Old 02-28-2013, 02:19 PM   #2241
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
Originally Posted by Ranatsu View Post
Yes I may end up doing the Koni inserts because it seems like an easy upgrade to me.
and uh the tires had an absurd amount of grip. So much I was almost thrown out of the seat.
I have front struts.....going rate is $75 each. And you can keep the springs because I'm not taking them off :p (Help me start building funds for my LS1 swap.)
2013 Raven 6MT, Daily Driven, Totaled (10-01-2013 r.i.p)
Project GT-R Killer (Currently in Progress.)
Ocho-Seis is offline   Reply With Quote
Old 02-28-2013, 04:25 PM   #2242
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
How has everybody's week been?
tuckdaddy is offline   Reply With Quote
Old 02-28-2013, 04:26 PM   #2243
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Originally Posted by tripjammer View Post
I am all down for the Works filter, I just want somebody to dyno it in real life. Its kinda pricy at over $70 though...unless you got a good deal. I heard they were in stock though...
Filter finally shipped out. A locked thread and a month later, im wishing i spent the money elsewhere but at least it's in the mail now.
Old 02-28-2013, 04:47 PM   #2244
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Cool...let me know bro!
tripjammer is offline   Reply With Quote
Old 02-28-2013, 05:13 PM   #2245
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
Stressed but glad this month is about over.
Argento ate6
mRdeMs83 is offline   Reply With Quote
Old 02-28-2013, 05:41 PM   #2246
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Will do just happy its hit the mail
Old 03-01-2013, 05:29 AM   #2247
johatan25
johatan25's Avatar
Drives: Lightning Red BRZ - Premium 6MT
@Extreme86
I noticed you have the WHITELINE KDT922... How much improvement did you feel in cornering/drive. I saw the video they have online, but I'd rather much have someone that has them installed tell me if they're worth getting..
I've also thought about their transmission bushing and possibly switching my rear shifter bushing... But I've been told drive feel gets a bit rough since the bushings are more stiff...
Anyone?
Mods done (RED), Mods to come(BLACK): LED Swap, GReddy SP Elite Exhaust, Leather Seats, TSW 18x8.5 + 235/35, MOTIV Over & Catless Test pipe, EcuTek 93 Octane tune, PERRIN Lightweight Pulley, PERRIN Intake Inlet + drop-in filter,, e85 fuel map, 5axis Spoiler?, Borla UEL Headers?
johatan25 is offline   Reply With Quote
Old 03-01-2013, 08:48 AM   #2248
BAS
Drives: Snow White
Originally Posted by johatan25 View Post
@Extreme86
Anyone?
Good to see someone else up at annoying hours, I am on call this week...so disaster.
Anyways, I have a buddy in Colorado that has a Perrin transmission/Cusco transmission collar support and the Perrin rear shifter bushing as well. In my opinion, its not noisy per say. I def think there is more vibration though, not too much for a daily driver though I thought. Really tighten things up well though and smoothed them out. Specially between 1-2 and 2-3, 2-1 during those cold mornings/startups
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
Old 03-01-2013, 11:20 AM   #2249
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
@Extreme86
Anyone?
Hey Joey! Yeah, glad you asked this question. First, you have to be very careful when installing this bushing kit if you are going to DIY. Once you get the upper disk in place when doing the rears....make sure the whole assembly is back up towards the body as far as it will go. (I eventually used a small spare jack.) Finger start the bolt and make sure, repeat...MAKE DAMN SURE you have it going in and threaded correctly. If you just shove it up and ratchet wrench it thinking the threads will connect; you will strip the seemingly soft threads on the body of the car (like I did on the first one) and then have to go out and buy a tap to clean out the damage!!! Huge pain in the a$$ for sure. I didn't see the threads/comments on ft86 about this issue until after I did it. Ugh. Pays to do research...like you are doing now!
As far as how this install affects the vehicle, it does tighten up the rear end as it removes some of the play on the axle assembly. Where you once had some rubber isolation/damping connected to the body of the car.....it is more of a solid connection with the 922s on there. The result in handling is that you now feel more connected to the rear end say when swinging around a corner and giving it gas. Closer to a solid axle American car feel in a way. On the last Twisted Sis run it felt a bit more twitchy when doing some high speed curves when nearing the limits...before entering the "drifting" zone so to speak. It made it feel like a different animal in that regard compared to earlier runs on the 3Sisters. Some may like that feel....I did not. I think there is better "control" in this situation without the 922s on the bushings (speculation - maybe because it would allow more body lean or twist for better balance - not as sensitive maybe? - more forgiving of driver input?). As a daily driver, the bushings make the rear of the car more bouncy when running at freeway speeds because of the lack of damping. For an autocross application, I think they would be of benefit especially with the addition of better rubber on the wheels. Also, these made the popping noises more apparent on the rear shelf deck that I had never really noticed before.
For me, I'm taking them off next week. I like the cornering feel for "city hot rodding" but, I prefer a more comfortable ride when cruising on the road as I'd rather do without the slight bouncy bouncy feel. For drifting, you'd probably want these. I'll sell um used for $30 OBO if anyone is interested in trying them out!!!
Extreme86 is offline   Reply With Quote
The Following User Says Thank You to Extreme86 For This Useful Post:
johatan25 (03-02-2013)
Old 03-01-2013, 05:21 PM   #2250
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Turn 15 row 3 section 8 at COTA! Mazda pro 1 race is about to start and qualifying is going to follow! So amped for tomorrow!
The Following User Says Thank You to tuckdaddy For This Useful Post:
Extreme86 (03-02-2013)
Old 03-01-2013, 05:56 PM   #2251
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
Guys, I thought I had the address, but can someone give me the address to Dynotronic's shop out in New Braunfels? Or directions from San Antonio? Thanks!
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
Old 03-01-2013, 06:02 PM   #2252
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
So who is down for a dyno day?
I talked to lonestar dyno and this is the response i got.
Originally Posted by lonestardyno
Hey Nate,
Sorry it took me so long to get back to you, I just finished rearranging some of my email hosting. Its all straightened out now.
Anyway, yes I would LOVE to host a day for y'all. The FR-S/BRZs have really caught my eye, it would be nice to get y'all in here to see what they can do. My rate for a dyno day is $60/car. That gets you 3 base runs for each car. My dyno can measure hp and torque (of course) along with boost psi and air/fuel ratios. All that info will be printed out on the graph for each car. Many shops in our area do not have the boost capability and if they do they charge extra a lot of the time to take those reading. Not sure if any of you guys have forced induction yet, just letting you know.
In addition if you can guarantee at least 12 cars or more I will provide food/drinks. That usually consists of pizza and ice chests full of water and soft drinks. Obviously other arrangements can be made depending on you needs.
What day/month are you thinking? Let me know.
So who is down and when do we want to do this?
Ricepuddin is offline   Reply With Quote
The Following 6 Users Say Thank You to Ricepuddin For This Useful Post:
Extreme86 (03-02-2013), Got3n (03-01-2013), johatan25 (03-01-2013), Ocho-Seis (03-01-2013), tripjammer (03-04-2013), tuckdaddy (03-01-2013)
Old 03-01-2013, 10:04 PM   #2253
Ocho-Seis
Ocho-Seis's Avatar
I'm down for dyno! !! 0
Old 03-01-2013, 11:59 PM   #2254
johatan25
johatan25's Avatar
@Ricepuddin
Down for it! But let's plan in advance... My schedule its kinda strict, so unless I'm off or have enough time to find cover, I can't make it!
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2321 12-24-2024 10:16 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 05:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 04:13 PM
