Old 02-25-2013, 08:13 PM   #15
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
When is your 1st event?
I am trying to make it to the Ohio tour, we will see.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-26-2013, 12:02 AM   #16
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Originally Posted by Sccabrz192 View Post
Brad had the same philosophy with his 05 WRX that we used to run in 07-08 together. It was his only mode of transportation, so it had to function both duties. I think the big negative to this type of setup is (particularly in a WRX) the more street-friendly setup will tend to understeer a lot more than a no-compromises car when provoked, so you have to be extra careful not to overdrive the car, but if you can get it right, there is no reason you cant be AT LEAST competitive for trophies, or podiums.
I'm VERY intrigued to find out how the balance of the car turns out in STX form considering it is much more netural in stock form than the WRXs. :happy0180:
We already know. My car has had it's suspension done since about July last year. Pushy it is not. Numerous comparisons between other cars like the Corvettes and even Mr. Sparks' RX8 last fall.... not to mention the many cars I get to drive throughout the year.
Sam Strano is offline   Reply With Quote
Old 02-26-2013, 01:08 PM   #17
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I meant first hand
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 02-27-2013, 12:07 AM   #18
Sam Strano
Sam Strano's Avatar
Well, you can come drive mine if you want... In fact anyone passing through, or who'd want to come to the sticks of PA can come take a ride.
Sam
Old 02-27-2013, 12:08 AM   #19
Sam Strano
Sam Strano's Avatar
BTW, let me help add to Andrew's build thread.... His wheels:
Old 02-27-2013, 07:56 AM   #20
Simmons
Simmons's Avatar
Cool, this thread needed some pics.
Simmons
Old 02-27-2013, 10:22 AM   #21
djfuller
djfuller's Avatar
Drives: 2013 Subaru BRZ GBS Limited MT
Looking forward to following along!
I just started autocrossing last year so I am pretty new to the whole thing. I was running CS last year without any upgrades at all (including tires). I'm thinking I'm going to be switching to STX this year, just because some of the things I want to do to the car aren't allowed in CS, primarily the wheels I want to go with. I realise I'm not going to be competitive, but I'm just in it to have fun.
I do have one question for you guys. I would really like to change the header to a UEL setup, just because I like the sound better. Unfortunately, its looking like all of the UEL headers that are being developed are going to be catless. I looked at the rules and I think it would be ok, but I was just wondering what your thoughts were? I've got a cat back system right now, but the rest of the exhaust is stock.
Sorry for the thread jack!
-Dave
djfuller is offline   Reply With Quote
Old 02-27-2013, 10:45 AM   #22
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
-Dave
Nameless' header is catted
Ranatsu is offline   Reply With Quote
Old 02-27-2013, 10:50 AM   #23
djfuller
djfuller's Avatar
Are they doing an unequal length header? I see that they are doing the equal length one, but I prefer the sound of the unequal length headers.
-Dave
Old 02-27-2013, 03:20 PM   #24
Ranatsu
Cone basher
-Dave
They haven't yet, but I bet they will, and for STX you can run a catless header as long as you keep the second cat in the system within 6" of its original location.
Old 02-27-2013, 03:29 PM   #25
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Sub'd! I cannot WAIT to start my transition to STX but Im seeing my big hurdle, other than my lack of past experience, will be the fact Im planning on a Koni+Spring setup, less clearance. Hoping that won't be an issue when adding 9" wheels with -2.5F camber.
Looking forward to following this year with all of these Ft86 cars running STX nationally. Sure hope it doesn't get bumped to STR if it does too well!
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-27-2013, 03:37 PM   #26
djfuller
djfuller's Avatar
Oh cool. That's even better. Thanks!
Old 02-27-2013, 04:19 PM   #27
Ranatsu
Cone basher
Yea the rule just says
STX, STU – Any high flow catalytic converter(s) are allowed, but
must attach within six inches of the original unit. Multiple catalytic
converters may be replaced by a single unit. The inlet of the sin-
gle replacement converter may be located no further downstream
than 6” along the piping flow path from the original exit of the fi nal
OE converter.
Old 02-27-2013, 09:16 PM   #28
apexaddict
From my calcs, it shouldn't be. A 17x9 +42 with a 245/40/17 Dunlop Z1 fits snugly up front (only a few mm between the perch and the tire), but you'll have issues dialing in any sort of camber.
Thankfully, in STX, your options are open - you can take camber *out* with the lower bolts and then use camber plates up top. A bit more expensive, but certainly less expensive than coilovers.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Ricepuddin's Build thread Ricepuddin Member's Car Journals 71 11-23-2019 11:22 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
My Whiteout 6MT build thread... jadewbj Member's Car Journals 10 01-04-2013 05:10 PM
