Old 02-27-2013, 07:37 AM   #1
SloS13
Drives: 2013 FR-S whiteout
Oil smells like fuel
FR-S manual with 5500miles
Oil smells like fuel. Anyone else?
SloS13 is offline   Reply With Quote
Old 02-27-2013, 07:52 AM   #2
roflcopter
Gold Member
roflcopter's Avatar
Drives: 2013 Whiteout FR-S
I changed mine at 1500 and it smelled strongly of petrol. I don't think I warmed it up like you're supposed to though, if I drove it for 15 minutes I'm sure the PCV or whatever this car has would have taken care of it.
roflcopter is offline   Reply With Quote
Old 02-27-2013, 06:02 PM   #3
SloS13
Brought it to the dealer. Initially two service employees agreed the oil smelled strong of fuel. After they check it out, the mechanic had me smell a jug of new oil compared to my dipstick. My dipstick smelled like gas, jug of new oil didn't but he claimed he couldn't smell gas. I'm going to send some off to get tested.
Old 02-27-2013, 09:03 PM   #4
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
How do you have that many miles when you bought your car last Sunday? I'm assuming you bought it used?
Subie is offline   Reply With Quote
Old 02-27-2013, 09:20 PM   #5
zooki
Drives: waiting on a 2021...
Was the car fully warmed up? From what I understand, cars with direct injection have a little more oil contamination when the car is cold, due to spraying fuel directly into the cylinders. Once the oil gets up to operating temperature the lighter volatiles like gasoline will flash off and go through the PCV system. At least hats the way I understood it.
zooki is offline   Reply With Quote
Old 02-27-2013, 09:49 PM   #6
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Its pretty normal, try to smell some other car's dip stick. I sniffed all of my family's cars and all smiled like gas
shu5892001 is offline   Reply With Quote
Old 02-27-2013, 09:58 PM   #7
Captain Insano
Agreed. I thought this very common.
Captain Insano is offline   Reply With Quote
Old 02-28-2013, 07:37 AM   #8
SloS13
Yup bought it with 5k
Checked when warm. I guess I can buy that. Still getting the oil tested for peace of mind though.
I've changed my own oil for the past 20 years, never smelled oil that strong of gas unless I was running a crazy-rich tune.
Thanks for the replies
Old 02-28-2013, 08:30 AM   #9
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
fuel dilution of oil normal till rings break in
Huehuecoyotl is offline   Reply With Quote
The Following 2 Users Say Thank You to Huehuecoyotl For This Useful Post:
Grishbok (02-28-2013), MysteryMachine (05-07-2014)
Old 02-28-2013, 02:04 PM   #10
jeebus
My first oil change had a tiny bit of fuel in the oil, but the next one didn't. Hope your rings are seated properly.
jeebus is offline   Reply With Quote
Old 03-01-2013, 12:00 AM   #11
fistpoint
Drives: Supercharged Golf Cart
All this talk of sniffing dipsticks...and one guy sniffed his whole family's!
fistpoint is offline   Reply With Quote
The Following 2 Users Say Thank You to fistpoint For This Useful Post:
LeeMaster (03-10-2013), Razz (03-10-2013)
Old 03-02-2013, 12:48 PM   #12
Red John
and True Blue
Drives: Red 2013 BRZ Limited MT--sold 8/9
THIS ^^^
Improper break in procedure to blame?
I disagree with the owners manual recommended break in procedure, My opinion it leaves an important step undone.
Although I am new here, this isn't my first Rodeo.
I've built quite a few engines, mostly high horsepower with stock and aftermarket components.
I installed chromoly (hard) rings a few times before giving up on them after having repeated problems getting them to seat.
I am careful now to select rings that are cast iron composition, usually the top ring with a chrome surface.
When cylinder walls are new, they have a cross hatch texture that is produced by the final honing operation. The purpose of the final hone is to fine tune the cylinder size and to produce the cross hatch finish.
The function of the cross hatch finish (which disappears/wears away as the engine breaks in) is to abrade the edges of the top and second rings, this is what is referred to as "seating" these rings.
When a new engine with solid base (not roller cam) lifters is started, it must be run for a period of time (about 20 minutes at 2000 rpm) to break in the cam and lifters.
With roller cam setups and roller cam followers this step is not required, but a new engine must be run for a few minutes to run the builder/factory quality control procedures.
Nonetheless, Neither one of these break in procedures is performed with the engine under load.
The break in procedure for piston rings in a new engine is as follows. Take the vehicle on a section of straight road and perform a strong acceleration in a lower gear, 2nd is usually good, lots of torque usually available. At the top of your strong acceleration, allow engine braking to slow the vehicle down to where you would shift to a lower gear. Do this 2-4 times and then proceed with the gentle factory break in procedure. I would say that RPMs at the top end of your strong acceleration runs should reach 5000 on the Tach in this 7450 Redline engine. It won't hurt your engine one bit, Rather it will take advantage of the cross hatch finish's intended function while it is still new and not worn away yet.
ask me about new ring and pinion break in.
Red John is offline   Reply With Quote
The Following User Says Thank You to Red John For This Useful Post:
Jasper (02-15-2022)
Old 03-03-2013, 01:42 AM   #13
XPR Small Block
Drives: Scion Frs
remember guys every motor has blow by, this takes place on the compression stroke of the motor as the fuel/air compresses and fuel ignites. A little bit of that pressure gets past the piston rings causing that smell it will get way more potent if you fry your rings. your safe I would say
XPR Small Block is offline   Reply With Quote
Old 03-03-2013, 02:20 AM   #14
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
@Red John knows what he's talking about. My pops was an old school v8 guy and I spent quite a bit of time growing up wrenching and helping him build and machine engines. Most modern import engines and engines in general now have much tighter tolerances than the afformentioned v8s that being said I have seen some newer engines 2afze for example have ring sealing issues causing uneven cylinder wall wear/gouging so it is possible that is could be a ring seating issue. A bit of fuel smell is normal and I have also heard that di tends to dirty the oil a bit quicker but I can't speak from knowledge/experience on that one.
Question for the op is the engine using any oil? I would try driving it a bit and make sure the oil consumption is within spec before you start to panic.
-Mike
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
What fuel do you put on your FRS/BRZ? dhpinoy Southern California 61 06-15-2018 05:35 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
91 AKI Fuel on 86 VinPetrol Engine, Exhaust, Transmission 8 10-04-2012 09:45 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
FUEL JDMSushi AUSTRALIA 23 07-18-2012 11:01 PM
