Old 11-15-2011, 08:57 PM   #141
TexSIN
TexSIN's Avatar
Drives: 2001 Half Bagged Blazer
Originally Posted by serialk11r View Post
I think you can't mess with the piston shape with D4-S, they don't use stratified charge but the piston is shaped so the direct injector + port injector create a very even distribution of fuel in the cylinder. If you remove the piston shape, don't expect the performance to stay the same; uneven AFR will promote detonation and poor combustion.
TexSIN is offline   Reply With Quote
Old 11-15-2011, 09:07 PM   #142
Allch Chcar
Drives: N/A
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-15-2011, 10:40 PM   #143
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Wings, that is some hella chop right there, bravo!
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-15-2011, 10:45 PM   #144
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
thanks XD
WingsofWar is offline   Reply With Quote
Old 11-15-2011, 11:01 PM   #145
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by TexSIN View Post
uh spam? what?
Old 11-16-2011, 02:43 AM   #146
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
WoW lives up to his name. lol
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 11-16-2011, 03:51 AM   #147
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
i thought that was real for a sec
wasnt the Gsport turbo?
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 11-16-2011, 05:24 AM   #148
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Originally Posted by Mr.Jay View Post
i thought that was real for a sec....
+1. Where can I buy one.
Zgrinch is offline   Reply With Quote
Old 11-17-2011, 03:15 AM   #149
arghx7
Drives: car
Originally Posted by Allch Chcar View Post
You didn't read much of the article that came out of did you?
The authors took a Ponticac Solstice engine, a 2.0 turbo direct injected engine, and heavily modified it into a single cylinder research engine. They took the turbo off and essentially blocked off three cylinders. They deleted the cams completely and ran with fully electronic valves.
They were investigating how much timing they can run with E85 on high compression pistons compared to running on 87 and 91 octane. Then they used the electronic valves to experiment with various unconventional valve timing strategies to reduce the effective compression ratio.
The whole point was to investigate the concept of a high compression E85 n/a engine that could be detuned for pump gas by using a Miller cycle. Look at the piston designs. They started with the 9.2:1 and made some prototype higher compression pistons. Notice that the higher compression ones have smaller and smaller piston bowls. That will cause all sorts of mixture formation issues on the D-4S system. Pistons on direct injection engines are a lot more complicated.
Old 11-17-2011, 06:07 AM   #150
70NYD
70NYD's Avatar
Drives: RX8 S1
Originally Posted by WingsofWar View Post
You jelly brz/frs has cant tarbo
Mate you are amazing I thought that was real
Hell I still think its real. If you didn't post it I would argue it is real haha
Whatever they are paying you its not enough
70NYD is offline   Reply With Quote
Old 11-17-2011, 06:39 AM   #151
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
Originally Posted by Major Clod View Post
Another Brisbane Beams owner here - I have a Blacktop 3SGE in my '76 RA23 Celica. Great motor for a small car - glad the FT86 is similar in output, though I have to admit I'm ever so slightly disappointed it's specs are just under the Beams which was released 12 years ago.
On all the talk about extracting power out of these - High compression, small capacity, direct injection - sounds like its going to be an expensive / complicated little motor to mod and tune in the early days. Here's hoping there are few brave souls out there that get the ground work going on discovering any potential this motor may have.
Unless you're really willing to pay someone money to essentially do all the RnD for you - you're better off swapping for a proven Subaru turbo motor now (if laws allow) - or waiting until there has been some solid development done on this engine.
For reference, one of the most powerful modded N/A beams motors here in Australia makes approx 190kw at the wheels - stock is around 110-120kw atw.
This is with TRD headers, custom quad throttles, dual stage injection, motec, cams, pistons, rods, head work, etc... Built over years of trial and error with multiple motors and thousands upon thousands of dollars spent. Significant power can be extracted but it's NOT easy and its NOT cheap for these sorts of motors.
Hey mate, I think you mean Glenn right. Man that guy helped me alot when I started modding my altezza powered ae86
If I had an ae86 again, I'd buy his parts again
EJ20 is offline   Reply With Quote
Old 11-17-2011, 10:21 AM   #152
Allch Chcar
Drives: N/A
Yes, I read the article, quite thoroughly actually. The point was that lower compression with DI wasn't a problem. People were being silly saying lower compression would be ruin the combustion when obviously it is fine as it doesn't disturb the dish shape.
-Allch Chcar
Old 11-17-2011, 11:48 AM   #153
serialk11r
That's with a different piston though, if you take the same piston and reduce compression by moving it down, then the injector doesn't spray completely into the dish anymore.
Old 11-17-2011, 01:00 PM   #154
arghx7
Drives: car
ding ding ding
direct injection is a lot more sensitive to the shape of the piston crown because mixture formation is very different than on a port injected engine.
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 09:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 04:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 09:46 PM
