Old 02-26-2013, 06:36 PM   #1
2_fast
2_fast's Avatar
Drives: FR-S 6MT Asphalt
Window going down on it's own.
I tried doing a search but couldn't find anything about the issue i'm having.The last few day my drivers side window has been dropping down just to the point you see daylight.This pretty much happens when car sits for a period of time.I have to click it up rest of the way when i start car after it sits.
2_fast is offline   Reply With Quote
Old 02-26-2013, 08:30 PM   #2
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
there's a good chance you have to reset your windows like this other guy had to: http://www.ft86club.com/forums/showthread.php?t=29861.
try following these instructions:
Originally Posted by Nate219BRZ View Post
Put car to on, engine off. Push and hold button down until window rolls down and you hear a click. Then hold window button up until it rolls up and you hear a click. Someone forgot to reprogram your window controls....
mezdup is offline   Reply With Quote
Old 02-26-2013, 08:52 PM   #3
2_fast
2_fast's Avatar
I've done the reset couple of times when windows won't go down but this happens after car sits.Wondering if window isn't going back up after i shut door.All the window functions work fine, window just seems to go down all on it's own.
Old 02-27-2013, 01:57 AM   #4
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Your car is secretly an autobot.
LeeMaster is offline   Reply With Quote
Old 02-27-2013, 04:09 AM   #5
2_fast
2_fast's Avatar
Good thing it's going in friday for condensation, just have them poke at this problem too.
Old 02-27-2013, 12:17 PM   #6
NOHOME
Drives: RAVEN
Yup, got that. Shows up as wind-noise. Far as I can tell, it is related to cold weather. Not sure if it is related to the issue where it stays in the lowered position, or is a separate concern.
For the most part, I observe it when it is cold enough that the window wont go down at all when you open/close the door.
NOHOME is offline   Reply With Quote
Old 02-27-2013, 12:58 PM   #7
GH05T
Undercover Batman
GH05T's Avatar
It could be a Decepticon.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
GH05T is offline   Reply With Quote
Old 02-27-2013, 02:56 PM   #8
Nate219BRZ
Nate219BRZ's Avatar
Drives: Rip 04 golf gti rip 05 scion TC
If you have your windows tinted. Go ahead and check the window switch in the door. It could be grounding/ not grounding on something? Causing the window to roll down like the doors open.
Nate219BRZ is offline   Reply With Quote
Window visors Kai Uhl Cosmetic Modification (Interior/Exterior/Lighting) 4 03-03-2013 09:35 AM
Window not sealing NOHOME Issues | Warranty | Recalls / TSB 9 12-12-2012 02:57 PM
What do you look at out your window? nzer Off-Topic Lounge [WARNING: NO POLITICS] 8 10-07-2012 01:59 AM
Fog on rear window JSK Issues | Warranty | Recalls / TSB 8 08-18-2012 02:23 PM
Pop out window brett_g Cosmetic Modification (Interior/Exterior/Lighting) 10 07-22-2012 10:42 AM
