Old 02-10-2013, 08:53 PM   #1975
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
Originally Posted by Dynotronics1 View Post
ok, you guys did a great job rounding up folks for this gb.
So heres the deal for ya; I have to go to CA on a tuning trip on the 22. So between now and then I'm going to offer a one file deal to the SA/AU folks for 400.00$ If you want a cable set up, you can get you very own for 310.00$ But if there are enough of yall around each other, I would suggest you share.
This is a one time deal. Single 93 oct file, tuned to your car, in your choise of map positions. Stock map loaded in a different position for you. I will also set whatever RR features you like. For example;
stock mode 1
93 oct map mode 2
93 oct with FFS mode 3
93 oct with AB/FFS/LC mode 4
I'll take all comers from the Texas area until I head out the door on the 22nd.
And yes, I dyno sheets are on the way. I just have to finish this silly mazda 3 first, since its been bolted to the dyno for 3 weeks testing
I'll definitely be taking you up on that! Quick (probably newb question...), but when you list those 4 "modes", are those all included in the price of $400? Regardless, can't wait to get it done once my new pulley gets shipped to me!
MmmDieselFumes is offline   Reply With Quote
The Following User Says Thank You to MmmDieselFumes For This Useful Post:
tripjammer (02-11-2013)
Old 02-10-2013, 09:03 PM   #1976
johatan25
johatan25's Avatar
Drives: Lightning Red BRZ - Premium 6MT
The 4 options are basically switches. You're only getting one fuel map for that price which is 93 octane. There are different 'goodies' that ecutek comes with like flat foot shifting, launch control, autoblip and he can activate those for you if you want. If you get another fuel map (I.e e85) he'll place that on one of the four options.
I have:
Stock on mode 1
93 O tune on 2
93 O plus autoblip on 3
93 O autoblip/launch control on 4
Mods done (RED), Mods to come(BLACK): LED Swap, GReddy SP Elite Exhaust, Leather Seats, TSW 18x8.5 + 235/35, MOTIV Over & Catless Test pipe, EcuTek 93 Octane tune, PERRIN Lightweight Pulley, PERRIN Intake Inlet + drop-in filter,, e85 fuel map, 5axis Spoiler?, Borla UEL Headers?
johatan25 is offline   Reply With Quote
The Following 2 Users Say Thank You to johatan25 For This Useful Post:
MmmDieselFumes (02-11-2013), tripjammer (02-11-2013)
Old 02-11-2013, 12:50 AM   #1977
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
stock mode 1
93 oct map mode 2
So $710 For cable option? When can we set up a date? or do we just come by.
2013 Raven 6MT, Daily Driven, Totaled (10-01-2013 r.i.p)
Project GT-R Killer (Currently in Progress.)
Ocho-Seis is offline   Reply With Quote
The Following User Says Thank You to Ocho-Seis For This Useful Post:
Old 02-11-2013, 12:54 AM   #1978
Brian210
Brian210's Avatar
Drives: Whiteout Scion FRS
stock mode 1
93 oct map mode 2
im definitely in for sure. Just give me a date and time.
Brian210 is offline   Reply With Quote
Old 02-11-2013, 12:59 AM   #1979
ksnapka
ksnapka's Avatar
Drives: WRB AT BRZ Limited
Originally Posted by blunova View Post
Who's the blue BRZ that parked behind me at Home Depot today??
ME!!
ksnapka is offline   Reply With Quote
The Following User Says Thank You to ksnapka For This Useful Post:
blunova (02-11-2013)
Old 02-11-2013, 01:25 AM   #1980
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
Who was in the blue BRZ on 281 basse?
Argento ate6
mRdeMs83 is offline   Reply With Quote
The Following User Says Thank You to mRdeMs83 For This Useful Post:
Old 02-11-2013, 02:01 AM   #1981
MmmDieselFumes
Drives: .
Probably one of us 19 twin owners who were at the quarry for the photo-meet lol.
johatan25 (02-11-2013)
Old 02-11-2013, 01:06 PM   #1982
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Argento ate6
That was probably me...
tripjammer is offline   Reply With Quote
Old 02-11-2013, 02:08 PM   #1983
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
tuckdaddy is offline   Reply With Quote
Old 02-11-2013, 02:29 PM   #1984
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Here is the thread I started for the photo shoot
http://www.ft86club.com/forums/showt...381#post727381
Post what you all have as well.
Ricepuddin is offline   Reply With Quote
Old 02-11-2013, 05:03 PM   #1985
tripjammer
tripjammer's Avatar
Found this for the folks who want to know what the Ecutek tune does and how to use it:
http://blog.perrinperformance.com/how-to-use-map-switching-with-perrin-tunes/
How-To Use Map Switching with PERRIN ECUTEK Tunes
All PERRIN Custom Tune ECUTEK Maps have built in map switching. This feature allows us to create one tune that has multiple features built in, that are selectable by the end user. With the ECUTEK ProECU software we are able to select the different maps using the cruise control stick. This allows for (4) total maps to be selected by simply pulling back on the cruise stick and push it up and down to change maps. The ability to change maps quickly and on the fly is a very useful feature as it allows for things like Launch Control, Flat Foot Shifting, Auto Blip Downshift, more ignition timing, leaner AFR to all be changed on the fly!
