Old 02-25-2013, 11:25 AM   #15
Visconti
Drives: 05 STi
Originally Posted by wparsons View Post
Anyone know if the Ecutek software runs ok on macs with windows in a virtual machine?
You'll need to be in boot camp for it to work correctly
John
Visconti is offline   Reply With Quote
Old 02-25-2013, 03:50 PM   #16
wparsons
wparsons's Avatar
^^ I'll see about that when I finally order a tune (no point with snowy roads )
I figured as much, but I'm stubborn and will still try to make it run through a virtual machine.
flickr
Old 02-25-2013, 03:53 PM   #17
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Go do a local tune. Always better than E tunes imho
86_ZN6 is offline   Reply With Quote
The Following 2 Users Say Thank You to 86_ZN6 For This Useful Post:
FR-S Matt (02-25-2013), SkullWorks (02-27-2013)
Old 02-25-2013, 04:05 PM   #18
FR-S Matt
+1
Nothing against FA20club or Visconti, but they both know they can tune better locally than anything. Local tunes are PERSONAL tunes for YOUR car with your mods. Nothing beats that. Most do updates for life too when you buy a tune.
Old 02-25-2013, 04:10 PM   #19
Xdragonxb0i
Drives: ex500r
Originally Posted by FR-S Matt View Post
+1
Agreed especially since your in CALI, Evasive motorsports could help you out.
Unfortunatly for me the closest tuner is about 7 hours so Fa20 or Visconti is the way to go for me
Xdragonxb0i is offline   Reply With Quote
Old 02-25-2013, 04:28 PM   #20
TemeCal
Drives: 86
John
While it does work in boot camp, it WILL 100% work in a virtual machine. I've tried it in parallels and vmware fusion.
@wparsons
So, yes, it WILL work in a virtual machine.
TemeCal is offline   Reply With Quote
Old 02-25-2013, 07:47 PM   #21
Visconti
Drives: 05 STi
@wparsons
Windows 8 doesn't work right in virtual machine and EcuTek also states they don't support it.
I would highly suggest just doing bootcamp
Old 02-25-2013, 08:13 PM   #22
BEERzed
Drives: BEERzed
I'm trying to work out how the new Ecutek license system works.
I understand that owners can now flash back to stock, which allows dealers to flash the ECU .. but can they then go back to their Ecutek tune?
What if I want to try a brzEdit or open source tune? Can I try them and then flash back to my Ecutek tune, or is that not allowed for some reason?
I'd be a lot more likely to try Ecutek again if I knew it didn't prevent me from trying other alternatives, should I ever want to.
I'd really like to hear from someone who has flashed an Ecuteked ECU back to stock, flashed a dealer (or other) tune over the top, then reinstalled their Ecutek tune.
Is it just promises, or has someone actually done it?
BEERzed is offline   Reply With Quote
Old 02-25-2013, 08:18 PM   #23
Visconti
Drives: 05 STi
What's your end goal?
If your dealer replaces the Ecu or flashes it then your Ecutek licensing is gone. You then have to contact your master dealer and get with them to get you a new license.
New licenses are only provided when proof of Ecu replacement or dealer reflash has been done.
So if your Ecutek tuned, flash back to stock and use brzedit you will lose your license.
John
Old 02-25-2013, 08:23 PM   #24
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
John
What is the likelyhood that a dealer can detect that you had a tune and just flashed back to stock prior to visiting them.?
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 02-25-2013, 08:27 PM   #25
Visconti
Drives: 05 STi
Flash can't be detected at the dealer level.
The dealer tools can see the checksum info and ram info in the Ecu.
During larger warranty claims , aka motor Subaru of American will ask the dealer to pull up some info which will tell them if the car has a stock or modified flash.
That being said the dealer can not flash over a custom Ecutek tune.. Only a stock a Ecutek flash.
Most of the time the dealer has problems with their tools so if they attempt to flash over a custom tune they'd blame their equipment before pointing fingers - trust me I know.
But the current recall replaces the Ecu not flashes
I've had a few customers have their custom tuned ecus replaced under this recall already.
John
The Following User Says Thank You to Visconti For This Useful Post:
Zgrinch (02-25-2013)
Old 02-25-2013, 08:37 PM   #26
TemeCal
Drives: 86
Well, I guess both of us should have specified the Win version. It works perfectly fine in Windows 7. Just flashed my car 5mins ago again.
Old 02-25-2013, 09:00 PM   #27
BEERzed
Drives: BEERzed
.. if your Ecutek tuned, flash back to stock and use brzedit you will lose your license.
Thanks for your honest response. It is appreciated.
Unfortunately, it means Ecutek is still not for me. I understand the concept of locking out competitors, but really good businesses don't need to do this.
I don't care what software a tuner uses. People who buy a car and own their ecu should have the freedom to choose the best tuner available at the time (without paying a new license fee to Ecutek every time they want to try an Ecutek tuner).
If this is a technical limitation and not a deliberate restraint on customer's choices, then Ecutek need to fix it.
Either way, thanks but it's not for me.
Old 02-25-2013, 09:20 PM   #28
swift996
swift996's Avatar
You might want to check out the Unichip offering, worth a look, not sure your goals.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Tuning for E85 Vs 91 Vicious LED Software Tuning 20 04-10-2014 10:56 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
Tuning Jordo! Engine, Exhaust, Transmission 54 09-05-2010 05:29 PM
