Old 11-09-2011, 06:27 PM   #127
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
how does KW convert to Wheel horse power? like what would the numbers be hp wise?
Syldrin is offline   Reply With Quote
Old 11-09-2011, 06:39 PM   #128
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
1 kilowatt = 1.34102209 hp
also Camp Pendleton huh? I'm 5 minutes south of there in Carlsbad... If you are a good marine (and over 21) you know where Henesseys, the Coyote, and the Boar's Crossing are... I'm pretty sure that their coordinates are taught in basic training.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-09-2011, 06:56 PM   #129
Syldrin
Troll Feeder
Syldrin's Avatar
i am not a marine i take care of them when they decide to go and get shot. i'm a hospital corpsman. but ya man i'm 25. my gps will find it.
Old 11-09-2011, 07:11 PM   #130
ryridesmotox
Ahh gotcha, well dude, I'm sure they appreciate your services more than the rest of us ever could. I was an EMT for many years, if/when you get out, I got a hook up at Pacific Ambulance, if you want to stay in the same field.
Old 11-09-2011, 10:47 PM   #131
Syldrin
Troll Feeder
Syldrin's Avatar
Yea they love us. It's a very humbling experiance to be in the same field as the legends I've come after. Pacific ambulance you say? I will most definatley would be interested that sounds amazing!
Old 11-12-2011, 11:50 PM   #132
LeeT
LeeT's Avatar
Drives: 2011 Mustang GT
No need to get your panties in a bunch people. The dynamic compression ratio is what you need to consider.
LeeT is offline   Reply With Quote
Old 11-14-2011, 02:26 AM   #133
arghx7
Drives: car
Sigh. Dynamic compression ratio. Don't take this the wrong way, but that's really not a metric that engineers use at all in practice. It's just stuff that people talk about on internet forums.
It is the brake mean effective pressure and indicated mean effective pressure, and indicator diagrams that are used in practice. Those require cylinder pressure transducers to actually use.
Old 11-14-2011, 07:52 PM   #134
LeeT
LeeT's Avatar
Don't worry, I didn't take it the wrong way. I don't mind technical discussion (bickering or not) :happy0180:.
I was referring to dynamic compression ratio (DCR) because I thought this thread was about boosting the engine. Looking back a few pages, I see that this thread has sort of turned into a discussion of power output and might be the reason behind your post, but I digress.
Solely looking at the static compression ratio (SCR) of 12.5:1 isn't the best way of determining if an engine can avoid detonation under boost. It simply is the ratio of cylinder volume at bottom dead center (sweep volume) divided by top dead center. However, this isn't the compression ratio the engine sees when its running. DCR is the compression ratio when you take into consideration the crank's position when the intake valve closes. The piston will already be traveling upwards when the intake valve closes, resulting in a smaller sweep volume. Because of this, DCR is always less than SCR. Simply put, there is less "squeeze" on the mixture, and therefore less heat, and subsequently less risk of detonation.
Old 11-15-2011, 12:52 AM   #135
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
Originally Posted by quik1987 View Post
Like this?
Similar... Without the turbo but with some intake plenums and a filter
Originally Posted by cyde01 View Post
I'd like to also some day, but i have a bad feeling this car is gonna be dbw. Lets hope someone makes a good itbs kit and an ecu that can tune it.
I'm sure it can't be too hard to convert throttle bodies to dbw. AFAIK dbw is essentially a stepper motor that controls throttle. Making an adaptor for it to hook up to ITB's shouldn't be hard, then you just have to get an ECU to control it (of which IIRC there are quite a few that can control both dbw and ITB's).
Snaps is offline   Reply With Quote
Old 11-15-2011, 07:26 PM   #136
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
You jelly brz/frs has cant tarbo
WingsofWar is offline   Reply With Quote
Old 11-15-2011, 07:49 PM   #137
Kostamojen
Thats a hellofa photoshop job right there.
Old 11-15-2011, 08:10 PM   #138
Snaps
Supra Owner
Snaps's Avatar
^ +1
WoW... You's crazy....
Old 11-15-2011, 08:27 PM   #139
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
KaliKev is offline   Reply With Quote
Old 11-15-2011, 09:26 PM   #140
Allch Chcar
Drives: N/A
Geez WoW, where did you get that?
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 09:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 10:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 05:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 10:46 PM
