Old 02-27-2013, 08:30 PM   #29
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by apexaddict View Post
From my calcs, it shouldn't be. A 17x9 +42 with a 245/40/17 Dunlop Z1 fits snugly up front (only a few mm between the perch and the tire), but you'll have issues dialing in any sort of camber.
Thankfully, in STX, your options are open - you can take camber *out* with the lower bolts and then use camber plates up top. A bit more expensive, but certainly less expensive than coilovers.
This... or the little fact you aren't tied to a particular offset requirement in ST... Just go with a small spacer and longer studs. Fixed.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 02-27-2013, 11:22 PM   #30
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I may have to go with that. May have to just poke a bit.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-28-2013, 05:06 PM   #31
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
- Cost-effectiveness
I've been down the "money build" road a couple of times before, and I don't want to do that here. I've owned no less than two STU Evos that have had Moton or AST shocks, one-of-one sets of ultra-light 17x9 SSRs, or fancy custom sway bars made for them. I'm all for shiny cool things, but I've done that already and I personally think it was a colossal waste of money. I think there's a lot more value in a handful of well-selected, bang-for-the-buck parts than just throwing money at the car for every little detail and hoping it
^Exactly why I got rid of my STi.
I look forward to seeing your car at NORA this spring, I'll have to jump in for a ride. Do you plan on going to the Toledo Pro again and Wilmington national tour?
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 03-10-2013, 05:33 PM   #32
apexaddict
Well, as of yesterday, the car is now officially an STX car. I headed to Sam's shop in Brookville, PA on Friday afternoon, and we worked into the night to get the initial setup done to the car.
We learned a lot about the car in a few hours, with the most important of those things being the likely solution to the uneven rear camber issue. Lots of people have been reporting their rear camber settings to be pretty different from side to side - in some cases, up to a full degree difference. However, when we went to put in the Whiteline rear subframe inserts, we noticed that the rear mounts in the subframe actually have an oblong hole through their bushings. This would mean that you could jimmy the subframe around, and it's own alignment could affect the alignment at the wheels. So we did what we could to ensure the subframe was bolted down as evenly as possible, and when we put the car on the alignment rack the next day, the rear camber was damn near spot on; -2.59 on one side, -2.60 on the other.
I would recommend to anyone having rear camber symmetry issues to install the Whiteline collars - if you're going to mess around with the subframe, you may as well put them in. They are very inexpensive, the install is easy, and they should make it easier to correctly locate the subframe's positioning.
http://www.stranoparts.com/partdetai...252&ModelID=37
The next day, we put the car on the rack and started playing with ride height and alignment. Another interesting note about the rear suspension is that it is VERY sensitive to ride height. Sam's personal FR-S has about -2.2 camber in the rear - my car is less than 10mm lower and measured at -2.6. With that kind of camber change, I think a big key to getting the handling of these cars right will be in the rear spring rate. We'll see.
The alignment was pretty much dictated by the non-adjustable rear camber, so we ended up going with a bit more camber up front than I wanted (-3.0) to free the car up. That was the absolute max we could run on the KWs with the Whiteline hats, and the absolute max I was willing to run on a daily driver.
So far the car is a lot more fun and a lot more responsive, we will see how it does at a test-and-tune in Columbus on 3/30. Hopefully before then I will also have a couple more things, like a tune and possibly an exhaust.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
The Following 5 Users Say Thank You to apexaddict For This Useful Post:
colHolm (03-10-2013), GTB/ZR-1 (03-11-2013), heeltoe86 (03-31-2013), P@ul (05-12-2013), race2win (03-10-2013)
Old 03-10-2013, 10:17 PM   #33
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Looks good,
you can get more front camber if you use the subaru camber bolts also. (-4) Not that you want to run that on the street.
The rear suspension changes a lot with ride height, and during lift throttle.
The front toe doesn't change much at all with ride height or camber.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 03-10-2013, 10:22 PM   #34
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Car looks great! Thx for the tip on the rear camber issue. I'll need to get these from Sam ASAP.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-11-2013, 01:29 PM   #35
GTB/ZR-1
GTB/ZR-1's Avatar
Thanks again, Andrew & Sam--just ordered the bushings abt an hour ago--just in time for Dixie!
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
apexaddict (03-11-2013)
Old 03-12-2013, 02:13 PM   #36
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
OP are you signed up for the NJ Pro? I thought I saw a Strano Parts FRS on there.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 03-12-2013, 04:07 PM   #37
apexaddict
That would be me, yes.
Andrew P.
Old 03-21-2013, 01:20 PM   #38
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Cool I'll have to check out the set up when I'm there. Sam's bar is going on this weekend. I'll be at Metlife for the first NNJR event of the year.
Old 03-22-2013, 08:54 PM   #39
ButtDyno
ButtDyno's Avatar
Drives: 2006 Evo MR #7 STU
Hey, I resemble that remark
Subscribed, definitely want to see how this goes. It's a really good mission statement, something everyone building something like this should take a look at.
ButtDyno is offline   Reply With Quote
Old 03-31-2013, 01:07 AM   #40
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
First day for Andrew's car, and he let me come play too. Great battle, he got me by .134. Couple of National Champions having at it, lots of fun (even though I lost). , er..I mean
I'm sure he, and I, will have more to add soon.
Sam Strano is offline   Reply With Quote
Old 03-31-2013, 02:46 AM   #41
heeltoe86
heeltoe86's Avatar
Drives: 2012 Ultramarine FR-S
Haha...I was thinking the rear subframe moved on me after having gone off track at well over 90mph twice. I have uneven -3.6rr and -2.6lr. Will be ordering those whiteline collars and make the adjustments needed.
2013 Ultramarine FR-S daily/trackwhore
1986 Toyota AE86 (sold)
2007 Toyota FJ Cruiser (sold)
2006 Toyota Tacoma PreRunner (sold)
1996 Honda Civic (sold)
heeltoe86 is offline   Reply With Quote
Old 03-31-2013, 08:51 AM   #42
SVThis
SVThis's Avatar
Drives: Scion FRS
Question on the rear subframe. I'm having my car aligned this week. If running stock suspension can you still adjust the sub frame orientation without the Whiteline bushings if there is a camber discrepancy left to right? If you can what would be the procedure to do this? Thanks.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Ricepuddin's Build thread Ricepuddin Member's Car Journals 71 11-23-2019 10:22 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
My Whiteout 6MT build thread... jadewbj Member's Car Journals 10 01-04-2013 04:10 PM
