| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: S
Nitro, i just took the factory unit out and am about to put in a z140. it looks like theres one extra wire in the 6 pin connector. Did you find this? Is that for the amp?
Looking at your 6 pin connector, what is the orange wire for? Last edited by Iddoit2er; 01-12-2013 at 12:38 PM. Reason: Correction |
#30 | |
Radio wiring harness guru
Drives: 1996 SVX L AWD
The extra orange wire on the aftermarket 6-pin Toyota harness is the illumination(-) lead in Subarus. This wire is not needed by aftermarket head units. If your aftermarket harness (Metra, Scosche, etc.) has that, either insulate the end, or extract the whole pin/wire. You usually do want to use the illumination(+) lead, on the 10-pin harness. Sometime soon I'll post a real pin-out table, customized for the BRZ and FR-S.
#31 | |
Drives: S
Do you know if theres a reverse sensor wire? That wasnt on the wiring list i found. |
#32 |
Drives: Raven 6mt FR-S
Installing my pioneer HU soon. Thinking about running the iphone cable into my glove box.
#33 |
Drives: Toyota 86
#34 |
I have a iphone 5 and the cable isn't out yet. Im just running the usb extension inside the glove box and mounting it there.
#35 |
86TUP
Drives: 86 GT
great write up!!
The only thing i'm not too happy about is how far our the 2 din stereo sits with the factory brackets. There doesnt seem to be any others on the market which solve this problem....unless ive overlooked it somehow |
#36 |
Drives: Subaru brz
Great write up, I will just add my 2c. The wiring in the BRZ (european spec, premium) seems a little different: the yellow cable on the metra connector (70-1761) does not match with subaru's connectors. It took me two days of hair pulling to figure this out. You have to remove matra yellow cable from the 6 pin connector and place it in the 10 pin connector in such a way that it connects to subaru's orange cable.
Hope it will help someone. S. |
#37 |
Drives: Scion FR-S
Any body looking to get this head unit? I have everything you need. head unit, wire harness already connected to metra harness, gps antenna, the inserts around the head unit to fit the fr-s dashboard, the parking break relay. I bought this setup and then broke my iphone which is the whole reason i got this setup. I got a droid and just dont like how it connects with my droid. Asking $350 shipped. Pics to come tomorrow
#38 |
Drives: scion frs
bespoke radio
i have the base radio in my car im looking to get a bespoke radio any thing special i have to do?
does the bespoke radio come with nav? if yes any special antenna? |
#39 |
Drives: '13 Whiteout FR-S M/T
Sry to raise this thread from the dead. I followed it and got everything working except the parking brake bypass (PAC TR7). Hook black to black, red to res, white to lime green (ebrake), and green to blue/white stripe. Is there anything additional I need to do to get this working?
#40 | |
Shift it or lose it
Drives: 2014 FRS, 2003 Celica GT
You need a relay. |
#41 | |
#42 |
Drives: 2014 BRZ Limited 6MT
Just installed the pioneer avh-4200nex and used every thing in this write up he used. The only thing is my Sirius Xm is not even able to be selected now. Am I missing something to hook up to the oem Xm radio satellite?
| BRZ NAV/DVD bypass | Scooby South | Electronics | Audio | NAV | Infotainment | 88 | 02-24-2014 03:41 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
| Subaru iPod Connector Cable? | Kimsey47 | Audio/Visual, Electronics, Infotainment, NAV | 25 | 07-05-2012 02:49 PM |
| BRZ Nav Unit owner's manuals | eikond | Electronics | Audio | NAV | Infotainment | 0 | 04-11-2012 04:07 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