How Does It Work?
To enable the map switching, first pull back on the cruise stick (toward the driver) for about 4 seconds. You will see the tachometer change to 1000 indicating map 1. Push the cruise stick up to select map 2, and the tach will go to 2000 RPM and same goes for map 3 and 4. Push the cruise stick down and you will change to the previous selected map. When you are finished choosing the map you desire, pull the cruise control stick back one more time and that locks in the map. Its as simple as that!
A Few Special Notes:
  • All of this works as long as the key is in the on position. That means the map can be selected with the engine running or with engine off.
  • Every time you turn off the car and start it again, it will default back to map number 1.
  • After selecting a map, the tach needle will resort back to the current engine RPM.
  • After enabling map switching, you have roughly 5 seconds to choose a map or the ECU will default back to the last map.
  • Maps are indicated using the tachometer needle. Map #1 is indicated by the needle resting at 1000RPM, Map #2 is indicated by the needle resting at 2000RPM, Map #3 is indicated by the needle resting at 3000RPM, and Map #4 is indicated by the needle resting at 4000RPM.
What Are The Features And How Do They Work?
Launch Control (LC)
The most requested feature is launch control. This is an alternate RPM limit that is activated when the vehicle is NOT moving and the clutch is depressed. After quickly giving the engine full throttle, the launch control (LC) RPM limit is enabled and RPM’s will hold at a preset point (example 3000 RPM). As soon as the clutch is release and the vehicle speed raises, the RPM limit now resorts back to the main RPM limit (Redline or 7500+ RPM). This allows for consistent launching while doing drag racing. While LC is enabled and working, the actual launch RPM can be adjusted by moving the cruise control stick up to raise the RPM, or down to lower the RPM.
Flat Foot Shifting (FFS)
Another really cool feature we utilize is Flat Foot Shifting. Flat Foot Shifting (FFS) is something that goes by many names, but they all do the same basic thing. When FFS is enabled, this means that you can be at full throttle and shift to the next higher gear without having to lift your foot off the gas pedal! This has a lot of benefits, but mainly its that it maintains speed during shifting. It also allows for faster and smoother shifts, which all leads to faster lap times. FFS is enabled any time the engine is at full throttle, and the clutch gets depressed. The ECU looks at the current RPM and cuts the fuel until the RPM drops to match the next gear. For instance, if you are full throttle in 3rd gear at 6000RPM and you push in the clutch (keeping your foot full throttle) the RPM’s will drop roughly 1000RPM to match the next higher gear. This feature works from 2000RPM to redline. That means you can give the engine full throttle at 4000RPM in 2nd gear, shift to the next higher gear and the ECU will drop the RPM’s to match going into 3rd. So it can be used in all situations, not just shifting at redline.
Auto Blip Downshift (ABDS)
Lastly is the Auto-Blip Downshift feature to help with decelerating and changing to the next lower gear. When Auto-Blip Downshift (ABDS) is enable, it helps with blipping the throttle to raise the RPM to better match the next lower gear while downshifting. Normally this is done using the Heel-Toe method of downshifting, where you have your right foot on the brake and gas at the same time and while you are braking, you roll your foot over to the gas pedal and give it a blip to raise the RPM’s up. ABDS is setup so you just need to use your right foot to brake with and the ECU does the blipping. With this feature enabled, it is activated when your foot is pressing on the brake, and then you depress the clutch to downshift to the next lower gear. The ECU will automatically blip the throttle to raise the RPM to match the next gear. It does not work if you press in the clutch then hit the brakes, only if you hit the brakes then operate the clutch. Example of this working is say you are at 4000RPM in 4th gear and you are approaching a turn that requires 3rd gear. As you apply the brakes, then hit the clutch and start to shift to 3rd gear, the ECU raises the RPM to roughly 5000RPM to match the next lower gear. As you release the clutch in 3rd gear, the RPM’s will be matched and you will be able to smoothly accelerate through the turn.
Other features we can add are things like changes to fueling and ignition timing. This allows us to add or remove HP from each map. With 4 maps and the ability to run different igniting timing between them allows us to add more timing or remove timing which effects HP. Same goes for fueling changes. We can lean out the fuel or richen it up to effect overall HP. What we normally find is that everyone wants the most power, so these features are left up to those that want to change HP with the flip of a switch. We can easily remove 20 HP from our base map by changing both fueling and timing.
The Following 2 Users Say Thank You to tripjammer For This Useful Post:
MmmDieselFumes (02-11-2013), Ocho-Seis (02-11-2013)
Old 02-11-2013, 06:15 PM   #1986
Ocho-Seis
Ocho-Seis's Avatar
OMG I'm so ready for the tune after reading that!!!
Old 02-11-2013, 06:44 PM   #1987
tripjammer
tripjammer's Avatar
So who is going to do the first supercharger or turbo charger install?
Old 02-11-2013, 10:00 PM   #1988
mRdeMs83
mRdeMs83's Avatar
Should I worry about going with an aftermarket exhaust for warranty reasons? If so should I even bother going with the TRD option?
Argento ate6
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2332 12-24-2024 11:16 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 11:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 06:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 05:13 PM
