Old 02-08-2013, 02:55 PM   #113
epifan
Some of latest factory bins included in brzEdit ECUs pack, including ZA1JA00C.
Pro version users can dump ECU bins for collect ECUs pack
Originally Posted by Foobar View Post
I presume from some of the screenshots that other members have posted that the factory files you're providing are the original ones that don't include Subaru's latest TSB fix. Any chance you have the files available for the latest factory reflash? That's ZA1JA00C for USDM 6MT, for instance.
epifan is offline   Reply With Quote
Old 02-08-2013, 09:40 PM   #114
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
If I read your website correctly, the only way to locate, identify, and edit new maps within the edu is if you have the "pro" tuning kit?
Forgive me for my ignorance.
George
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 02-08-2013, 10:14 PM   #115
mad_sb
Drives: 2013 Asphalt FR-S
George
I don't believe that is correct. Even with EcuFlash, the process of finding new maps does not involve ecuflash... testing them does, but finding is normally done with a dis-assembly program not the editor program itself.
I'm fairly sure The personal and pro versions will updated as new maps are found. And of course if you find a new map via whatever means, if you email the data to Epifan, I'm sure he will make it available via a program update.
The personal version was just released this week and there have already been two updates published.
Old 02-10-2013, 03:12 PM   #116
epifan
With Pro version you have access to raw ECU bin using internal HEXViewer tool. So you can get access to all possible maps (1700+) and create defs for them.
The Following User Says Thank You to epifan For This Useful Post:
Deepseadiver (02-10-2013)
Old 02-10-2013, 08:23 PM   #117
86drift
86drift's Avatar
Drives: Toyota 86 GT
Welcome to the forum! It's good to have vendors on to help answer questions.
Hopefully the admins will set up a setup a sub-category for tuning because there's going to be a lot of questions and interest in this stuff.
86drift is offline   Reply With Quote
Old 02-10-2013, 09:16 PM   #118
xjohnx
Grip>Slip
xjohnx's Avatar
Does that mean owners of the Pro version could theoretically read maps flashed by ecutek tuners?
Old 02-10-2013, 11:58 PM   #119
brzEdit
No, Ecutek maps will carry a proprietary encryption applied to them. So I doubt you will be able to ready them using our software.
brzEdit is offline   Reply With Quote
The Following User Says Thank You to brzEdit For This Useful Post:
xjohnx (02-11-2013)
Old 02-11-2013, 01:46 AM   #120
ft_sjo
Drives: GT86
Can you read the OEM cal with this?
Old 02-11-2013, 02:01 AM   #121
epifan
Yes, in special "dump" format using Pro version only
Old 02-11-2013, 03:32 AM   #122
ft_sjo
Drives: GT86
Thanks. Do you have the latest UK cal with the idle fix in it?
Old 02-11-2013, 03:40 AM   #123
epifan
Yes
Old 02-11-2013, 07:09 AM   #124
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks.
For the record, i was just asking to make sure those guys were safe. I wouldn't know what to do with the rom even if i had it.
Old 02-11-2013, 10:17 AM   #125
ft_sjo
Drives: GT86
Yes
Thanks, and could you also please confirm if realtime map tracing is enabled for all x/y tables and datalogging?
Old 02-11-2013, 10:18 AM   #126
epifan
Yes, sure. This is standard feature of all ecuEdit-based products
ft_sjo (02-11-2013)
