a break for a while and watch some of the other drivers run around the timed section.
After about 30 minutes the cold and boredom started to set in so I went back to the car to get in a few more runs and when I turned the key, it started, sputtered and died. odd... After that, the car completely refused to fire up. It would crank and crank but no fire. That was the time when I watched a new kid in his MR2 run over my spare tire and jack that I had sitting near my car. (no, I didn't kill him but I wasn't in the best of moods). One of the guys had a scanner so we hooked it up to the car to look for codes or problems and nothing. As far as the ECU was concerned, the car was perfectly fine.
Fast forward two hours later, car still won't start so I finally said "F-it" and called roadside assistance. They came, got the car and the driver, being a fellow enthusiast graciously didn't tell Toyota where the car was or what I was doing with it before it died!
So I get a call from Toyota later telling me that they got my car all safe and sound and wanted to know what was wrong with it. I told them and he said, "that's strange. It started up just fine and runs perfect!". No CEL's, no codes, no evidence that anything was wrong at all! So when my wife took me to the dealer to pick up the car I chatted a bit with the service guy and he said it may have been possible that the vehicle disabling system may not have recognized my key and killed the fuel pump.
Car is still running fine the next day and no problems.
Anyone else have or heard of a problem like this?
Scott
naikaidriver is offline   Reply With Quote
Old 03-03-2013, 03:43 PM   #2
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Engine likely flooded due to poor cold-start programming.
Actually, I've suspected this as an issue because my BRZ has sputtered on startup on occasion. Kinda ghetto for it having 3k miles on it. Makes you wonder how this thing will run with 100k miles.
But many imports I've owned have had these sorts of issues on cold starts. Not sure why. But if it does it again, try utilizing the flood control function. WOT while cranking for 15-20 second intervals should clean out any excessive fuel from the cylinders.
My wife's car didn't start doing this sputtering thing until we switched to ethanol/oxygenated fuels.
Coheed is offline   Reply With Quote
Old 03-03-2013, 04:28 PM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
To the people with cold start issues...have you tried priming the fuel system by turning the key to ACC for a couple of seconds and then cranking?
I had to do this with my Civic when starting in very cold weather sometimes.
Old 03-03-2013, 04:35 PM   #4
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I cant believe some people think 35F degrees is cold... They are too spoiled.
chenshuo is offline   Reply With Quote
The Following 7 Users Say Thank You to chenshuo For This Useful Post:
ftc~brz (03-06-2013), HunterGreene (03-07-2013), LeeMaster (03-05-2013), microbionic (03-07-2013), Rayme (03-05-2013), SkAsphalt (03-08-2013), tripjammer (03-07-2013)
Old 03-03-2013, 04:47 PM   #5
blackraven1425
Drives: raven at
I never had to do this on either of my Civics (05 and 08ish) or the CR-Z. In the FR-S, I've done this lately, and it seems to let it crank easier than just going straight to cranking. I still have a couple of minor misses every startup, though it seems to be less than before.
blackraven1425 is offline   Reply With Quote
Old 03-05-2013, 06:54 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
hmm weird..car hates owner? j/k hope everything is ok now
Old 03-05-2013, 07:09 PM   #7
Liquidsnake
Drives: "I drives like a Porsche"
Bro 50 degrees in Los Angeles is cold. Heater time.
Liquidsnake is offline   Reply With Quote
The Following 6 Users Say Thank You to Liquidsnake For This Useful Post:
D1cker (03-06-2013), russv (03-05-2013), Sportsguy83 (03-06-2013), suaveflooder (03-05-2013), Wes (03-05-2013), whataboutbob (03-06-2013)
Old 03-05-2013, 07:28 PM   #8
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
I agree, here in Oklahoma, that simply 'chill-y' when it dropps to 6, THEN we consider that cold. But I imagine you up there in Canada have differing levels of tolerance.
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
NemesisPrime909 is offline   Reply With Quote
Old 03-05-2013, 07:30 PM   #9
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
50 degrees in Seattle = T-shirt time!
TennisHsu is offline   Reply With Quote
The Following 2 Users Say Thank You to TennisHsu For This Useful Post:
LeeMaster (03-05-2013), TommyFive (03-05-2013)
Old 03-05-2013, 07:42 PM   #10
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
You guys are bonkers.. its 64 out today and I stay rocking sweatshirt n sweat pants
Jared0934 is offline   Reply With Quote
The Following User Says Thank You to Jared0934 For This Useful Post:
Wes (03-05-2013)
Old 03-05-2013, 07:51 PM   #11
OrbitalEllipses
Drives: Attitude
It hasn't broken the 40s for quite a few weeks now, dipping into the teens on a rare occasion. That's t-shirt weather you're talking about.
Old 03-05-2013, 08:19 PM   #12
#87
I usually post drunk
#87's Avatar
I had multiple crank start once but I noticed I had just put the key and cranked really fast. Now I turn to ACC and don't crank until I hear the fuel pump finish priming. When I do it this way I haven't had any problems.
#87 is offline   Reply With Quote
Old 03-05-2013, 08:30 PM   #13
OrbitalEllipses
Drives: Attitude
I haven't bothered checking, but can anyone confirm pressing the start button twice without depressing the clutch does the same thing? I believe that's ACC power, but I always just start the car.
Old 03-05-2013, 08:30 PM   #14
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i was in LA for vacation last christmas. it was so warm for me. we rent a convertible and had the top down the whole time and we were wearing just a shirt. the locals look at us weird.
Hit and run on my FRS yesterday yamaha16bw Scion FR-S / Toyota 86 GT86 General Forum 28 03-05-2013 10:48 AM
Checked out an FR-S and BRZ yesterday, parked my MR2 next to 'em Turbowned New England 6 06-04-2012 11:08 AM
Picked up the FR-S yesterday... Suiris Scion FR-S / Toyota 86 GT86 General Forum 9 06-03-2012 06:23 PM
Picked up my BRZ yesterday mechaghost BRZ First-Gen (2012+) — General Topics 132 05-15-2012 05:07 PM
Sat in FR-S yesterday Arthur Scion FR-S / Toyota 86 GT86 General Forum 35 04-11-2012 01:50 AM
