| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#85 | |
Drives: FR-S, NA8, S13
| The Following User Says Thank You to ebphoto For This Useful Post: | RRnold (03-02-2013) |
#86 |
Drives: Toyota 86
18x9.5 +20
18x10 +22 On order... Keep your eye peeled |
| The Following User Says Thank You to blags For This Useful Post: | sal (03-02-2013) |
#87 | |
Drives: RB v1 FRS
#88 | |
Drives: RB v1 FRS
...I have people begging me not to lower my car more because they think it will ruin the car...fools..they also think the only purpose of camber is to make room in your fenders..
| The Following User Says Thank You to dobbrz For This Useful Post: | zenki_levin (03-02-2013) |
#89 |
Drives: Fr-S
I really can't tell the difference, i changed my wheels 2 weeks after car purchase. definitely more grip, as far as weight. the "sluggishness" is very unnoticeable.
"mr.Balloon hands, no way, get real..."
#90 |
Drives: AE86
Not sure if you would call them agressive but these wheels are my current favorite wheel for a normal body car
| The Following 7 Users Say Thank You to doricar For This Useful Post: | *KID* (03-04-2013), botbs (03-03-2013), HATED1 (03-02-2013), humanshield (12-01-2013), tintumz22 (03-05-2013), Zaku (03-02-2013), zenki_levin (03-02-2013) |
#91 | |
Drives: 2013 BRZ SWP 6AT Ltd
Ummm. No. This set-up is form over function. Negative camber is a function. = negative camber improves grip when cornering. This is because it places the tire at a better angle to the road, transmitting the forces through the vertical plane of the tire rather than through a shear force across it. Another reason for negative camber is that a rubber tire tends to roll on itself while cornering. The inside edge of the contact patch would begin to lift off of the ground if the tire had zero camber, reducing the area of the contact patch. This effect is compensated for by applying negative camber, maximizing the contact patch area. Note that this is only true for the outside tire during the turn; the inside tire would benefit most from positive camber. He likes form over function. You don't need to set-up any fr-s, 86 or BRZ to these specs to go out and drift. Negative camber is the only way anyone could fit a 10" and 10.5" under the factory sheet metal. 6" of negative camber with offsets at +12 and +17 isn't functional for daily driving. He is crazy low. These cars start life crazy low from the factory. That's kinda the point. We have a lower center of gravity than a Ferrari. All you need to do is get springs and voila, you are even more crazy low and entering supercar territory. He is only a couple inches off the ground. The only way to go lower would be bags and scraping. This kinda helps prove the point - Don't get me wrong. I love his set-up, appreciate the skill and craftsmanship that went into it. If I had silky smooth JDM roads to ride on daily I would consider a set-up this agro. My current set-up: Even he knows that it's not a functional set-up and is in the process of having a wide fender kit put on. He had the fronts on at the messe. ![]() And he wasn't sporting 6" of negative camber with the new fenders on. Last edited by Beyer Subaru; 03-02-2013 at 01:23 PM. |
| The Following 4 Users Say Thank You to Beyer Subaru For This Useful Post: |
#92 |
Drives: Argento FR-S
Those fenders are not Rocket Bunny, They are called Todorokki I believe and will be available soon. Definitely my favorite 86!
| The Following 4 Users Say Thank You to philstar For This Useful Post: |
#93 |
#94 |
Trackman
Drives: Raven Frs
Those fenders are sex for sure. And do help support nasty wide rims =)
#95 |
Lowered Lifestyle
Drives: Scion Fr-S
XXR 527 18x8.75 35mm all round with dunlop direzza dz101 225/40/18 all round also. Thinking of 5mm spacers in rear tho....
| The Following 3 Users Say Thank You to SMOKETREES For This Useful Post: |
#96 |
Trackman
Drives: Raven Frs
@SMOKETREES Hey are you using plastic or metal hub rings?
#97 | |
Lowered Lifestyle
Drives: Scion Fr-S
#98 | |
Trackman
Drives: Raven Frs
I have a set of 530s for the summer and i was thinking about buying stainless ones to replace the plastic ones i have. |
| Tags |
| dontlike?dontlookmoveon |
| Post the Wheels You want On your FRS/BRZ!! | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1738 | 10-11-2017 04:29 PM |
| RPF1 and PF01 aggressive fitment size requests | Crossover Auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-22-2012 02:30 PM |
| post VIN with any problem thread? | fistpoint | Issues | Warranty | Recalls / TSB | 0 | 10-04-2012 10:11 PM |
| Do aggressive offsets cause more debris to kick up into the paint? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-26-2012 10:03 PM |
| Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 02:20 AM |
