Old 02-08-2013, 11:43 PM   #337
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Unichip Jack View Post
Important safety tip… for everybody using the Flux2 Display, ensure there’s sufficient slack in the cables between the dash and the display. Too little slack excessively strains the wires when you open the door and can break the wires or plugs.
Husker741… correct. If your dealer doesn’t dig modifications, remove the parts and there’s no footprint they’ve been there. If the dealer is ok with modifications (some of our biggest customers are dealers), leave the kit in place as it doesn’t interfere with anything they want to do when servicing the car and whatever they’re doing doesn’t affect the Unichip.
MapsQ folder update… the 92 Octane and 89 Octane maps are updated. Don’t blow a gasket when you open the folders and see more folders. Details to follow.
Cheers
I concur in the safety tip. Course it was my own damn fault. Live and learn.
Installed Mods:
Old 02-09-2013, 10:03 AM   #338
bakerr6
Drives: 2013 raven black fr-s
whoever is using the flux2, I'll post a pic of where I routed it. There's no way the wires will get frayed or the connectors will get pulled out, and it's in the perfect spot for when I do decide to go FI and run a pillar pod.
bakerr6 is offline   Reply With Quote
Old 02-09-2013, 06:43 PM   #339
xcelir8brz
Drives: 2013 BRZ Limited
Just custom mount it like I did (err more of a permanent solution) and you won't have any issues with wiring:
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
bakerr6 (02-09-2013)
Old 02-09-2013, 07:24 PM   #340
bakerr6
I put mine on the window right above that
Old 02-10-2013, 12:08 AM   #341
Shit Luck
Drives: red frs
just cant get past that ugly display unit...
Shit Luck is offline   Reply With Quote
Old 02-10-2013, 06:21 PM   #342
xcelir8brz
Yeah, it had to grow on me too.
Old 02-10-2013, 06:43 PM   #343
bakerr6
It's now bad if you integrate it into the dash. I thought of having a piece molded for it if I go to car shows, but I'm all about weight savings at this point
Old 02-10-2013, 06:54 PM   #344
xcelir8brz
It's not just about aesthetics. But power. People of asked me what it did. I said it helped the car go faster. And they said 'cool'. Nuff' said.
Old 02-10-2013, 06:55 PM   #345
Shit Luck
Drives: red frs
its huge, if looks like i added it to the car it has no buisness in my car... shame though, i do like the price.
Old 02-10-2013, 06:57 PM   #346
xcelir8brz
Believe you me. I thought of various mounting options, including it mounted to the right of the radio. Thought that was too far to see and control. If they could shrink the size down dramatically I'd be up for that. I made a custom bracket/mixed with the suction cup bracket to affix it sturdily to the dash.
It works. It's not pretty. But it works.
And no Taxi cab remarks.
Old 02-11-2013, 11:31 PM   #347
Shit Luck
Drives: red frs
ok let me ask a few questions...
what do i need to purchase to be able to load tunes?
do i need that huge flux 2 unit?
Old 02-12-2013, 07:19 AM   #348
xcelir8brz
Unichip and download cable. You can flip between two tunes with switch. If you want to see OBDII, etc. and flip between five tunes, you need Flux2.
Old 02-12-2013, 08:27 AM   #349
QFry
QFry's Avatar
Drives: '13 Argento FR-S
They have the flux2, a 2way switch (no display), and a 5way switch (no display).
If you dont want the flux2 order it with the switch you want...one of the benefits of the switches is you can change maps on the fly...just remember which # is associated with which map. Honestly, i find myself using the flux 2 instead of the switch ...but i like seeing my timing and fuel etc.
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
Old 02-12-2013, 10:21 AM   #350
swift996
swift996's Avatar
I just got the unichip and download cable. The special with the flux 2 was tempting but since I run the Torque app via a wireless adapter on the OBD II, I didn't want to add the flux 2. I also didn't know where I'd put it. It's a nice add on though.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
