Old 11-06-2011, 07:18 PM   #29
fatoni
Originally Posted by RRnold View Post
That's Defense by blocking his line or breaking his concentration!
TBH, even in stock trim a FWD vs RWD comparo is rhetorical...
not any more than rwd vs rwd
Old 11-06-2011, 07:21 PM   #30
fatoni
Originally Posted by 4agze View Post
yes its a track at night lol but thats like 7yrs ago I dont do it anymore
only thing I see wrong with a fwd is when elevation change like down hill & off camber turns a fwd will understeer but got to admire how well build a ITR, I remember back then when honda stated that they will bring the ITR here in US soil on limited number & it will be under the acura name and as i remember a lot of honda heads rolled and at the end acura Type-R was a success actually sold out half before it hit the showroom. this reminds you of anything like what going on with the scion FRS right now.
that has next to nothing to do with what wheels are driving the car. the only time a fwd will understeer where a rwd wont is under acceleration
Old 11-06-2011, 07:39 PM   #31
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
Im guessing you never been to a track before
I'll give you a video sample, horse thief mile has an infamous elevation drop listen to what KT says about the hasport EP3 civic, I driven my ae86 on this track few times and still I cant fully get hold of the left right drop.
4agze is offline   Reply With Quote
Old 11-06-2011, 09:01 PM   #32
fatoni
ive been on a track before. that track even. i think you kinda proved my point by bringing up the difficulty you have with your ae86. showing a case where a fwd has touble in a particular corner does not speak to the fact that it is because of the fwd or that it is not the case in rwd cars.
Old 11-06-2011, 10:02 PM   #33
4agze
4agze's Avatar
No i didnt prove your Point when i say "cant get Hold Of the left and right drop" im not talking about my car was understeering or over steering its my confidence and comitment on that turn, You say "the only time a fwd will understeer where a rwd wont is under acceleration" watch the video again he was going down hill turning making a lot of understeer.
Old 11-06-2011, 10:57 PM   #34
fatoni
again, missing the point. im not saying a fwd car wont understeer. what im saying is that things like that will happen to rwd cars as well. the problem isnt inherent to fwd and fwd alone
Old 11-06-2011, 11:51 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've driven FWD and RWD on the street, autocross and the track. I've experienced understeer in both. He was correct but it's probably better to add the word "properly setup" in front of FWD. A FWD economy car setup for massive understeer due to engineers making the design as safe as possible for random bad drivers driving the car will understeer more than a properly setup FWD car. The same is true for a RWD car and using more throttle in any situation where you want to break the laws of physics (such as the example below) will make the problem worse in BOTH FWD and RWD. If you do get enough power in RWD to get the car to rotate after trying to break the laws of physics you'll just have all four tires sliding instead of the front two.
If you take a corner where the maximum entry speed is say 50mph in both a FWD and RWD car at 70mph in RWD or FWD, you are going to exceed the maximum traction available from the front tires, and the car will understeer.
So yes, the ONLY time a properly setup and driven FWD car will understeer where a RWD car won't is under acceleration. It's just takes a different approach to correctly setup a FWD car to eliminate the understeer (assuming the car is properly driven, as again, improperly driven cars will ALL understeer regardless of which and how many wheels are putting the power to the ground).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-07-2011, 12:40 AM   #36
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
i once witnessed a new lotus elise understeer like you wouldn't believe at my local autocross. the guy had no idea how to drive his car, so he mashed the gas and made it understeer everywhere. anything can understeer.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 11-07-2011, 12:54 AM   #37
4agze
4agze's Avatar
I didnt say only fwd understeer offcourse all drivetrain fwd, rwd & awd can understeer, my point was fwd are more prone to understeer on a downhill And off camber turn read my post again.
Old 11-07-2011, 02:00 AM   #38
Kostamojen
The problem with FWD is recovering from understeer, not to mention inability to have more than X amount of usable power.
Old 11-07-2011, 02:46 AM   #39
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
I could have told you that Integras suck at offroading!
I remember when I saw the '97 ITR in Championship white for 27K @ Ball Honda, I thought to myself, "that is one overpriced Integra!"
True, too many different variables that can potentially skew the outcome; hp, weight, wheelbase etc.
Old 11-07-2011, 03:52 AM   #40
fernan2
fernan2's Avatar
Drives: Wrx
i wish i could drive like Keiichi.
fernan2 is offline   Reply With Quote
Old 11-07-2011, 09:48 AM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
they actually made awd integers for the Japanese market lol those parts plus some awd crv parts have been used to make an awd pikes peak ITR which was then converted to RWD.
27k with ac? Only overpriced a couple grand then. Have you ever driven one, especially a stock non fucked up one?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-07-2011, 01:48 PM   #42
RRnold
2 wheel member
RRnold's Avatar
If they made a RWD Integra, that would have been it! This one didn't have AC and marked up since it was the first year in the US. I drove my buddy's black Type R that was lightly modded before but it was around town so nothing serious.
What type of performance parts will you be looking to buy first? bFreed Engine, Exhaust, Transmission 12 11-09-2011 05:51 PM
AutoExpressUK: Honda Civic Type R is back quik1987 Other Vehicles & General Automotive Discussions 36 10-18-2011 01:15 PM
What type off LSD you would like on the FT-86? Blokatos Engine, Exhaust, Transmission 43 02-17-2010 04:06 AM
