Old 02-12-2013, 04:02 PM   #2003
dpgdave
Originally Posted by Ocho-Seis View Post
Photos? and will they need seat rails?
They're side mounted and come with the rails seen in the pics above
dpgdave is offline   Reply With Quote
The Following User Says Thank You to dpgdave For This Useful Post:
Ocho-Seis (02-12-2013)
Old 02-12-2013, 05:31 PM   #2004
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
I can dig the forecast! Will be washing the car today!
tuckdaddy is offline   Reply With Quote
Old 02-12-2013, 05:41 PM   #2005
johatan25
johatan25's Avatar
Drives: Lightning Red BRZ - Premium 6MT
How often are y'all doing oil changes?
Mods done (RED), Mods to come(BLACK): LED Swap, GReddy SP Elite Exhaust, Leather Seats, TSW 18x8.5 + 235/35, MOTIV Over & Catless Test pipe, EcuTek 93 Octane tune, PERRIN Lightweight Pulley, PERRIN Intake Inlet + drop-in filter,, e85 fuel map, 5axis Spoiler?, Borla UEL Headers?
johatan25 is offline   Reply With Quote
Old 02-12-2013, 05:44 PM   #2006
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
Oil change? whats that? Lol jk jk. I have had 2 and I'm at 18k Just had the second one done.....but I'm also running synthetic so IDk if that matters. (but around 5k-7k to answer your question.)
2013 Raven 6MT, Daily Driven, Totaled (10-01-2013 r.i.p)
Project GT-R Killer (Currently in Progress.)
Ocho-Seis is offline   Reply With Quote
Old 02-12-2013, 06:40 PM   #2007
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I did my first at 3000. Switched to Pennzoil Ultra 5w-20. I will run this for the 7500 interval, and then do a UOA.. I may try Motul 300v in the future.. Depends on the UOA.
Ranatsu is offline   Reply With Quote
Old 02-12-2013, 08:01 PM   #2008
tuckdaddy
Because Racecar
tuckdaddy's Avatar
did my first at 1k and the 2nd 3rd and 4th around 6k while dealing with my CEL but ill be chnging mine every 5k
Old 02-12-2013, 09:10 PM   #2009
Dynotronics1
ok, so I have two of you that want proecu kits. I sent 12 out today, so I have 5 left, and two are going to Mazda customers this week. So that means first to the shop gets the last one I have in stock!
BTW, I will be at the shop this weekend working on the race car, so if any of you that wanted tuning for the deal price want to swing by, thats fine, just let me know
Dynotronics1 is offline   Reply With Quote
Old 02-12-2013, 09:57 PM   #2010
Ocho-Seis
Ocho-Seis's Avatar
Sweet I will be there Saturday to grab mine...will be on that side of the city anyways in Cibolo
Old 02-12-2013, 10:06 PM   #2011
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Originally Posted by aaronosaurus View Post
Oil coolers are going to be a bigger deal for us in the summer! That being said, plenty of failures cases for that system will stop/slow the flow of oil to the motor. I'd be more worried about some obstruction or increase in resistance through that system decreasing the efficiency of the oil pump. I think that failure would be worse, because it's hard to detect, than one of the lines breaking and dumping all of your oil.
My advise would be to buy quality, get an oil pressure gauge, and keep an eye on the whole system. If something looks degraded/broken, its better to fix it before the whole thing fails. With the Perrin system you can twist off the adapter and replace the filter&oil to limp home should something go wrong, which is a nice safety net. I need to re-read the C stock rules, but I'll probably be getting one of those later this spring.
http://www.ft86club.com/forums/showthread.php?t=28713 (not a Perrin) this worries me a little, I may wait a little and let everyone else beta test.
Ricepuddin is offline   Reply With Quote
The Following User Says Thank You to Ricepuddin For This Useful Post:
aaronosaurus (02-13-2013)
Old 02-12-2013, 10:27 PM   #2012
Brian210
Brian210's Avatar
Drives: Whiteout Scion FRS
Im so ready to do this. Looks like it might be a race to your shop. Thanks for the heads up.
Brian210 is offline   Reply With Quote
Old 02-13-2013, 12:03 AM   #2013
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
For me, first one at 2K and I'm doing an OCI every 5000 thereafter so, I will be due in about 500 more miles @ 7K. Thanks for reminding me!!!
That PU "Penzoil Ultra" 5W-20 is a good oil. I went with TGMO “Toyota Genuine Motor Oil” 0W-20 for the first change and I have some Eneos Sustina 0W-20 for the next one. Should have done it the other way around but couldn't find the Sustina at a good price (it is expensive) when I did the first OC.
Mazda GF-5 0W-20 (made by Idemitsu) is suppose to be good oil at a decent price with higher VI (viscosity index) numbers than the dealership Subaru oil (also Idemitsu oil) so I might try that one next time if I can score a case at a good price at one of the dealers.
@johatan25 In case you are considering what oil to use...check out "Bob is the Oil Guy" website: http://www.bobistheoilguy.com/forums...s.php?ubb=cfrm -- CATERHAM is the xpert on 0W-20 oils and a year ago he did comparisons of all the brands and listed them in order of his preference. Eneos Sustina and TGMO were top rated at the time but, they say the newer API SN Toyota oil is not the same as the older SM oil that was tested in the past. New stuff has a "trinuclear moly" formula that replaces the actual molybdenum content our factory oil was loaded with. Speculation is the Toyota oil is made by Exxon now meeting the Toyota specifications. I tried to find the original post. If I come across it I will update. Anyway, BITOG website is a good oil reference site for sure!!! Oil is oil as far as molecular structure but there are different grades of base oils and it is the "additive" packages that differ among manufactures that distinguish performance characteristics. Just about everything you need to know about oil and more is on BITOG!
Extreme86 is offline   Reply With Quote
The Following User Says Thank You to Extreme86 For This Useful Post:
Old 02-13-2013, 12:26 AM   #2014
aaronosaurus
The data matters
Drives: WRBP BRZ
I missed that thread. His problem is not that the pressure is changing with the RPM, it's that he didn't measure it without the cooler and with the cooler. He dosen't know what changes have been made to the car, so unless someone with a stock vehicle steps up with some numbers he won't have a baseline to compare with. As long as you keep an eye on everything it should be alight, it's just that an oil cooler won't be as fire-and-forget as an exhaust.
aaronosaurus is offline   Reply With Quote
The Following User Says Thank You to aaronosaurus For This Useful Post:
Extreme86 (02-13-2013)
Old 02-13-2013, 12:29 AM   #2015
aaronosaurus
The data matters
Drives: WRBP BRZ
That site has _way_ to much information! Every time I would change the oil in my other Subarus I'd spend an hour or three reading BITOG, get totally confused, and end up with Rotella.
Old 02-13-2013, 01:31 AM   #2016
johatan25
johatan25's Avatar
first OC.
Dang... That's a lot of info... In just oil change... But I gotta start with asking what UOA and OCI is... Cuz I have no idea
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2332 12-24-2024 11:16 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 11:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 06:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 05:13 PM
