#141 | |
Drives: 2001 Half Bagged Blazer
#142 |
Drives: N/A
#143 |
Hot Dog
Drives: quicker than arghx7
Wings, that is some hella chop right there, bravo!
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#144 |
MODERATOR-SAMA
Drives: Swagtron Scooter
thanks XD
#146 |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
WoW lives up to his name. lol
I wish I was cool enough to have an FR-S
#147 |
Drives: FRS :D
i thought that was real for a sec
wasnt the Gsport turbo?
Out of the FRS game
#148 |
Drives: 2013 Limited DGM BRZ
#149 |
Drives: car
You didn't read much of the article that came out of did you?
The authors took a Ponticac Solstice engine, a 2.0 turbo direct injected engine, and heavily modified it into a single cylinder research engine. They took the turbo off and essentially blocked off three cylinders. They deleted the cams completely and ran with fully electronic valves. They were investigating how much timing they can run with E85 on high compression pistons compared to running on 87 and 91 octane. Then they used the electronic valves to experiment with various unconventional valve timing strategies to reduce the effective compression ratio. The whole point was to investigate the concept of a high compression E85 n/a engine that could be detuned for pump gas by using a Miller cycle. Look at the piston designs. They started with the 9.2:1 and made some prototype higher compression pistons. Notice that the higher compression ones have smaller and smaller piston bowls. That will cause all sorts of mixture formation issues on the D-4S system. Pistons on direct injection engines are a lot more complicated. |
#150 |
Drives: RX8 S1
Mate you are amazing
I thought that was real Hell I still think its real. If you didn't post it I would argue it is real haha Whatever they are paying you its not enough
#151 | |
Drives: NA8C, GDB, and R50
![]() If I had an ae86 again, I'd buy his parts again
See My Album: http://www.ft86club.com/forums/album.php?u=949
#152 | |
Drives: N/A
#153 |
Drives: '06 AM V8V Coupe
That's with a different piston though, if you take the same piston and reduce compression by moving it down, then the injector doesn't spray completely into the dish anymore.
#154 | |
Drives: car
direct injection is a lot more sensitive to the shape of the piston crown because mixture formation is very different than on a port injected engine. |
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 09:53 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 10:22 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
| Super Bowl! | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 01-29-2010 05:02 PM |
| Super Lap Battle | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 0 | 12-10-2009 10:46 PM |
